电子发烧友论坛|
本人小白一枚,想通过一个IO口上升沿触发, 控制另一个IO输出2秒的高电平,然后输出2秒低电平,我编了程序,中断是触发了,进入中断处理函数后只执行了第一句,控制的那个IO口一直都是高电平,高手帮我看看,谢谢了
/* USER CODE BEGIN Header */ /** ****************************************************************************** * @file : main.c * @brief : Main program body ****************************************************************************** ** This notice applies to any and all portions of this file * that are not between comment pairs USER CODE BEGIN and * USER CODE END. Other portions of this file, whether * inserted by the user or by software development tools * are owned by their respective copyright owners. * * COPYRIGHT(c) 2019 STMicroelectronics * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * 1. Redistributions of source code must retain the above copyright notice, * this list of conditions and the following disclaimer. * 2. Redistributions in binary form must reproduce the above copyright notice, * this list of conditions and the following disclaimer in the documentation * and/or other materials provided with the distribution. * 3. Neither the name of STMicroelectronics nor the names of its contributors * may be used to endorse or promote products derived from this software * without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ****************************************************************************** */ /* USER CODE END Header */ /* Includes ------------------------------------------------------------------*/ #include "main.h" /* Private includes ----------------------------------------------------------*/ /* USER CODE BEGIN Includes */ #include "flash.h" /* USER CODE END Includes */ /* Private typedef -----------------------------------------------------------*/ /* USER CODE BEGIN PTD */ uint32_t state = 0, count = 0; /* USER CODE END PTD */ /* Private define ------------------------------------------------------------*/ /* USER CODE BEGIN PD */ /* USER CODE END PD */ /* Private macro -------------------------------------------------------------*/ /* USER CODE BEGIN PM */ /* USER CODE END PM */ /* Private variables ---------------------------------------------------------*/ /* USER CODE BEGIN PV */ /* USER CODE END PV */ /* Private function prototypes -----------------------------------------------*/ void SystemClock_Config(void); static void MX_GPIO_Init(void); /* USER CODE BEGIN PFP */ /* USER CODE END PFP */ /* Private user code ---------------------------------------------------------*/ /* USER CODE BEGIN 0 */ /* USER CODE END 0 */ /** * @brief The application entry point. * @retval int */ int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration--------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* USER CODE BEGIN Init */ /* USER CODE END Init */ /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ // state = Flash_Read(FLASH_USER_START_ADDR); /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); /* USER CODE BEGIN 2 */ /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { // HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_RESET); // HAL_Delay(1000); /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ /* switch(state) { case 0: //µÈ´ýPB0ÖÐ¶Ï break; case 1: //PB0ÒÑÖÐ¶Ï if(count == 0) { Flash_Write(FLASH_USER_START_ADDR,state); } if(count++ > 20) { state = 2; count = 0; HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_SET); } break; case 2: //µÈ´ýPA12ÖÐ¶Ï break; case 3: if(count == 0) { Flash_Write(FLASH_USER_START_ADDR,state); } if(count++ > 20) { state = 0; count = 0; HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_SET); } break; } HAL_Delay(100); //100ms*/ } /* USER CODE END 3 */ } /** * @brief System Clock Configuration * @retval None */ void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; /**Initializes the CPU, AHB and APB busses clocks */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI; RCC_OscInitStruct.HSIState = RCC_HSI_ON; RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE; if (HAL_RCC_OscConfig( RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /**Initializes the CPU, AHB and APB busses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK) { Error_Handler(); } } /** * @brief GPIO Initialization Function * @param None * @retval None */ static void MX_GPIO_Init(void) { GPIO_InitTypeDef GPIO_InitStruct = {0}; /* GPIO Ports Clock Enable */ __HAL_RCC_GPIOF_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); /*Configure GPIO pin Output Level */ HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_RESET); /*Configure GPIO pin Output Level */ HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_RESET); /*Configure GPIO pin : PA3 */ GPIO_InitStruct.Pin = GPIO_PIN_3; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; HAL_GPIO_Init(GPIOA, GPIO_InitStruct); /*Configure GPIO pin : PB0 */ GPIO_InitStruct.Pin = GPIO_PIN_0; GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING; GPIO_InitStruct.Pull = GPIO_PULLDOWN; HAL_GPIO_Init(GPIOB, GPIO_InitStruct); /*Configure GPIO pin : PA12 */ GPIO_InitStruct.Pin = GPIO_PIN_12; GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING; GPIO_InitStruct.Pull = GPIO_PULLUP; HAL_GPIO_Init(GPIOA, GPIO_InitStruct); /*Configure GPIO pin : PB3 */ GPIO_InitStruct.Pin = GPIO_PIN_3; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; HAL_GPIO_Init(GPIOB, GPIO_InitStruct); /* EXTI interrupt init*/ HAL_NVIC_SetPriority(EXTI0_1_IRQn, 0, 0); HAL_NVIC_EnableIRQ(EXTI0_1_IRQn); HAL_NVIC_SetPriority(EXTI4_15_IRQn, 0, 0); HAL_NVIC_EnableIRQ(EXTI4_15_IRQn); } /* USER CODE BEGIN 4 */ void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin) { if(GPIO_Pin == GPIO_PIN_0) { HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_SET); HAL_Delay(1000); HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_RESET); HAL_Delay(1000); /* if(state == 0) { state = 1; count = 0; HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_SET); HAL_Delay(2000); } } else if(GPIO_Pin == GPIO_PIN_12) { if(state == 2) { state = 3; count = 0; HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_SET); HAL_Delay(2000); } } else { }*/ } } /* USER CODE END 4 */ /** * @brief This function is executed in case of error occurrence. * @retval None */ void Error_Handler(void) { /* USER CODE BEGIN Error_Handler_Debug */ /* User can add his own implementation to report the HAL error return state */ /* USER CODE END Error_Handler_Debug */ } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(char *file, uint32_t line) { /* USER CODE BEGIN 6 */ /* User can add his own implementation to report the file name and line number, tex: printf("Wrong parameters value: file %s on line %drn", file, line) */ /* USER CODE END 6 */ } #endif /* USE_FULL_ASSERT */ /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/ |
2个回答
中断里面延时,这中断时间太长了吧?Delay(1000)也是中断方式,是不是优先级配置有问题,导致Delay执行不下去?
