使用全自动编译Ubuntu固件的时候,执行recovery这一步的时候,ubunturootfs里面的跟文件系统自动被删除了,导致最后打包报错了,请大神帮忙分析是什么原因: zgh@linux:~/rk3399_linux_release_v2.5.1_20210301$ ./build.sh processing option: allff ============================================ TARGET_ARCH=arm64 TARGET_PLATFORM=rk3399 TARGET_UBOOT_CONFIG=firefly-rk3399 TARGET_SPL_CONFIG= TARGET_KERNEL_CONFIG=firefly_linux_defconfig TARGET_KERNEL_DTS=rk3399-firefly-aiojd4-lvds TARGET_TOOLCHAIN_CONFIG= TARGET_BUILDROOT_CONFIG= TARGET_RECOVERY_CONFIG=rockchip_rk3399_recovery TARGET_PCBA_CONFIG=rockchip_rk3399_pcba TARGET_RAMBOOT_CONFIG= ============================================ ============Start building uboot============ TARGET_UBOOT_CONFIG=firefly-rk3399 ========================================= make firefly-rk3399_defconfig -j8configuration written to .configscripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h CFG u-boot.cfg GEN include/autoconf.mk.dep CFG spl/u-boot.cfg CFG tpl/u-boot.cfg GEN include/autoconf.mk GEN spl/include/autoconf.mk GEN tpl/include/autoconf.mk CHK include/config/uboot.release CHK include/generated/timestamp_autogenerated.h CHK include/config.h CFG u-boot.cfg UPD include/generated/timestamp_autogenerated.h CHK include/generated/version_autogenerated.h CHK include/generated/generic-asm-offsets.h CHK include/generated/asm-offsets.h HOSTCC tools/mkenvimage.o HOSTCC tools/fit_image.o HOSTCC tools/image-host.o HOSTCC tools/dumpimage.o HOSTCC tools/mkimage.o HOSTCC tools/rockchip/boot_merger.o HOSTCC tools/rockchip/loaderimage.o HOSTLD tools/mkenvimage HOSTLD tools/loaderimage HOSTLD tools/dumpimage HOSTLD tools/mkimage HOSTLD tools/boot_merger CC arch/arm/cpu/armv8/fwcall.o CC cmd/version.o CC common/main.o LD arch/arm/cpu/armv8/built-in.o LD cmd/built-in.o LD common/built-in.o CC drivers/usb/gadget/f_fastboot.o CC lib/smbios.o CC lib/display_options.o CC lib/efi_loader/helloworld.o LD lib/efi_loader/helloworld.so OBJCOPY lib/efi_loader/helloworld.efi LD drivers/usb/gadget/built-in.o LD lib/built-in.o LD u-boot OBJCOPY u-boot.srec OBJCOPY u-boot-nodtb.bin SYM u-boot.sym start=(/home/zgh/rk3399_linux_release_v2.5.1_20210301/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=(/home/zgh/rk3399_linux_release_v2.5.1_20210301/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 start end make[2]: “arch/arm/dts/rk3399-firefly.dtb”已是最新。 CAT u-boot-dtb.bin MKIMAGE u-boot.img COPY u-boot.dtb MKIMAGE u-boot-dtb.img COPY u-boot.bin ALIGN u-boot.bin CC tpl/common/spl/spl.o CC tpl/arch/arm/mach-rockchip/tpl.o CC spl/arch/arm/cpu/armv8/fwcall.o CC spl/common/spl/spl.o CC tpl/arch/arm/cpu/armv8/fwcall.o LD spl/arch/arm/cpu/armv8/built-in.o LD tpl/arch/arm/cpu/armv8/built-in.o LD tpl/arch/arm/mach-rockchip/built-in.o LD tpl/common/spl/built-in.o LD spl/common/spl/built-in.o COPY spl/u-boot-spl.dtb COPY tpl/u-boot-tpl.dtb CC tpl/lib/display_options.o LD tpl/lib/built-in.o CC spl/lib/display_options.o LD spl/lib/built-in.o LD tpl/u-boot-tpl LD spl/u-boot-spl OBJCOPY tpl/u-boot-tpl-nodtb.bin CAT tpl/u-boot-tpl-dtb.bin COPY tpl/u-boot-tpl.bin OBJCOPY spl/u-boot-spl-nodtb.bin CAT spl/u-boot-spl-dtb.bin COPY spl/u-boot-spl.bin CFGCHK u-boot.cfg load addr is 0x200000! pack input u-boot.bin pack file size: 946352(924 KB) crc = 0x84f82744 uboot version: U-Boot 2017.09-g948c63a14e-dirty #zgh (Nov 24 2021 - 09:53:38) pack uboot.img success! pack uboot okay! Input: u-boot.bin out:trust.img merge success(trust.img) /home/zgh/rk3399_linux_release_v2.5.1_20210301/u-boot pack trust okay! Input: /home/zgh/rk3399_linux_release_v2.5.1_20210301/rkbin/RKTRUST/RK3399TRUST.ini Image Type: Rockchip RK33 (SD/MMC) boot image Init Data Size: 153600 bytes pack loader ok.