各位大神:
我用STM32F401 进行串口通信,UASRT1跟UASRT2使用正常,使用USART6时不正常,发送HELLO WORLD为乱码怎么破? 代码如下: main { SystemInit(); /*定义一个GPIO_InitTypeDef类型的结构体*/ GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStruct; GPIO_Structinit( GPIO_InitStructure); //USART_DeInit(USART6); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE); //开启GPIOC时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART6, ENABLE); //开启USART6时钟 /*USART6管脚复用配置*/ GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_USART6);//配置复用的引脚, GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_USART6);// /*配置USART6管脚及相关参数*/ /*配置GPIOC_Pin6为USART6_TX:输出*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //设置为复用,必须为AF GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //没有上拉和下拉 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //输出推免 GPIO_Init(GPIOC, GPIO_InitStructure); /*配置GPIOC_Pin7为USART6_RX:输入*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //这也必须为复用,与M3不同! GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, GPIO_InitStructure); /*配置USART6*/ USART_StructInit( USART_InitStructure); //这个要屏蔽是不行的?? USART_InitStructure.USART_BaudRate = 115200;//345600;//115200;// USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART6, USART_InitStructure); /*使能USART6*/ USART_ClockStructInit( USART_ClockInitStruct); //填充外设时钟默认值 USART_ClockInit(USART6, USART_ClockInitStruct); //初始化外设时钟 USART_ITConfig(USART6, USART_IT_RXNE, ENABLE); //使能 USART1中断 USART_Cmd(USART6, ENABLE); /*串口6中断配置*/ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);//使能GPIOC时钟 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //嵌套优先级分组为 1 NVIC_InitStructure.NVIC_IRQChannel = USART6_IRQn; //嵌套通道为USART6_IRQn NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //抢占优先级为 0 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //响应优先级为 0 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //通道中断使能 NVIC_Init( NVIC_InitStructure); USART_ITConfig(USART6, USART_IT_RXNE, ENABLE);//开启中断 while { USART6_TX("Hello world!n"); delay(0xFFFFF); } } VOID USART6_TX(INT8 *usStr) { while (*usStr) { USART_SendData(USART6, *usStr++); /* 循环发送知道结束*/ while (USART_GetFlagStatus(USART6, USART_FLAG_TXE) == RESET); //当TXE被置起时,一帧数据传输完成 } } VOID delay(UINT32 uDelayVal) { UINT32 uTemp = 0 ; for(uTemp=0;uTemp |
2个回答
这么说吧,对于STM32F401来讲,USART1和USART6特性参数是一样的,如果USART1可以,相同的参数应用到USART6肯定可以的。你不妨检查下管脚以及连接方面,尤其看看有没有搞错管脚了,有时低级错误照样酿成大问题。尽可能使用CubeMx做配置。
一种可能的原因是USART6的引脚配置不正确。请确保引脚配置正确,并按照以下步骤进行检查和修复:
1.打开STM32的参考手册,在其GPIO部分找到USART6的引脚配置。 2.确保将这些引脚正确地配置为USART模式,并在初始化GPIO时将它们设置为相应的输出模式、速度和推挽/开漏设置。 3.确保将USART6正确地初始化为所需的波特率、数据位、停止位和校验位。这些设置应与你的通信设备(如电脑)一致。 4.确保你在发送数据之前等待USART6的发送缓冲区为空,以确保数据不会丢失。 另外,还可以尝试使用示波器检查USART6的发送引脚,以确保它们在发送数据时正常工作。如果USART6的引脚配置和初始化都正确,那么很可能是通信设备(如电脑)的接收设置有问题,导致接收到的数据是乱码。在这种情况下,你可能需要检查通信设备的接收设置并进行修复。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 23:53 , Processed in 0.838446 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2390
