电子发烧友论坛|
[14:14:10.888]收←◆ESP-ROM:esp32c6-20220919
Build:Sep 19 2022 rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:2 load:0x40875720,len:0x1804 load:0x4086c410,len:0xe58 load:0x4086e610,len:0x2e20 entry 0x4086c41a [0;32mI (23) boot: ESP-IDF v5.2.1-dirty 2nd stage b [14:14:10.947]收←◆ootloader[0m [0;32mI (24) boot: compile time Jun 12 2024 20:28:23[0m [0;32mI (24) boot: chip revision: v0.0[0m [0;32mI (27) boot.esp32c6: SPI Speed : 80MHz[0m [0;32mI (32) boot.esp32c6: SPI Mode : DIO[0m [0;32mI (36) boot.esp32c6: SPI Flash Size : 8MB[0m [0;32mI (41) boot: Enabling RNG early entropy source...[0m [0;32mI (47) boot: Partition Table:[0m [0;32mI (50) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (57) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m [0;32mI (65) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (72) boot: 2 factory factory app 00 00 00010000 00100000[0m [0;32mI (80) boot: 3 zb_storage Unknown data 01 81 00110000 00004000[0m [0;32mI (87) boot: 4 zb_fct Unknown data 01 81 00114000 00000400[0m [0;32mI (95) boot: End of partition table[0m [0;32mI (9 [14:14:11.025]收←◆9) esp_image: segment 0: paddr=00010020 vaddr=42030020 size=0e148h ( 57672) map[0m [0;32mI (119) esp_image: segment 1: paddr=0001e170 vaddr=40800000 size=01ea8h ( 7848) load[0m [0;32mI (122) esp_image: segment 2: paddr=00020020 vaddr=42000020 size=2e9a0h (190880) map[0m [0;32mI (165) esp_image: segment 3: paddr=0004e9c8 vaddr=40801ea8 size=00e24h ( 3620) load[0m [0;32mI (167) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (168) boot: Disabling RNG early entropy source...[0m [0;32mI (185) cpu_start: Pro cpu up.[0m [0;33mW (193) clk: esp_perip_clk_init() has not been implemented yet[0m [0;32mI (200) cpu_start: Pro cpu start user code[0m [0;32mI (200) cpu_start: cpu freq: 160000000 Hz[0m [0;32mI (200) cpu_start: Application information:[0m [0;32mI (203) cpu_start: Project name: rtthread[0m [0;32mI (208) cpu_start: App version: 999[0m [0;32mI (213) cpu_start: Compile time: Jul 21 2024 14:05:49[0m [0;32mI (219) cpu_start: ELF file SHA256: 9dd6ed6abc0c70de...[0m [0;32mI (225) cpu_start: ESP-IDF: 999[0m [0;32mI (229) cpu_start: Min chi [14:14:11.164]收←◆p rev: v0.0[0m [0;32mI (234) cpu_start: Max chip rev: v0.99 [0m [0;32mI (239) cpu_start: Chip rev: v0.0[0m [0;32mI (244) cpu_start: next do core[0m [0;32mI (251) heap_init: Initializing. RAM available for dynamic allocation:[0m [0;32mI (258) heap_init: At 40830360 len 0004C2B0 (304 KiB): DRAM[0m [0;32mI (264) heap_init: At 4087C610 len 000039F0 (14 KiB): STACK/DRAM[0m [0;32mI (271) heap_init: At 50000020 len 00003FE0 (15 KiB): RTCRAM[0m |
1个回答
从你提供的串口打印信息来看,你的ESP32设备在启动过程中遇到了问题,导致无法正常完成初始化。以下是一些可能的原因和解决方案:
1. **电源问题**:如果电源不稳定或电源电压不足,设备可能会在启动过程中重启。请检查电源线路和电压是否符合设备要求。 2. **固件问题**:你提到编译成功但设备卡在`heap_init`,这可能意味着固件中存在问题。尝试以下操作: - 确保使用的是最新版本的ESP-IDF。 - 检查是否有任何配置错误或不兼容的设置。 - 尝试使用默认配置重新编译并烧录固件。 3. **硬件问题**:如果硬件存在缺陷,如损坏的Flash存储器或不稳定的连接,也可能导致设备无法正常启动。检查硬件连接是否牢固,以及是否有任何可见的损坏。 4. **烧录过程中的问题**:烧录过程中可能出现错误,导致固件损坏。尝试重新烧录固件,并确保烧录过程中没有错误发生。 5. **内存分配问题**:`heap_init`是内存堆初始化的过程,如果内存分配出现问题,可能导致设备无法继续执行。检查你的代码是否有内存泄漏或不正确的内存分配。 6. **看门狗定时器问题**:如果看门狗定时器设置不当,可能会在启动过程中触发重启。检查看门狗定时器的配置。 7. **环境干扰**:电磁干扰或其他环境因素可能影响设备的正常工作。尝试在不同的环境下测试设备。 8. **软件问题**:检查是否有软件bug或逻辑错误导致设备在初始化过程中卡住。 解决这类问题通常需要逐步排查,从硬件检查开始,然后是电源和烧录过程,最后是软件和固件。希望这些建议能帮助你解决问题。如果问题仍然存在,可能需要更详细的错误信息或日志来进一步诊断。 |
只有小组成员才能发言,加入小组>>
453 浏览 0 评论
975 浏览 0 评论
1700 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1357 浏览 1 评论
1248 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1272浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
939浏览 3评论
2371浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2556浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1066浏览 2评论
/9
GMT+8, 2025-12-9 10:05 , Processed in 0.656547 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
760
