您好!
准备先使用例程先测试一下再移植该例程,wifi连接上后,http连接失败,打印信息如下: Code: Select all I (880) wifi:mode : sta (7c:9e:bd:39:0d:7c) I (880) wifi:enable tsf I (890) example_connect: Waiting for IP(s) I (2940) wifi:new:<6,2>, old:<1,0>, ap:<255,255>, sta:<6,2>, prof:1 I (3670) wifi:state: init -> auth (b0) I (3690) wifi:state: auth -> assoc (0) I (3720) wifi:state: assoc -> run (10) I (3730) wifi:connected with E880-IR01, aid = 3, channel 6, 40D, bssid = 54:75:95:2d:6c:26 I (3730) wifi:security: WPA2-PSK, phy: bgn, rssi: -45 I (3730) wifi:pm start, type: 1 W (3750) wifi: I (3800) wifi:AP's beacon interval = 102400 us, DTIM period = 1 I (4670) esp_netif_handlers: example_connect: sta ip: 192.168.1.192, mask: 255.255.255.0, gw: 192.168.1.1 I (4670) example_connect: Got IPv4 event: Interface "example_connect: sta" address: 192.168.1.192 I (5670) example_connect: Got IPv6 event: Interface "example_connect: sta" address: fe80:0000:0000:0000:7e9e:bdff:fe39:0d7c, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (5670) example_connect: Connected to example_connect: sta I (5680) example_connect: - IPv4 address: 192.168.1.192 I (5680) example_connect: - IPv6 address: fe80:0000:0000:0000:7e9e:bdff:fe39:0d7c, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (5690) wifi:Set ps type: 0 E (6060) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x2700 I (6070) esp-tls-mbedtls: Failed to verify peer certificate! E (6070) esp-tls: Failed to open new connection E (6070) TRANSPORT_BASE: Failed to open a new connection E (6080) HTTP_CLIENT: Connection failed, sock < 0 E (6080) esp_https_ota: Failed to open HTTP connection: ESP_ERR_HTTP_CONNECT E (6090) esp_https_ota: Failed to establish HTTP connection E (6100) simple_ota_example: Firmware upgrade failed http server测试是运行正常的,但是之前玩http clent没有用过tls-mbedtls,这个问题该如何处理?请指点迷津,谢谢您! |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 08:01 , Processed in 0.724332 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
718
