STM8S105C6T6 UART2串口,能接收数据,不能发送数据,哪位大神能帮忙看看。现在单片机自发自收没有问题,串口自发自收也没有问题,但是两个连接起来就单片机只能接收数据,发送数据,串口无接收
工具:USB转TTL 以下是程序代码: void UART2_GPIO_init() { GPIO_DeInit(GPIOD); //GPIO_Init(GPIOD,GPIO_PIN_5,GPIO_MODE_IN_PU_NO_IT);//串口通讯TX GPIO_Init(GPIOD,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_FAST); //GPIO_Init(GPIOD, GPIO_PIN_5, GPIO_MODE_OUT_PP_HIGH_FAST); GPIO_Init(GPIOD,GPIO_PIN_6, GPIO_MODE_IN_FL_NO_IT);//串口通讯RX } void UART2_ConfigurationInit(void) { UART2_GPIO_init(); UART2_DeInit(); UART2_Init((u32)9600, UART2_WORDLENGTH_8D, UART2_STOPBITS_1, UART2_PARITY_NO, UART2_SYNCMODE_CLOCK_DISABLE, UART2_MODE_TXRX_ENABLE); //波特率 9600 8位数据 1个停止位 没有奇偶校验 关闭SCK 同意串口接受和发送 UART2_ITConfig(UART2_IT_RXNE_OR,ENABLE);//开启读中断,接收数据寄存器非空或溢出错误中断 //UART2_ITConfig(UART2_IT_TXE,ENABLE);//开启写中断 UART2_Cmd(ENABLE);//启用串口 } void UART2_Close() { UART2_Cmd(DISABLE); UART2_ITConfig(UART2_IT_RXNE_OR,DISABLE);//关读中断,接收数据寄存器非空或溢出错误中断 UART2_ITConfig(UART2_IT_TXE,DISABLE);//关写中断 } void Send_Data(u8 Data) { /*while((UART2_GetFlagStatus(UART2_FLAG_TXE)==RESET)); //待发送寄存器为空 UART2_SendData8((unsigned char)Data); while((UART2_GetFlagStatus(UART2_FLAG_TC)==RESET)); //传输完成的标志 */ unsigned int j; while((UART2_GetFlagStatus(UART2_FLAG_TXE)==RESET)); //待发送寄存器为空 UART2_SendData8(Data); while((UART2_GetFlagStatus(UART2_FLAG_TC)==RESET)); //UART2_ClearFlag(UART2_FLAG_TC); //j=50; //while(j--); } //发送字符串Send_Str("STM8SUART rn") void Send_Str(unsigned char *Data) { while(*Data!='�') { Send_Data(*Data); Data++; } } INTERRUPT_HANDLER(UART2_TX_IRQHandler, 20)//发送数据中断 { /* In order to detect unexpected events during development, it is recommended to set a breakpoint on the following instruction. */ // 写操作自动清中断,因此可以不用显式清中断 //UART2_ClearITPendingBit(UART2_IT_TXE); } /** * @brief UART2 RX interrupt routine. * @param None * @retval None */ INTERRUPT_HANDLER(UART2_RX_IRQHandler, 21)//接收数据中断 { /* In order to detect unexpected events during development, it is recommended to set a breakpoint on the following instruction. UART2_ClearITPendingBit(UART2_IT_RXNE); Uart2RecData = UART2_ReceiveData8(); Send(Uart2RecData); */ // 读操作自动清中断,因此可以不用显式清中断 // 注意这里的中断名是RXNE,不是RXNE_OR Uart2RecData = UART2_ReceiveData8(); UART2_SendData8(Uart2RecData); UART2_ClearITPendingBit(UART2_IT_RXNE); } |
2个回答
应该是双机的RXD和TXD连接错了
从代码来看,你的串口发送设置有问题。你将GPIO5设置为了输出模式,但是没有将GPIO6设置为输出模式。串口发送数据是需要在TX引脚上输出数据的,因此你需要将GPIO6设置为输出模式。
你可以尝试修改代码如下: ``` void UART2_GPIO_init(){ GPIO_DeInit(GPIOD); GPIO_Init(GPIOD,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_FAST);//串口通讯TX GPIO_Init(GPIOD,GPIO_PIN_6, GPIO_MODE_OUT_PP_LOW_FAST);//串口通讯RX } ``` 这样应该就能够正确发送数据了。请注意,你的代码中只有GPIO5和GPIO6被初始化,如果你还需要使用其他引脚作为串口的控制引脚(如CTS和RTS),请根据需要进行相应的初始化操作。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1792 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1626 浏览 1 评论
1094 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
732 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1682 浏览 2 评论
1943浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
740浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
577浏览 3评论
600浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
562浏览 3评论
GMT+8, 2024-12-26 05:40 , Processed in 0.948491 second(s), Total 84, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
