电子发烧友论坛|
芯片:esp32 s3 r8
idf版本:4.4 开发环境:vscode ------------------------ 问题描述: softAp创建热点日志完成,使用手机和电脑都未找到热点 日志: W (310) spi_flash: Detected size(16384k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (324) sleep: Configure to isolate all GPIO pins in sleep state I (330) sleep: Enable automatic switching of GPIO sleep configuration I (337) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (402) wifi softAP: ESP_WIFI_MODE_AP I (402) pp: pp rom version: e7ae62f I (402) net80211: net80211 rom version: e7ae62f I (412) wifi:wifi driver task: 3fce5990, prio:23, stack:6656, core=0 I (412) system_api: Base MAC address is not set I (412) system_api: read default base MAC address from EFUSE I (442) wifi:wifi firmware version: 63017e0 I (442) wifi:wifi certification version: v7.0 I (442) wifi:config NVS flash: enabled I (442) wifi:config nano formating: disabled I (442) wifi:Init data frame dynamic rx buffer num: 32 I (452) wifi:Init management frame dynamic rx buffer num: 32 I (452) wifi:Init management short buffer num: 32 I (462) wifi:Init dynamic tx buffer num: 32 I (462) wifi:Init static tx FG buffer num: 2 I (462) wifi:Init static rx buffer size: 1600 I (472) wifi:Init static rx buffer num: 10 I (472) wifi:Init dynamic rx buffer num: 32 I (482) wifi_init: rx ba win: 6 I (482) wifi_init: tcpip mbox: 32 I (482) wifi_init: udp mbox: 6 I (492) wifi_init: tcp mbox: 6 I (492) wifi_init: tcp tx win: 5744 I (492) wifi_init: tcp rx win: 5744 I (502) wifi_init: tcp mss: 1440 I (502) wifi_init: WiFi IRAM OP enabled I (512) wifi_init: WiFi RX IRAM OP enabled I (522) phy_init: phy_version 501,94697a2,Apr 7 2022,20:49:08 I (622) wifi:mode : softAP (68:b6:b3:24:f0:d1) I (622) wifi:Total power save buffer number: 16 I (622) wifi:Init max length of beacon: 752/752 I (622) wifi:Init max length of beacon: 752/752 I (632) wifi softAP: wifi_init_softap finished. SSID:abb1 password:12345678qw channel:6 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 09:40 , Processed in 0.620726 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
354