(rk3399_loader_v1.26.126.bin)(0.00) /home/zgh/rk3399_linux_release_v2.5.1_20210301/u-boot pack rk3399_loader_v1.26.126.bin okay! Input: /home/zgh/rk3399_linux_release_v2.5.1_20210301/rkbin/RKBOOT/RK3399MINIALL.ini Platform RK3399 is build OK, with new .config(make firefly-rk3399_defconfig -j8) Running build_uboot succeeded. Skipping build_loader for missing configs: RK_LOADER_BUILD_TARGET. ============Start building kernel============ TARGET_ARCH =arm64 TARGET_KERNEL_CONFIG =firefly_linux_defconfig TARGET_KERNEL_DTS =rk3399-firefly-aiojd4-lvds TARGET_KERNEL_CONFIG_FRAGMENT = ========================================== /home/zgh/rk3399_linux_release_v2.5.1_20210301 configuration written to .configscripts/kconfig/conf --silentoldconfig Kconfig CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h CHK scripts/mod/devicetable-offsets.h make[1]: “arch/arm64/boot/dts/rockchip/rk3399-firefly-aiojd4-lvds.dtb”已是最新。 CHK include/generated/timeconst.h CHK include/generated/bounds.h CHK include/generated/asm-offsets.h CALL scripts/checksyscalls.sh make[1]: “include/generated/vdso-offsets.h”已是最新。 CHK include/generated/compile.h make[1]: “arch/arm64/boot/Image.lz4”已是最新。 Image: kernel.img is ready CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h CHK scripts/mod/devicetable-offsets.h CHK include/generated/timeconst.h CHK include/generated/bounds.h CHK include/generated/asm-offsets.h CALL scripts/checksyscalls.sh make[2]: “include/generated/vdso-offsets.h”已是最新。 Building modules, stage 2. MODPOST 2 modules Image: resource.img (with rk3399-firefly-aiojd4-lvds.dtb logo.bmp ) is ready Image: boot.img (with Image ramdisk.img resource.img) is ready Image: zboot.img (with Image.lz4 ramdisk.img resource.img) is ready Running build_kernel succeeded. Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN. Skipping build_buildroot for missing configs: RK_CFG_BUILDROOT. buildroot/output//images/rootfs.ext4 not generated? Running build_rootfs succeeded. ==========Start building recovery========== TARGET_RECOVERY_CONFIG=rockchip_rk3399_recovery ======================================== config is rockchip_rk3399_recovery found kernel image Top of tree: /home/zgh/rk3399_linux_release_v2.5.1_20210301 =========================================== #TARGET_BOARD=rk3399 #OUTPUT_DIR=output/rockchip_rk3399_recovery #CONFIG=rockchip_rk3399_recovery_defconfig =========================================== make: Entering directory '/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot' GEN /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/Makefile /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/build/defconfig_hook.py -m /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/configs/rockchip_rk3399_recovery_defconfig /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/tristate.config BR2_CONFIG=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.config HOST_GCC_VERSION="7" BUILD_DIR=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build SKIP_LEGACY= BR2_DEFCONFIG=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/configs/rockchip_rk3399_recovery_defconfig /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/build/buildroot-config/conf --defconfig=/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig Config.in /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:65:warning: override: reassigning to symbol BR2_PACKAGE_UPDATE /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:66:warning: override: reassigning to symbol BR2_PACKAGE_RKSCRIPT /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:70:warning: override: reassigning to symbol BR2_PACKAGE_EXFAT /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:71:warning: override: reassigning to symbol BR2_PACKAGE_EXFAT_UTILS /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.rockchipconfig:73:warning: override: reassigning to symbol BR2_PACKAGE_NTFS_3G configuration written to /home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot/output/rockchip_rk3399_recovery/.configmake: Leaving directory '/home/zgh/rk3399_linux_release_v2.5.1_20210301/buildroot' ====Start build rockchip_rk3399_recovery==== 2021-11-24T09:54:28 >>> Finalizing target directory 2021-11-24T09:54:30 >>> Sanitizing RPATH in target tree 2021-11-24T09:54:31 >>> Copying overlay board/rockchip/rk3399/fs-overlay-64/ 2021-11-24T09:54:31 >>> Copying overlay board/rockchip/common/base 2021-11-24T09:54:31 >>> Copying overlay board/rockchip/common/recovery 2021-11-24T09:54:31 >>> Executing post-build script build/post.sh 2021-11-24T09:54:31 >>> Generating root filesystem image rootfs.cpio 2021-11-24T09:54:34 >>> Generating root filesystem image rootfs.ext2 2021-11-24T09:54:35 >>> Generating root filesystem image rootfs.squashfs 2021-11-24T09:54:36 >>> Generating root filesystem image rootfs.tar Done in 14s log saved on /home/zgh/rk3399_linux_release_v2.5.1_20210301/br.log ====Build rockchip_rk3399_recovery ok!==== pack recovery.img...done. you take 0:17.77 to build recovery ====Build recovery ok!==== Running build_recovery succeeded. Skipping build_ramboot for missing configs: RK_CFG_RAMBOOT. Running build_all succeeded. /usr/bin/fakeroot warning: /home/zgh/rk3399_linux_release_v2.5.1_20210301/ubunturootfs/ubuntu_18.04_arm64_NOGPUVPU_ext4_v2.03-28-g6eebc47_20201204-0948_MINIMAL.img not found! please set correct RK_ROOTFS_IMG in device/rockchip/.BoardConfig.mk create parameter...done. /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/rk3399/parameter-4.19.txt 0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x00020000@0x0003a000(oem),0x00c00000@0x0005a000(rootfs),-@0x00c5a000(userdata:grow) create recovery.img...done. create misc.img...done. Source buildroot/build/envsetup.sh Top of tree: /home/zgh/rk3399_linux_release_v2.5.1_20210301 No available configs for: /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/oem/oem_normal Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/oem.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/oem/oem_normal (auto sized) Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/oem.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/oem/oem_normal with size(17M) 0+0 records in 0+0 records out 0 bytes copied, 2.2429e-05 s, 0.0 kB/s mke2fs 1.44.1 (24-Mar-2018) Discarding device blocks: done Creating filesystem with 17408 1k blocks and 4368 inodes Filesystem UUID: 162e3adb-726f-4163-b474-296bcd70e013 Superblock backups stored on blocks:
Allocating group tables: done Writing inode tables: done Copying files into the device: done Writing superblocks and filesystem accounting information: done tune2fs 1.44.1 (24-Mar-2018) Setting maximal mount count to -1 Setting interval between checks to 0 seconds Source buildroot/build/envsetup.sh Top of tree: /home/zgh/rk3399_linux_release_v2.5.1_20210301 No available configs for: /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/userdata/userdata_normal Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/userdata.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/userdata/userdata_normal (auto sized) Making /home/zgh/rk3399_linux_release_v2.5.1_20210301/rockdev/userdata.img from /home/zgh/rk3399_linux_release_v2.5.1_20210301/device/rockchip/userdata/userdata_normal with size(5M) 0+0 records in 0+0 records out 0 bytes copied, 2.2193e-05 s, 0.0 kB/s mke2fs 1.44.1 (24-Mar-2018) Discarding device blocks: done Creating filesystem with 5120 1k blocks and 1280 inodes Allocating group tables: done Writing inode tables: done Copying files into the device: done Writing superblocks and filesystem accounting