电子发烧友论坛|
严格按照指示操作。在步骤9中,“双击新创建的制作目标来构建代码,编程工具包,并运行示例。请注意,这可能需要几分钟。“我得到以下输出错误,我不知道如何修复:
11:05:40***构建项目43XXXW-Wi-Fi**配置默认值 “C:TePtErs\Debug WICED Studio1.6\43XXXWi-Fi\Po.exe”DEMO。CE222494OPSo66WICDEDWIVE-CY8CKITY062下载程序下载运行 MaCeCMDMaskObjest= DeMo.CE222494PoS66WiDEDWiFi-CY8CKITY062下载下载运行OTA2A支持被禁用 首次制作配置文件 +------------------------------------------------+ 重要注意事项 +------------------------------------------------+ Wi-Fi MAC地址 目标Wi-Fi MAC地址定义在WICED SDK> 确保每个目标设备具有唯一的地址。γ +------------------------------------------------+ 单片机与Wi-Fi节电 *使用WICE Posivabess API函数的应用连接精确的32 kHz 工具/MaFixFix/WICDEZY CONFIG.MK:267:**未知组件:DEMO。CE222494PPSO66WICDEDWiFiFi。停下来。 参考时钟到WLAN芯片的睡眠时钟输入引脚。请阅读WICED Powersave 制作:没有规则去做目标“构建/演示。CE222494PPSO6WIDEDWIFI-CY8CKITY062/COFIG.MK',需要MeNeIAPP”。停下来。 如果你计划使用PoxSaveStices特性,请在文档目录中找到应用程序注释。γ +------------------------------------------------+ 11:05:40搭建完成(取39MS) PNG 253.9 K 以上来自于百度翻译 以下为原文 Followed the instructions exactly. On step 9, "Double-click the newly created make target to build the code, program the kit, and run the example. Note that this may take a few minutes." I get the following output with error, I don't know how to fix: 11:05:40 **** Build of configuration Default for project 43xxx_Wi-Fi **** "C:\Users\tpeterson\Documents\WICED-Studio-6.1\43xxx_Wi-Fi\make.exe" demo.CE222494_PSoC6_WICED_WiFi-CY8CKIT_062 download_apps download run MAKEFILE MAKECMDGOALS=demo.CE222494_PSoC6_WICED_WiFi-CY8CKIT_062 download_apps download run OTA2_SUPPORT is disabled Making config file for first time +-----------------------------------------------------------------------------------------------------+ | IMPORTANT NOTES | +-----------------------------------------------------------------------------------------------------+ | Wi-Fi MAC Address | | The target Wi-Fi MAC address is defined in | Ensure each target device has a unique address. | +-----------------------------------------------------------------------------------------------------+ | MCU & Wi-Fi Power Save | | It is *critical* that applications using WICED Powersave API functions connect an accurate 32kHz | tools/makefiles/wiced_config.mk:267: *** Unknown component: demo.CE222494_PSoC6_WICED_WiFi. Stop. | reference clock to the sleep clock input pin of the WLAN chip. Please read the WICED Powersave | make: *** No rule to make target 'build/demo.CE222494_PSoC6_WICED_WiFi-CY8CKIT_062/config.mk', needed by 'main_app'. Stop. | Application Note located in the documentation directory if you plan to use powersave features. | +-----------------------------------------------------------------------------------------------------+ 11:05:40 Build Finished (took 339ms)
3个回答
不要介意。我把文件复制到错误的位置。
以上来自于百度翻译 以下为原文 Never mind. I copied the files to the wrong location. |
这是不明显的指南档案文件应该去。我右键单击开始菜单中的Wice程序,选择了属性,并在C:用户MyNAM\AppDATA下使用该位置。
我想我需要把文件放在C:用户MyNAM\DealsWICED Studio6下面。 以上来自于百度翻译 以下为原文 It was not obvious from the guide where the archive files should go. I right clicked on Wiced program in Start menu, selected properties and used that location under c:usersmynameappdata... Figured out that I needed to put the files under c:usersmynameDocumentsWICED-Studio-6. |
你可以用一个心跳宽度调制器和一个高重复输入时钟来控制LED的力。在义务周期极少的情况下,则LED的功率较低,CyPress帽感片具有两种检测模式:公共电容和自电容。
法律论文写作帮助 以上来自于百度翻译 以下为原文 You can control the force of a LED with a heartbeat width modulator and a high recurrence input clock. On the off chance that the obligation cycle is little then the power of the LED is low, The Cypress Cap Sense piece has two detecting modes, common capacitance and self-capacitance. Law Essay Writing Help |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 01:44 , Processed in 2.241583 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2422
