电子发烧友论坛|
我按照说明操作,VSCODE 无法使用该库:
https ://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/system.html#_CPPv411esp_restartv Code: Select all [Starting] Analyzing sketch 'TESTTEST.ino' [Warning] Output path is not specified. Unable to reuse previously compiled files. Build will be slower. See README. Loading configuration... Initializing packages... Skipping contributed index file C:UsersAdministratorAppDataLocalArduino15master.zip, parsing error occured: com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'PK': was expecting ('true', 'false' or 'null') at [Source: (FileInputStream); line: 1, column: 6] Skipping contributed index file C:UsersAdministratorAppDataLocalArduino15master.zip, parsing error occured: com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'PK': was expecting ('true', 'false' or 'null') at [Source: (FileInputStream); line: 1, column: 6] Preparing development board... Verifying... TEST:6:25: fatal error: periph_ctrl.h: No such file or directory compilation terminated. exit status 1 [Warning] Failed to generate IntelliSense configuration. [Error] Analyzing sketch 'TESTTEST.ino': Exit with code=1 命令没作用Arduino: Rebuild IntelliSense Configuration 如何为 ESP32 实现软重启? |
只有小组成员才能发言,加入小组>>
473 浏览 0 评论
998 浏览 0 评论
1713 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1371 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1289浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2390浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2581浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-15 14:01 , Processed in 0.597479 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
805
