在调试发布版4.1.0的时候,遇到问题:
调用RT_KERNEL_MALLOC object = (struct rt_object *)RT_KERNEL_MALLOC(information->object_size); if (object == RT_NULL) { /* no memory can be allocated */ return RT_NULL; } 对象为空最后,确定是_MEM_MALLOC(_size)返回为空,source insight发现下面_MEM_MOC定义处的宏图发现所有的宏图都没有打开 #if defined(RT_USING_SMALL_MEM_AS_HEAP) static rt_smem_t system_heap; rt_inline void _smem_info(rt_size_t *total, rt_size_t *used, rt_size_t *max_used) { if (total) *total = system_heap->total; if (used) *used = system_heap->used; if (max_used) *max_used = system_heap->max; } #define _MEM_INIT(_name, _start, _size) system_heap = rt_smem_init(_name, _start, _size) #define _MEM_MALLOC(_size) rt_smem_alloc(system_heap, _size) #define _MEM_REALLOC(_ptr, _newsize) rt_smem_realloc(system_heap, _ptr, _newsize) #define _MEM_FREE(_ptr) rt_smem_free(_ptr) #define _MEM_INFO(_total, _used, _max) _smem_info(_total, _used, _max) #elif defined(RT_USING_MEMHEAP_AS_HEAP) static struct rt_memheap system_heap; void *_memheap_alloc(struct rt_memheap *heap, rt_size_t size); void _memheap_free(void *rmem); void *_memheap_realloc(struct rt_memheap *heap, void *rmem, rt_size_t newsize); #define _MEM_INIT(_name, _start, _size) rt_memheap_init(&system_heap, _name, _start, _size) #define _MEM_MALLOC(_size) _memheap_alloc(&system_heap, _size) #define _MEM_REALLOC(_ptr, _newsize) _memheap_realloc(&system_heap, _ptr, _newsize) #define _MEM_FREE(_ptr) _memheap_free(_ptr) #define _MEM_INFO(_total, _used, _max) rt_memheap_info(&system_heap, _total, _used, _max) #elif defined(RT_USING_SLAB_AS_HEAP) static rt_slab_t system_heap; rt_inline void _slab_info(rt_size_t *total, rt_size_t *used, rt_size_t *max_used) { if (total) *total = system_heap->total; if (used) *used = system_heap->used; if (max_used) *max_used = system_heap->max; } #define _MEM_INIT(_name, _start, _size) system_heap = rt_slab_init(_name, _start, _size) #define _MEM_MALLOC(_size) rt_slab_alloc(system_heap, _size) #define _MEM_REALLOC(_ptr, _newsize) rt_slab_realloc(system_heap, _ptr, _newsize) #define _MEM_FREE(_ptr) rt_slab_free(system_heap, _ptr) #define _MEM_INFO _slab_info #else #define _MEM_INIT(...) #define _MEM_MALLOC(...) RT_NULL #define _MEM_REALLOC(...) RT_NULL #define _MEM_FREE(...) #define _MEM_INFO(...) #endif RT_USING_SMALL_MEM_AS_HEAP RT_USING_MEMHEAP_AS_HEAP RT_USING_SLAB_AS_HEAP 应该是宏最终这样被定义#define _MEM_MALLOC(...) RT_NULL为NULL的原因吧。 |
2个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
999 浏览 0 评论
2781 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9368 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2895 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2300 浏览 1 评论
/9
GMT+8, 2025-12-1 20:29 , Processed in 0.750900 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3378
