我是用的IDF版本是4.4.2
MQTT是拷贝"F:ESP32-S3idfesp-idfexamplesprotocolsmqtttcp"这个例程 OTA是拷贝"F:ESP32-S3idfesp-idfexamplessystemota"这个例程 Code: Select all char *mqtt_username = "RF1_23020901"; memcpy(&mqtt_username[4], serial_number, 8); esp_mqtt_client_config_t mqtt_cfg = { .port=1883, .keepalive=60, .buffer_size=1314, .username = mqtt_username, .client_id= "RF1_23020901", .password = "10902032", .reconnect_timeout_ms = 5000, }; 本来一直正常使用能OTA,但是我现在想根据设备编号去设置MQTT帐号和密码,加了下面这条指令后就不能OTA了 memcpy(&mqtt_username[4], serial_number, 8); 测试发现只要注释掉这条指令就正常,不注释OTA更新一半就重启,下面是重启打印 I (79987) HTTP_CLIENT: Body received in fetch header state, 0x3fceaafd, 31 I (79987) esp_https_ota: Starting OTA... I (79987) esp_https_ota: Writing to partition subtype 17 at offset 0x190000 I (110107) esp_image: segment 0: paddr=00190020 vaddr=3c100020 size=3a900h (239872) map ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x8 (TG1WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT) Saved PC:0x42003a01 0x42003a01: panic_handler at F:/ESP32-S3/idf/esp-idf/components/esp_system/port/panic_handler.c:148 (discriminator 3) 并且重启后还会提示 I (37) boot.esp32s3: Boot SPI Speed : 80MHz I (41) boot.esp32s3: SPI Mode : QIO I (46) boot.esp32s3: SPI Flash Size : 8MB W (51) boot.esp32s3: PRO CPU has been reset by WDT. W (56) boot.esp32s3: APP CPU has been reset by WDT. I (62) boot: Enabling RNG early entropy source... 请问下这是什么原因 |
只有小组成员才能发言,加入小组>>
315浏览 6评论
273浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
263浏览 5评论
270浏览 4评论
247浏览 4评论
GMT+8, 2024-6-29 11:40 , Processed in 0.530978 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