首先,我会尝试理解您的问题并提供一些建议。您想要通过一个输入/输出(IO)口的上升沿触发,控制另一个IO口输出2秒的高电平,然后输出2秒的低电平。您提到您的程序中的中断被触发了,但是只执行了第一句,导致控制的IO口一直保持高电平。
为了解决这个问题,我们需要确保以下几点: 1. 确保您的硬件连接正确,即输入信号可以正确地触发中断。 2. 在中断服务程序中,确保您正确地设置了定时器或其他计时机制,以便在2秒后切换输出电平。 3. 确保您的中断服务程序中的代码是按照预期执行的,包括清除中断标志位,以防止重复触发。 以下是一个简化的示例,展示了如何使用STM32微控制器实现您的需求: ```c #include "stm32f1xx_hal.h" // 定义输入和输出IO口 #define INPUT_PIN GPIO_PIN_0 #define OUTPUT_PIN GPIO_PIN_1 // 定义定时器和通道 #define TIMER_HANDLE htim1 #define TIMER_CHANNEL TIM_CHANNEL_1 // 全局变量,用于存储定时器的开始时间 uint32_t startTime; void SystemClock_Config(void); void MX_TIM1_Init(void); int main(void) { HAL_Init(); SystemClock_Config(); MX_TIM1_Init(); // 初始化GPIO GPIO_InitTypeDef GPIO_InitStruct = {0}; __HAL_RCC_GPIOA_CLK_ENABLE(); GPIO_InitStruct.Pin = INPUT_PIN | OUTPUT_PIN; GPIO_InitStruct.Mode = GPIO_MODE_INPUT; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); // 初始化定时器 TIMER_HANDLE.Instance = TIM1; TIMER_HANDLE.Init.Prescaler = (uint32_t)((SystemCoreClock / 2) - 1); TIMER_HANDLE.Init.CounterMode = TIM_COUNTERMODE_UP; TIMER_HANDLE.Init.Period = 1000 - 1; TIMER_HANDLE.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; TIMER_HANDLE.Init.RepetitionCounter = 0; HAL_TIM_Base_Init(&TIMER_HANDLE); // 配置定时器通道 TIM_HandleTypeDef *htim = &TIMER_HANDLE; TIM_OC_InitTypeDef sConfigOC = {0}; TIM_OC_ChannelConfigTypeDef sConfig = {0}; sConfigOC.OCMode = TIM_OCMODE_TOGGLE; sConfigOC.Pulse = 1000; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; HAL_TIM_OC_ConfigChannel(htim, &sConfigOC, TIMER_CHANNEL); HAL_TIM_OC_Start_IT(htim, TIMER_CHANNEL); // 配置外部中断 HAL_NVIC_SetPriority(EXTI0_IRQn, 0, 0); HAL_NVIC_EnableIRQ(EXTI0_IRQn); while (1) { // 空循环,等待中断 } } void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim) { if (htim->Instance == TIM1) { // 切换输出电平 HAL_GPIO_TogglePin(GPIOA, OUTPUT_PIN); // 重新启动定时器 HAL_TIM_Base_Start_IT(&TIMER_HANDLE); } } void EXTI0_IRQHandler(void) { // 清除中断标志位 __HAL_GPIO_EXTI_CLEAR_IT(INPUT_PIN); // 启动定时器 HAL_TIM_Base_Start_IT(&TIMER_HANDLE); } ``` 请注意,这个示例仅用于演示目的,您可能需要根据您的硬件和需求进行调整。希望这可以帮助您解决问题。如果您有任何疑问或需要进一步的帮助,请随时提问。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2166浏览 3评论
/9
GMT+8, 2025-12-2 04:42 , Processed in 0.821326 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
275
