电子发烧友论坛|
你好,
我想在stm8s208cb(slave)和stm8s105c6t6(master)之间使用I2C通信。我使用stm8s标准外设库。 stm8s105c6t6(主)代码: - 在虚空主体 CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); // 16MHz时钟 I2C_Init(400000,0xA0,I2C_DUTYCYCLE_2,I2C_ACK_CURR,I2C_ADDMODE_7BIT,16); // i2c init I2C_Cmd(ENABLE); I2C_GenerateSTART(ENABLE); //发送开始条件 I2C_Send7bitAddress(0x30,I2C_DIRECtiON_TX); //发送写入的从站地址 / ******************* ******************* / - 一会儿(1) I2C_GenerateSTART(ENABLE); I2C_SendData(0x61); I2C_GenerateSTOP(ENABLE); stm8s208cb(slave)代码: - 在虚空主体 CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); // 16MHz系统时钟 I2C_DeInit(); I2C_Init(400000,0x30,I2C_DUTYCYCLE_2,I2C_ACK_CURR,I2C_ADDMODE_7BIT,16); I2C_Cmd(ENABLE); - 一会儿(1) uint8_t RxBuffer = I2C_ReceiveData(); 但它不起作用。求救,谢谢! #i2c#stm8#i2c-example 以上来自于谷歌翻译 以下为原文 Hello, I want to use I2C communication between stm8s208cb(slave) and stm8s105c6t6(master). I use stm8s standard peripheral library. stm8s105c6t6(master) code: -in the void main CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //16MHz clock I2C_Init(400000, 0xA0, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, 16); //i2c init I2C_Cmd(ENABLE); I2C_GenerateSTART(ENABLE); //send start condition I2C_Send7bitAddress(0x30, I2C_DIRECTION_TX); //send slave address for write /********************************************************************/ -in the while(1) I2C_GenerateSTART(ENABLE); I2C_SendData(0x61); I2C_GenerateSTOP(ENABLE); stm8s208cb(slave) code: -in the void main CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //16MHz System Clock I2C_DeInit(); I2C_Init(400000, 0x30, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, 16); I2C_Cmd(ENABLE); -in the while(1) uint8_t RxBuffer = I2C_ReceiveData(); But it does not work. Help please, thank you! #i2c #stm8 #i2c-example |
1个回答
亲爱的sakarya.erhan,
首先调试主机,如果它为init,start和stopn生成正确的波形。您可以在CRO或逻辑分析仪上看到主CLK和DATA引脚。 /*请 如果这篇文章可以帮助您或解决您的问题。* / / **免责声明** / / *我不是ST技术支持团队的成员。因此,请在您的最后验证/测试任何支持/建议。* / / *此帖仅用于一般支持目的,不收取任何费用。如果您需要任何个人支持,请联系 embeddeddesign.help@gmail.com * / 以上来自于谷歌翻译 以下为原文 Dear sakarya.erhan, First debug your master, if it is generating correct waveform for init, start and stopn. You can see the master CLK and DATA pin on CRO or Logic Analyzer. /*Please if this post helps you or solves your problem.*/ /**disclaimer**/ /* I am not a person from ST Technical Support Team. So please verify/test any support/suggestion at your end.*/ /* This post is only for general support purpose and free of any charge.If you need any personal support for your work please contact at embeddeddesign.help@gmail.com */ |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:42 , Processed in 0.752385 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1785