information: done tune2fs 1.44.1 (24-Mar-2018) Setting maximal mount count to -1 Setting interval between checks to 0 seconds create uboot.img...done. create idbloader.img...done. create trust.img...done. create loader...done. create boot.img...done. Image: image in rockdev is ready Make image ok! File name is BOARDCONFIGUBUNTU-GPT Rename the file? [N|y]Make update.img start to make update.img... Resize rootfs partition size dumpe2fs 1.44.1 (24-Mar-2018) dumpe2fs: No such file or directory while trying to open /home/zgh/rk3399_linux_release_v2.5.1_20210301/ubunturootfs/Firefly_Ubuntu_18.04.5_LTS_DESKTOP_ext4_202012301242_PYTHON3.5-RKNN-OPENCV.img ./mkupdate.sh: line 37: >>9: syntax error: operand expected (error token is ">>9") Android Firmware Package Tool v1.66 ------ PACKAGE ------ Add file: ./package-file Add file: ./package-file done,offset=0x800,size=0x28a,userspace=0x1 Add file: ./Image/MiniLoaderAll.bin Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x7194e,userspace=0xe4 Add file: ./Image/parameter.txt Add file: ./Image/parameter.txt done,offset=0x73000,size=0x20d,userspace=0x1 Add file: ./Image/trust.img Add file: ./Image/trust.img done,offset=0x73800,size=0x400000,userspace=0x800 Add file: ./Image/uboot.img Add file: ./Image/uboot.img done,offset=0x473800,size=0x400000,userspace=0x800 Add file: ./Image/misc.img Add file: ./Image/misc.img done,offset=0x873800,size=0xc000,userspace=0x18 Add file: ./Image/boot.img Add file: ./Image/boot.img done,offset=0x87f800,size=0x1ea4000,userspace=0x3d48 Add file: ./Image/recovery.img Add file: ./Image/recovery.img done,offset=0x2723800,size=0x1e80800,userspace=0x3d01 Add file: ./Image/rootfs.img Error: ------ FAILED ------ Press any key to quit: ERROR: Running build_updateimg failed! ERROR: exit code 1 from line 1207:
另外BoardConfig的配置内容如下: 1 #!/bin/bash 2 3 # Target arch 4 export RK_ARCH=arm64 5 # Uboot defconfig 6 export RK_UBOOT_DEFCONFIG=firefly-rk3399 7 # Kernel defconfig 8 export RK_KERNEL_DEFCONFIG=firefly_linux_defconfig 9 # Kernel dts 10 export RK_KERNEL_DTS=rk3399-firefly-aiojd4-lvds 11 # boot image type 12 export RK_BOOT_IMG=boot.img 13 # kernel image path 14 export RK_KERNEL_IMG=kernel/arch/arm64/boot/Image 15 # parameter for GPT table 16 export RK_PARAMETER=parameter-4.19.txt 17 # Recovery config 18 export RK_CFG_RECOVERY=rockchip_rk3399_recovery 19 # ramboot config 20 export RK_CFG_RAMBOOT= 21 # Pcba config 22 export RK_CFG_PCBA=rockchip_rk3399_pcba 23 # Build jobs 24 export RK_JOBS=12 25 # target chip 26 export RK_TARGET_PRODUCT=rk3399 27 # Set rootfs type, including ext2 ext4 squashfs 28 export RK_ROOTFS_TYPE=ext4 29 # yocto machine 30 export RK_YOCTO_MACHINE=rockchip-rk3399-sapphire-excavator 31 # rootfs image path 32 export RK_ROOTFS_IMG=ubunturootfs/ubuntu_18.04_arm64_NOGPUVPU_ext4_v2.03-28- g6eebc47_20201204-0948_MINIMAL.img 33 # Set ramboot image type 34 export RK_RAMBOOT_TYPE= 35 # Set oem partition type, including ext2 squashfs 36 export RK_OEM_FS_TYPE=ext2 37 # Set userdata partition type, including ext2, fat 38 export RK_USERDATA_FS_TYPE=ext2 39 #OEM config 40 export RK_OEM_DIR=oem_normal 41 #userdata config 42 export RK_USERDATA_DIR=userdata_normal 43 #misc image 44 export RK_MISC=wipe_all-misc.img 45 #choose enable distro module 46 export RK_DISTRO_MODULE= 47 # Define pre-build script for this board 48 export RK_BOARD_PRE_BUILD_SCRIPT=app-build.sh |
1个回答
按WIKI中关于安装rootfs的说明,安装后就解决了,希望对你有帮助
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
812 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
1994 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
1336 浏览 0 评论
2282 浏览 3 评论
GMT+8, 2024-10-20 13:51 , Processed in 0.616523 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
