电子发烧友论坛|
我试图通过单个 SPI 传输从 ADXL313 读取多个字节。我可以读取设备 ID 寄存器。
如何使用多字节读取读取具有顺序地址(a1、a2、a3 ....)的设备的 6 个寄存器(每个 1 字节)?(如何传输虚拟字节,如果需要,如何在帧之间保持 PCS 位断言,以及何时以及如何读取数据(最后或与发送虚拟字节一起)) 我是 SPI 的新手,正在以示例代码作为参考。 如果有人可以提供一些使用多字节读取的伪代码或实际代码,我将不胜感激。 谢谢。 示例代码: void LPSPI0_init_master(void) { /*! * LPSPI0 Clocking: * =================================================== */ PCC->PCCn[PCC_LPSPI0_INDEX] = 0; /* Disable clocks to modify PCS ( default) */ PCC->PCCn[PCC_LPSPI0_INDEX] = PCC_PCCn_PR_MASK /* (default) Peripheral is present. */ |PCC_PCCn_CGC_MASK /* Enable PCS=SPLL_DIV2 (40 MHz func'l clock) */ |PCC_PCCn_PCS(6); /*! * LPSPI0 Initialization: * =================================================== */ LPSPI0->CR = 0x00000000; /* Disable module for configuration */ LPSPI0->IER = 0x00000000; /* Interrupts not used */ LPSPI0->DER = 0x00000000; /* DMA not used */ LPSPI0->CFGR0 = 0x00000000; /* Defaults: */ /* RDM0=0: rec'd data to FIFO as normal */ /* CIRFIFO=0; Circular FIFO is disabled */ /* HRSEL, HRPOL, HREN=0: Host request disabled */ LPSPI0->CFGR1 = LPSPI_CFGR1_MASTER_MASK; /* Configurations: master mode */ /* PCSCFG=0: PCS[3:2] are enabled */ /* OUTCFG=0: Output data retains last value when CS negated */ /* PINCFG=0: SIN is input, SOUT is output */ /* MATCFG=0: Match disabled */ /* PCSPOL=0: PCS is active low */ /* NOSTALL=0: Stall if Tx FIFO empty or Rx FIFO full */ /* AUTOPCS=0: does not apply for master mode */ /* SAMPLE=0: input data sampled on SCK edge */ /* MASTER=1: Master mode */ LPSPI0->TCR = LPSPI_TCR_CPHA_MASK |LPSPI_TCR_CPOL_MASK |LPSPI_TCR_PRESCALE(2) |LPSPI_TCR_PCS(0) |LPSPI_TCR_FRAMESZ(15); /* Transmit cmd: PCS0, 16 bits, prescale func'l clk by 4, etc */ /* CPOL=1: SCK inactive state is high */ /* CPHA=1: Change data on SCK lead'g, capture on trail'g edge */ /* PRESCALE=2: Functional clock divided by 2**2 = 4 */ /* PCS=0: Transfer using PCS0 */ /* LSBF=0: Data is transfered MSB first */ /* BYSW=0: Byte swap disabled */ /* CONT, CONTC=0: Continuous transfer disabled */ /* RXMSK=0: Normal transfer: rx data stored in rx FIFO */ /* TXMSK=0: Normal transfer: data loaded from tx FIFO */ /* WIDTH=0: Single bit transfer */ /* FRAMESZ=15: # bits in frame = 15+1=16 */ LPSPI0->CCR = LPSPI_CCR_SCKPCS(4) |LPSPI_CCR_PCSSCK(4) |LPSPI_CCR_DBT(8) |LPSPI_CCR_SCKDIV(8); /* Clock dividers based on prescaled func'l clk of 100 nsec */ /* SCKPCS=4: SCK to PCS delay = 4+1 = 5 (500 nsec) */ /* PCSSCK=4: PCS to SCK delay = 9+1 = 10 (1 usec) */ /* DBT=8: Delay between Transfers = 8+2 = 10 (1 usec) */ /* SCKDIV=8: SCK divider =8+2 = 10 (1 usec: 1 MHz baud rate) */ LPSPI0->FCR = LPSPI_FCR_TXWATER(3) /* RXWATER=0: Rx flags set when Rx FIFO >0 */ ; /* TXWATER=3: Tx flags set when Tx FIFO <= 3 */ LPSPI0->CR = LPSPI_CR_MEN_MASK |LPSPI_CR_DBGEN_MASK; /* Enable module for operation */ /* DBGEN=1: module enabled in debug mode */ /* DOZEN=0: module enabled in Doze mode */ /* RST=0: Master logic not reset */ /* MEN=1: Module is enabled */ } void LPSPI0_transmit_16bits (uint16_t send) { while((LPSPI0->SR & LPSPI_SR_TDF_MASK)>>LPSPI_SR_TDF_SHIFT==0); /* Wait for Tx FIFO available */ LPSPI0->TDR = send; /* Transmit data */ LPSPI0->SR |= LPSPI_SR_TDF_MASK; /* Clear TDF flag */ } uint16_t LPSPI0_receive_16bits (void) { uint16_t recieve = 0; while((LPSPI0->SR & LPSPI_SR_RDF_MASK)>>LPSPI_SR_RDF_SHIFT==0); /* Wait at least one RxFIFO entry */ recieve= LPSPI0->RDR; /* Read received data */ LPSPI0->SR |= LPSPI_SR_RDF_MASK; /* Clear RDF flag */ return recieve; /* Return received data */ } 读取设备 ID: LPSPI0_transmit_16bits(0xC000); //register at 0x00, first two bits are 1 for 'read' and 'multi-byte read' respectively, can't read multiple bytes though LPSPI0_16bits_read = LPSPI0_receive_16bits(); |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1555浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1207浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
734浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
677浏览 1评论
/9
GMT+8, 2025-12-1 19:01 , Processed in 0.615114 second(s), Total 73, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2559
