-- Found Git: /usr/bin/git (found version "2.24.3 (Apple Git-128)")
-- The C compiler identification is GNU 8.4.0 -- The CXX compiler identification is GNU 8.4.0 -- The ASM compiler identification is GNU -- Found assembler: /Users/marlon/.espressif/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: /Users/marlon/.espressif/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: /Users/marlon/.espressif/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32 -- Project sdkconfig file /Users/marlon/esp/hello_world/sdkconfig -- Found PythonInterp: /Users/marlon/.espressif/python_env/idf4.4_py3.8_env/bin/python (found version "3.8.11") -- Found Perl: /usr/local/bin/perl (found version "5.34.0") -- App "hello-world" version: 1 -- Adding linker script /Users/marlon/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.ld -- Adding linker script /Users/marlon/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.api.ld -- Adding linker script /Users/marlon/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld -- Adding linker script /Users/marlon/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld -- Adding linker script /Users/marlon/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld -- Adding linker script /Users/marlon/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld -- Adding linker script /Users/marlon/esp/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld -- Adding linker script /Users/marlon/esp/hello_world/build/esp-idf/esp32/esp32_out.ld -- Adding linker script /Users/marlon/esp/esp-idf/components/esp32/ld/esp32.project.ld.in -- Adding linker script /Users/marlon/esp/esp-idf/components/esp32/ld/esp32.peripherals.ld -- Components: app_trace app_update asio bootloader bootloader_support bt cbor cmock coap console cxx driver efuse esp-tls esp32 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_ipc esp_lcd esp_local_ctrl esp_netif esp_phy esp_pm esp_ringbuf esp_rom esp_serial_slave_link esp_system esp_timer esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos hal heap idf_test jsmn json libsodium log lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter tinyusb ulp unity vfs wear_levelling wifi_provisioning wpa_supplicant xtensa -- Component paths: /Users/marlon/esp/esp-idf/components/app_trace /Users/marlon/esp/esp-idf/components/app_update /Users/marlon/esp/esp-idf/components/asio /Users/marlon/esp/esp-idf/components/bootloader /Users/marlon/esp/esp-idf/components/bootloader_support /Users/marlon/esp/esp-idf/components/bt /Users/marlon/esp/esp-idf/components/cbor /Users/marlon/esp/esp-idf/components/cmock /Users/marlon/esp/esp-idf/components/coap /Users/marlon/esp/esp-idf/components/console /Users/marlon/esp/esp-idf/components/cxx /Users/marlon/esp/esp-idf/components/driver /Users/marlon/esp/esp-idf/components/efuse /Users/marlon/esp/esp-idf/components/esp-tls /Users/marlon/esp/esp-idf/components/esp32 /Users/marlon/esp/esp-idf/components/esp_adc_cal /Users/marlon/esp/esp-idf/components/esp_common /Users/marlon/esp/esp-idf/components/esp_eth /Users/marlon/esp/esp-idf/components/esp_event /Users/marlon/esp/esp-idf/components/esp_gdbstub /Users/marlon/esp/esp-idf/components/esp_hid /Users/marlon/esp/esp-idf/components/esp_http_client /Users/marlon/esp/esp-idf/components/esp_http_server /Users/marlon/esp/esp-idf/components/esp_https_ota /Users/marlon/esp/esp-idf/components/esp_https_server /Users/marlon/esp/esp-idf/components/esp_hw_support /Users/marlon/esp/esp-idf/components/esp_ipc /Users/marlon/esp/esp-idf/components/esp_lcd /Users/marlon/esp/esp-idf/components/esp_local_ctrl /Users/marlon/esp/esp-idf/components/esp_netif /Users/marlon/esp/esp-idf/components/esp_phy /Users/marlon/esp/esp-idf/components/esp_pm /Users/marlon/esp/esp-idf/components/esp_ringbuf /Users/marlon/esp/esp-idf/components/esp_rom /Users/marlon/esp/esp-idf/components/esp_serial_slave_link /Users/marlon/esp/esp-idf/components/esp_system /Users/marlon/esp/esp-idf/components/esp_timer /Users/marlon/esp/esp-idf/components/esp_websocket_client /Users/marlon/esp/esp-idf/components/esp_wifi /Users/marlon/esp/esp-idf/components/espcoredump /Users/marlon/esp/esp-idf/components/esptool_py /Users/marlon/esp/esp-idf/components/expat /Users/marlon/esp/esp-idf/components/fatfs /Users/marlon/esp/esp-idf/components/freemodbus /Users/marlon/esp/esp-idf/components/freertos /Users/marlon/esp/esp-idf/components/hal /Users/marlon/esp/esp-idf/components/heap /Users/marlon/esp/esp-idf/components/idf_test /Users/marlon/esp/esp-idf/components/jsmn /Users/marlon/esp/esp-idf/components/json /Users/marlon/esp/esp-idf/components/libsodium /Users/marlon/esp/esp-idf/components/log /Users/marlon/esp/esp-idf/components/lwip /Users/marlon/esp/hello_world/main /Users/marlon/esp/esp-idf/components/mbedtls /Users/marlon/esp/esp-idf/components/mdns /Users/marlon/esp/esp-idf/components/mqtt /Users/marlon/esp/esp-idf/components/newlib /Users/marlon/esp/esp-idf/components/nghttp /Users/marlon/esp/esp-idf/components/nvs_flash /Users/marlon/esp/esp-idf/components/openssl /Users/marlon/esp/esp-idf/components/openthread /Users/marlon/esp/esp-idf/components/partition_table /Users/marlon/esp/esp-idf/components/perfmon /Users/marlon/esp/esp-idf/components/protobuf-c /Users/marlon/esp/esp-idf/components/protocomm /Users/marlon/esp/esp-idf/components/pthread /Users/marlon/esp/esp-idf/components/sdmmc /Users/marlon/esp/esp-idf/components/soc /Users/marlon/esp/esp-idf/components/spi_flash /Users/marlon/esp/esp-idf/components/spiffs /Users/marlon/esp/esp-idf/components/tcp_transport /Users/marlon/esp/esp-idf/components/tcpip_adapter /Users/marlon/esp/esp-idf/components/tinyusb /Users/marlon/esp/esp-idf/components/ulp /Users/marlon/esp/esp-idf/components/unity /Users/marlon/esp/esp-idf/components/vfs /Users/marlon/esp/esp-idf/components/wear_levelling /Users/marlon/esp/esp-idf/components/wifi_provisioning /Users/marlon/esp/esp-idf/components/wpa_supplicant /Users/marlon/esp/esp-idf/components/xtensa -- Configuring done -- Generating done -- Build files have been written to: /Users/marlon/esp/hello_world/build [1/988] Generating project_elf_src_esp32.c [2/988] Generating linker script... [3/988] Generating ../../partition_table/partition-table.bin Partition table binary generated. Contents: ******************************************************************************* # ESP-IDF Partition Table # Name, Type, SubType, Offset, Size, Flags nvs,data,nvs,0x9000,24K, phy_init,data,phy,0xf000,4K, factory,app,factory,0x10000,1M, ******************************************************************************* [4/988] Building C object esp-idf/lwip/CMakeFiles/__idf_lwip.dir/lwip/src/api/netifapi.c.obj FAILED: esp-idf/lwip/CMakeFiles/__idf_lwip.dir/lwip/src/api/netifapi.c.obj /Users/marlon/.espressif/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -Iconfig -I/Users/marlon/esp/esp-idf/components/lwip/include/apps -I/Users/marlon/esp/esp-idf/components/lwip/include/apps/sntp -I/Users/marlon/esp/esp-idf/components/lwip/lwip/src/include -I/Users/marlon/esp/esp-idf/components/lwip/port/esp32/include -I/Users/marlon/esp/esp-idf/components/lwip/port/esp32/include/arch -I/Users/marlon/esp/esp-idf/components/newlib/platform_include -I/Users/marlon/esp/esp-idf/components/freertos/include -I/Users/marlon/esp/esp-idf/components/freertos/port/xtensa/include -I/Users/marlon/esp/esp-idf/components/esp_hw_support/include -I/Users/marlon/esp/esp-idf/components/esp_hw_support/include/soc -I/Users/marlon/esp/esp-idf/components/esp_hw_support/port/esp32/. -I/Users/marlon/esp/esp-idf/components/heap/include -I/Users/marlon/esp/esp-idf/components/log/include -I/Users/marlon/esp/esp-idf/components/soc/include -I/Users/marlon/esp/esp-idf/components/soc/esp32/. -I/Users/marlon/esp/esp-idf/components/soc/esp32/include -I/Users/marlon/esp/esp-idf/components/hal/esp32/include -I/Users/marlon/esp/esp-idf/components/hal/include -I/Users/marlon/esp/esp-idf/components/hal/platform_port/include -I/Users/marlon/esp/esp-idf/components/esp_rom/include -I/Users/marlon/esp/esp-idf/components/esp_rom/esp32 -I/Users/marlon/esp/esp-idf/components/esp_rom/include/esp32 -I/Users/marlon/esp/esp-idf/components/esp_common/include -I/Users/marlon/esp/esp-idf/components/esp_system/include -I/Users/marlon/esp/esp-idf/components/esp_system/port/soc -I/Users/marlon/esp/esp-idf/components/esp_system/port/public_compat -I/Users/marlon/esp/esp-idf/components/esp32/include -I/Users/marlon/esp/esp-idf/components/driver/include -I/Users/marlon/esp/esp-idf/components/driver/esp32/include -I/Users/marlon/esp/esp-idf/components/esp_pm/include -I/Users/marlon/esp/esp-idf/components/esp_ringbuf/include -I/Users/marlon/esp/esp-idf/components/efuse/include -I/Users/marlon/esp/esp-idf/components/efuse/esp32/include -I/Users/marlon/esp/esp-idf/components/xtensa/include -I/Users/marlon/esp/esp-idf/components/xtensa/esp32/include -I/Users/marlon/esp/esp-idf/components/vfs/include -I/Users/marlon/esp/esp-idf/components/esp_wifi/include -I/Users/marlon/esp/esp-idf/components/esp_event/include -I/Users/marlon/esp/esp-idf/components/esp_netif/include -I/Users/marlon/esp/esp-idf/components/esp_eth/include -I/Users/marlon/esp/esp-idf/components/tcpip_adapter/include -I/Users/marlon/esp/esp-idf/components/esp_phy/include -I/Users/marlon/esp/esp-idf/components/esp_phy/esp32/include -I/Users/marlon/esp/esp-idf/components/app_trace/include -I/Users/marlon/esp/esp-idf/components/esp_timer/include -I/Users/marlon/esp/esp-idf/components/nvs_flash/include -I/Users/marlon/esp/esp-idf/components/spi_flash/include -I/Users/marlon/esp/esp-idf/components/mbedtls/port/include -I/Users/marlon/esp/esp-idf/components/mbedtls/mbedtls/include -I/Users/marlon/esp/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fmacro-prefix-map=/Users/marlon/esp/hello_world=. -fmacro-prefix-map=/Users/marlon/esp/esp-idf=IDF -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER="v4.4-dev-1849-g8e3e65a47" -DESP_PLATFORM -Wno-address -MD -MT esp-idf/lwip/CMakeFiles/__idf_lwip.dir/lwip/src/api/netifapi.c.obj -MF esp-idf/lwip/CMakeFiles/__idf_lwip.dir/lwip/src/api/netifapi.c.obj.d -o esp-idf/lwip/CMakeFiles/__idf_lwip.dir/lwip/src/api/netifapi.c.obj -c /Users/marlon/esp/esp-idf/components/lwip/lwip/src/api/netifapi.c In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/stdlib.h:62, from /Users/marlon/esp/esp-idf/components/lwip/port/esp32/include/lwipopts.h:35, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/include/lwip/opt.h:51, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/api/netifapi.c:41: /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/cdefs.h:828:2: error: #error Unsupported architecture #error Unsupported architecture ^~~~~ In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:33, from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/_types.h:27, from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/stdlib.h:64, from /Users/marlon/esp/esp-idf/components/lwip/port/esp32/include/lwipopts.h:35, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/include/lwip/opt.h:51, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/api/netifapi.c:41: /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/machine/_types.h:36:2: error: #error architecture not supported #error architecture not supported ^~~~~ In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/_types.h:27, from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/stdlib.h:64, from /Users/marlon/esp/esp-idf/components/lwip/port/esp32/include/lwipopts.h:35, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/include/lwip/opt.h:51, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/api/netifapi.c:41: /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:55:9: error: unknown type name '__int64_t' typedef __int64_t __darwin_blkcnt_t; /* total blocks */ ^~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:56:9: error: unknown type name '__int32_t' typedef __int32_t __darwin_blksize_t; /* preferred block size */ ^~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:57:9: error: unknown type name '__int32_t' typedef __int32_t __darwin_dev_t; /* dev_t */ ^~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:60:9: error: unknown type name '__uint32_t' typedef __uint32_t __darwin_gid_t; /* [???] process and group IDs */ ^~~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:61:9: error: unknown type name '__uint32_t' typedef __uint32_t __darwin_id_t; /* [XSI] pid_t, uid_t, or gid_t*/ ^~~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:62:9: error: unknown type name '__uint64_t' typedef __uint64_t __darwin_ino64_t; /* [???] Used for 64 bit inodes */ ^~~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:68:9: error: unknown type name '__darwin_natural_t' typedef __darwin_natural_t __darwin_mach_port_name_t; /* Used by mach */ ^~~~~~~~~~~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:70:9: error: unknown type name '__uint16_t' typedef __uint16_t __darwin_mode_t; /* [???] Some file attributes */ ^~~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:71:9: error: unknown type name '__int64_t' typedef __int64_t __darwin_off_t; /* [???] Used for file sizes */ ^~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:72:9: error: unknown type name '__int32_t' typedef __int32_t __darwin_pid_t; /* [???] process and group IDs */ ^~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:73:9: error: unknown type name '__uint32_t' typedef __uint32_t __darwin_sigset_t; /* [???] signal set */ ^~~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:74:9: error: unknown type name '__int32_t' typedef __int32_t __darwin_suseconds_t; /* [???] microseconds */ ^~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:75:9: error: unknown type name '__uint32_t' typedef __uint32_t __darwin_uid_t; /* [???] user IDs */ ^~~~~~~~~~ /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/_types.h:76:9: error: unknown type name '__uint32_t' typedef __uint32_t __darwin_useconds_t; /* [???] microseconds */ ^~~~~~~~~~ In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/signal.h:82, from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/wait.h:109, from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/stdlib.h:66, from /Users/marlon/esp/esp-idf/components/lwip/port/esp32/include/lwipopts.h:35, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/include/lwip/opt.h:51, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/api/netifapi.c:41: /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/machine/signal.h:36:2: error: #error architecture not supported #error architecture not supported ^~~~~ In file included from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/signal.h:146, from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/sys/wait.h:109, from /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/stdlib.h:66, from /Users/marlon/esp/esp-idf/components/lwip/port/esp32/include/lwipopts.h:35, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/include/lwip/opt.h:51, from /Users/marlon/esp/esp-idf/components/lwip/lwip/src/api/netifapi.c:41: /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/include/machine/_mcontext.h:33:2: error: #error architecture not supported |
只有小组成员才能发言,加入小组>>
451浏览 6评论
381浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
361浏览 5评论
365浏览 4评论
339浏览 4评论
GMT+8, 2024-9-15 23:20 , Processed in 0.769549 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
