1.NCNN编译
NCNN就不描述了,这里采用NCNN最新的发布版ncnn-20200727,buildroot中的mk文件如下 NCNN_VERSION = 20200727 NCNN_SITE = $(call github,Tencent,ncnn,$(NCNN_VERSION)) NCNN_INSTALL_STAGING = YES NCNN_LICENSE = BSD-2-Clause or GPL-2.0+ NCNN_LICENSE_FILES = LICENSE NCNN_CONF_OPTS += -DNCNN_ARM82=OFF $(eval $(cmake-package)) NCNN_ARM82这个要稍微注意下,这里用不到的,但是编译的时候再cmakelists中,检测到arm之后就默认开启了,这里会编译出错. 2.retinaface 这里就直接采用NCNN历程中的retinaface.cpp了,基本都可以直接使用 QSmartNcnn::QSmartNcnn() { retinaface.opt.use_vulkan_compute = true; retinaface.opt.num_threads = 6; // model is converted from // // // the ncnn model // retinaface.load_param("retinaface-R50.param"); // retinaface.load_model("retinaface-R50.bin"); int ret = retinaface.load_param("/root/ncnn-assets/models/mnet.25-opt.param"); qDebug() << "load param " << ret; ret = retinaface.load_model("/root/ncnn-assets/models/mnet.25-opt.bin"); qDebug() << "load bin " << ret; } QSmartNcnn::~QSmartNcnn() { } int QSmartNcnn::detect_face(const cv::Mat &image, QVector { std::vector qDebug() << "need do detect"; if(detect_retinaface(image, faceobjects) < 0) return -1; qDebug() << faceobjects.size(); for(auto &item : faceobjects) { rect.append(QRect(item.rect.x,item.rect.y, item.rect.width,item.rect.height)); } return rect.size(); } int QSmartNcnn::extract_feature(const cv::Mat &image, const QRect &rect, QByteArray &feature) { } void QSmartNcnn::qsort_descent_inplace(std::vector { int i = left; int j = right; float p = faceobjects[(left + right) / 2].prob; while (i <= j) { while (faceobjects.prob > p) i++; while (faceobjects[j].prob < p) j--; if (i <= j) { // swap std::swap(faceobjects, faceobjects[j]); i++; j--; } } #pragma omp parallel sections { #pragma omp section { if (left < j) qsort_descent_inplace(faceobjects, left, j); } #pragma omp section { if (i < right) qsort_descent_inplace(faceobjects, i, right); } } } void QSmartNcnn::qsort_descent_inplace(std::vector { if (faceobjects.empty()) return; qsort_descent_inplace(faceobjects, 0, faceobjects.size() - 1); } void QSmartNcnn::nms_sorted_bboxes(const std::vector { picked.clear(); const int n = faceobjects.size(); std::vector for (int i = 0; i < n; i++) { areas = faceobjects.rect.area(); } for (int i = 0; i < n; i++) { const FaceObject& a = faceobjects; int keep = 1; for (int j = 0; j < (int)picked.size(); j++) { const FaceObject& b = faceobjects[picked[j]]; // intersection over union float inter_area = intersection_area(a, b); float union_area = areas + areas[picked[j]] - inter_area; // float IoU = inter_area / union_area if (inter_area / union_area > nms_threshold) keep = 0; } if (keep) picked.push_back(i); } } // copy from src/layer/proposal.cpp ncnn::Mat QSmartNcnn::generate_anchors(int base_size, const ncnn::Mat& ratios, const ncnn::Mat& scales) { int num_ratio = ratios.w; int num_scale = scales.w; ncnn::Mat anchors; anchors.create(4, num_ratio * num_scale); const float cx = base_size * 0.5f; const float cy = base_size * 0.5f; for (int i = 0; i < num_ratio; i++) { float ar = ratios; int r_w = round(base_size / sqrt(ar)); int r_h = round(r_w * ar); //round(base_size * sqrt(ar)); for (int j = 0; j < num_scale; j++) { float scale = scales[j]; float rs_w = r_w * scale; float rs_h = r_h * scale; float* anchor = anchors.row(i * num_scale + j); anchor[0] = cx - rs_w * 0.5f; anchor[1] = cy - rs_h * 0.5f; anchor[2] = cx + rs_w * 0.5f; anchor[3] = cy + rs_h * 0.5f; } } return anchors; } void QSmartNcnn::generate_proposals(const ncnn::Mat& anchors, int feat_stride, const ncnn::Mat& score_blob, const ncnn::Mat& bbox_blob, const ncnn::Mat& landmark_blob, float prob_threshold, std::vector { int w = score_blob.w; int h = score_blob.h; // generate face proposal from bbox deltas and shifted anchors const int num_anchors = anchors.h; for (int q = 0; q < num_anchors; q++) { const float* anchor = anchors.row(q); const ncnn::Mat score = score_blob.channel(q + num_anchors); const ncnn::Mat bbox = bbox_blob.channel_range(q * 4, 4); const ncnn::Mat landmark = landmark_blob.channel_range(q * 10, 10); // shifted anchor float anchor_y = anchor[1]; float anchor_w = anchor[2] - anchor[0]; float anchor_h = anchor[3] - anchor[1]; for (int i = 0; i < h; i++) { float anchor_x = anchor[0]; for (int j = 0; j < w; j++) { int index = i * w + j; float prob = score[index]; if (prob >= prob_threshold) { // apply center size float dx = bbox.channel(0)[index]; float dy = bbox.channel(1)[index]; float dw = bbox.channel(2)[index]; float dh = bbox.channel(3)[index]; float cx = anchor_x + anchor_w * 0.5f; float cy = anchor_y + anchor_h * 0.5f; float pb_cx = cx + anchor_w * dx; float pb_cy = cy + anchor_h * dy; float pb_w = anchor_w * exp(dw); float pb_h = anchor_h * exp(dh); float x0 = pb_cx - pb_w * 0.5f; float y0 = pb_cy - pb_h * 0.5f; float x1 = pb_cx + pb_w * 0.5f; float y1 = pb_cy + pb_h * 0.5f; FaceObject obj; obj.rect.x = x0; obj.rect.y = y0; obj.rect.width = x1 - x0 + 1; obj.rect.height = y1 - y0 + 1; obj.landmark[0].x = cx + (anchor_w + 1) * landmark.channel(0)[index]; obj.landmark[0].y = cy + (anchor_h + 1) * landmark.channel(1)[index]; obj.landmark[1].x = cx + (anchor_w + 1) * landmark.channel(2)[index]; obj.landmark[1].y = cy + (anchor_h + 1) * landmark.channel(3)[index]; obj.landmark[2].x = cx + (anchor_w + 1) * landmark.channel(4)[index]; obj.landmark[2].y = cy + (anchor_h + 1) * landmark.channel(5)[index]; obj.landmark[3].x = cx + (anchor_w + 1) * landmark.channel(6)[index]; obj.landmark[3].y = cy + (anchor_h + 1) * landmark.channel(7)[index]; obj.landmark[4].x = cx + (anchor_w + 1) * landmark.channel(8)[index]; obj.landmark[4].y = cy + (anchor_h + 1) * landmark.channel(9)[index]; obj.prob = prob; faceobjects.push_back(obj); } anchor_x += feat_stride; } anchor_y += feat_stride; } } } int QSmartNcnn::detect_retinaface(const cv::Mat& bgr, std::vector { const float prob_threshold = 0.8f; const float nms_threshold = 0.4f; int img_w = bgr.cols; int img_h = bgr.rows; ncnn::Mat in = ncnn::Mat::from_pixels(bgr.data, ncnn::Mat::PIXEL_BGR2RGB, img_w, img_h); ncnn::Extractor ex = retinaface.create_extractor(); ex.set_num_threads(6); ex.input("data", in); std::vector // stride 32 { ncnn::Mat score_blob, bbox_blob, landmark_blob; ex.extract("face_rpn_cls_prob_reshape_stride32", score_blob); ex.extract("face_rpn_bbox_pred_stride32", bbox_blob); ex.extract("face_rpn_landmark_pred_stride32", landmark_blob); const int base_size = 16; const int feat_stride = 32; ncnn::Mat ratios(1); ratios[0] = 1.f; ncnn::Mat scales(2); scales[0] = 32.f; scales[1] = 16.f; ncnn::Mat anchors = generate_anchors(base_size, ratios, scales); std::vector generate_proposals(anchors, feat_stride, score_blob, bbox_blob, landmark_blob, prob_threshold, faceobjects32); faceproposals.insert(faceproposals.end(), faceobjects32.begin(), faceobjects32.end()); } // stride 16 { ncnn::Mat score_blob, bbox_blob, landmark_blob; ex.extract("face_rpn_cls_prob_reshape_stride16", score_blob); ex.extract("face_rpn_bbox_pred_stride16", bbox_blob); ex.extract("face_rpn_landmark_pred_stride16", landmark_blob); const int base_size = 16; const int feat_stride = 16; ncnn::Mat ratios(1); ratios[0] = 1.f; ncnn::Mat scales(2); scales[0] = 8.f; scales[1] = 4.f; ncnn::Mat anchors = generate_anchors(base_size, ratios, scales); std::vector generate_proposals(anchors, feat_stride, score_blob, bbox_blob, landmark_blob, prob_threshold, faceobjects16); faceproposals.insert(faceproposals.end(), faceobjects16.begin(), faceobjects16.end()); } // stride 8 { ncnn::Mat score_blob, bbox_blob, landmark_blob; ex.extract("face_rpn_cls_prob_reshape_stride8", score_blob); ex.extract("face_rpn_bbox_pred_stride8", bbox_blob); ex.extract("face_rpn_landmark_pred_stride8", landmark_blob); const int base_size = 16; const int feat_stride = 8; ncnn::Mat ratios(1); ratios[0] = 1.f; ncnn::Mat scales(2); scales[0] = 2.f; scales[1] = 1.f; ncnn::Mat anchors = generate_anchors(base_size, ratios, scales); std::vector generate_proposals(anchors, feat_stride, score_blob, bbox_blob, landmark_blob, prob_threshold, faceobjects8); faceproposals.insert(faceproposals.end(), faceobjects8.begin(), faceobjects8.end()); } // sort all proposals by score from highest to lowest qsort_descent_inplace(faceproposals); // apply nms with nms_threshold std::vector nms_sorted_bboxes(faceproposals, picked, nms_threshold); int face_count = picked.size(); faceobjects.resize(face_count); for (int i = 0; i < face_count; i++) { faceobjects = faceproposals[picked]; // clip to image size float x0 = faceobjects.rect.x; float y0 = faceobjects.rect.y; float x1 = x0 + faceobjects.rect.width; float y1 = y0 + faceobjects.rect.height; x0 = std::max(std::min(x0, (float)img_w - 1), 0.f); y0 = std::max(std::min(y0, (float)img_h - 1), 0.f); x1 = std::max(std::min(x1, (float)img_w - 1), 0.f); y1 = std::max(std::min(y1, (float)img_h - 1), 0.f); faceobjects.rect.x = x0; faceobjects.rect.y = y0; faceobjects.rect.width = x1 - x0; faceobjects.rect.height = y1 - y0; } return 0; } 测试效果很慢,就算开了多线程也是,在720P的输入下,基本职能达到1.5FPS,每次检测都是600MS。这里目前只做了人脸检测,替换之前opencv的级联器。一般来说,这种还要做人脸特征值提取操作,用于和本地对比,做识别操作。 3.输入 输入这里就把前面method哪里修改一下。 cvtColor(img, mat, cv::COLOR_YUV420p2BGR); // cascade.detectMultiScale( mat, faces, // 1.1, 2, 0 // //|CASCADE_FIND_BIGGEST_OBJECT // //|CASCADE_DO_ROUGH_SEARCH // |CASCADE_SCALE_IMAGE, // Size(30, 30) ); method->detect_face(mat,rects); 原作者:嘉木有鱼 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
272 浏览 0 评论
2057 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3839 浏览 0 评论
2350 浏览 1 评论
3586 浏览 3 评论
GMT+8, 2024-10-1 05:23 , Processed in 0.663350 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
