我使用Wiced studio 6.4 编译 iperf_app , 我升级了KitProg3,
但是烧写flash报错,如下 请问如何处理? Welcome.iperf_app-CY8CKIT_062 ----------------------------------|---------|---------| | | Static | Module | Flash | RAM | ----------------------------------+---------+---------| command_console | 3620 | 412 | crc | 1060 | 0 | DHCP_Server | 1432 | 132 | DNS | 64 | 44 | Host MCU-family library | 22835 | 6555 | Interrupt Vectors | 652 | 0 | iperf | 25242 | 2128 | libc | 46885 | 3404 | Networking | 3706 | 13953 | NetX-Duo - Interfaces Stacks | 0 | 16 | Other | 48113 | 3461 | Packet Buffers | 0 | 57780 | platform | 2300 | 736 | RAM Initialisation | 4628 | 0 | resources | 44 | 0 | Ring_Buffer | 156 | 0 | SPI_Flash_Library_CY8CKIT_062 | 1172 | 352 | Startup Stack Link Script fill | 71 | 10 | Supplicant - BESL | 84 | 0 | ThreadX | 8740 | 400 | WICED | 4404 | 1088 | wiced_log | 300 | 1104 | Wiced_RO_FS | 566 | 0 | WWD | 16845 | 3197 | ----------------------------------+---------+---------| TOTAL (bytes) | 188291 | 94772 | ----------------------------------|---------|---------| Downloading Bootloader ... Building apps lookup table "**** OpenOCD failed - ensure you have installed the driver from the drivers directory, and that the debugger is not running **** In Linux this may be due to USB access permissions. In a virtual machine it may be due to USB passthrough settings. Check in the task list that another OpenOCD process is not running. Check that you have the correct target and JTAG device plugged in. ****" Downloading DCT ... "**** OpenOCD failed - ensure you have installed the driver from the drivers directory, and that the debugger is not running **** In Linux this may be due to USB access permissions. In a virtual machine it may be due to USB passthrough settings. Check in the task list that another OpenOCD process is not running. Check that you have the correct target and JTAG device plugged in. ****" Downloading resources filesystem ... build/Welcome.iperf_app-CY8CKIT_062/filesystem.bin at sector 1 size 104... tools/makefiles/wiced_apps.mk:335: recipe for target 'FILESYSTEM_IMAGE_DOWNLOAD' failed make.exe[1]: *** [FILESYSTEM_IMAGE_DOWNLOAD] Error 1 Makefile:351: recipe for target 'main_app' failed make: *** [main_app] Error 2 15:00:25 Build Finished (took 5s.381ms) |
1个回答
根据您提供的信息,以下是一些导致PSoc062 WIFI-BT烧写失败的原因以及相应的解决方法:
1. 硬件连接错误:检查PSoc062与KitProg3之间的连接是否正确,确保连接器插好且连接器引脚对齐。 2. 设备电源问题:确保PSoc062有足够的电源供应并且电源电压稳定。如果使用外部电源,请检查电源适配器是否正常工作并提供正确的电压。 3. Bootloader问题:检查PSoc062的Bootloader是否正确安装。您可以尝试重新安装Bootloader或者刷新Bootloader固件。 4. 编程接口问题:确保您使用的编程接口与Wiced Studio 6.4兼容。请检查编程接口的设置并确保选择正确的接口。 5. 硬件故障:如果以上方法无效,可能存在硬件故障。您可以尝试更换或者修复硬件设备。 6. 软件问题:确保使用的Wiced Studio 6.4版本兼容PSoc062 WIFI-BT。尝试升级Wiced Studio至最新版本并重新编译和烧写。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
为什么用FatFS在SD卡创建文件,在单片机上读写正常,用读卡器插到电脑上就什么都没有
297 浏览 0 评论
708 浏览 2 评论
《DNK210使用指南 -CanMV版 V1.0》第九章 打印输出实验
375 浏览 0 评论
stm32f407+ksz8863rlli概率性ping不通
1090 浏览 1 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-常见网络服务搭建之NFS服务搭建
515 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11334 浏览 31 评论
GMT+8, 2024-10-1 05:53 , Processed in 0.729833 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
