Platform: RK3399
OS: Android 7.1 Kernel: v4.4.83 系统默认只支持两路Camera,只要将CameraHal中的数量限制改掉就可以了。 另外,有些地方直接用0和1表示Camera通道,也要做相应修改。 注意:因为Android只定义了Front和Back两种Camera属性,所以不能使用默认的APK测试。 Patch: diff --git a/CameraHal/CameraHal_Module.cpp b/CameraHal/CameraHal_Module.cpp index 01afa0d..07380f2 100755 --- a/CameraHal/CameraHal_Module.cpp +++ b/CameraHal/CameraHal_Module.cpp @@ -835,7 +839,7 @@ int camera_get_number_of_cameras(void) fd = open(cam_path, O_RDONLY); if (fd < 0) { LOGE("Open %s failed! strr: %s",cam_path,strerror(errno)); - break; + continue; } LOGD("Open %s success!",cam_path); @@ -849,13 +853,13 @@ int camera_get_number_of_cameras(void) LOGD("Video device(%s): video capture not supported.n",cam_path); } else { rk_cam_total_info* pNewCamInfo = new rk_cam_total_info(); - memset(camInfoTmp[cam_cnt&0x01].device_path,0x00, sizeof(camInfoTmp[cam_cnt&0x01].device_path)); - strcat(camInfoTmp[cam_cnt&0x01].device_path,cam_path); - memset(camInfoTmp[cam_cnt&0x01].fival_list,0x00, sizeof(camInfoTmp[cam_cnt&0x01].fival_list)); - memcpy(camInfoTmp[cam_cnt&0x01].driver,capability.driver, sizeof(camInfoTmp[cam_cnt&0x01].driver)); - camInfoTmp[cam_cnt&0x01].version = capability.version; + memset(camInfoTmp[cam_cnt].device_path,0x00, sizeof(camInfoTmp[cam_cnt].device_path)); + strcat(camInfoTmp[cam_cnt].device_path,cam_path); + memset(camInfoTmp[cam_cnt].fival_list,0x00, sizeof(camInfoTmp[cam_cnt].fival_list)); + memcpy(camInfoTmp[cam_cnt].driver,capability.driver, sizeof(camInfoTmp[cam_cnt].driver)); + camInfoTmp[cam_cnt].version = capability.version; if (strstr((char*)&capability.card[0], "front") != NULL) { - camInfoTmp[cam_cnt&0x01].facing_info.facing = CAMERA_FACING_FRONT; + camInfoTmp[cam_cnt].facing_info.facing = CAMERA_FACING_FRONT; #ifdef LAPTOP } else if (strstr((char*)&capability.card[0], "HP HD") != NULL || strstr((char*)&capability.card[0], "HP IR")) { @@ -866,14 +870,14 @@ int camera_get_number_of_cameras(void) LOGD("Camera %d name: %s", (cam_cnt&0x01), gU***CameraNames[cam_cnt&0x01].string()); #endif } else { - camInfoTmp[cam_cnt&0x01].facing_info.facing = CAMERA_FACING_BACK; + camInfoTmp[cam_cnt].facing_info.facing = CAMERA_FACING_BACK; } ptr = strstr((char*)&capability.card[0],"-"); if (ptr != NULL) { ptr++; - camInfoTmp[cam_cnt&0x01].facing_info.orientation = atoi(ptr); + camInfoTmp[cam_cnt].facing_info.orientation = atoi(ptr); } else { - camInfoTmp[cam_cnt&0x01].facing_info.orientation = 0; + camInfoTmp[cam_cnt].facing_info.orientation = 0; } memset(version,0x00,sizeof(version)); @@ -1207,8 +1211,11 @@ int camera_get_number_of_cameras(void) } #endif - memcpy(&gCamInfos[0], &camInfoTmp[0], sizeof(rk_cam_info_t)); - memcpy(&gCamInfos[1], &camInfoTmp[1], sizeof(rk_cam_info_t)); + for (int i = 0; i < gCamerasNumber; i++) { + memcpy(&gCamInfos, &camInfoTmp, sizeof(rk_cam_info_t)); + } property_get("ro.sf.hwrotation", property, "0"); diff --git a/CameraHal/CameraHal_Module.h b/CameraHal/CameraHal_Module.h index 45c81ec..69be491 100755 --- a/CameraHal/CameraHal_Module.h +++ b/CameraHal/CameraHal_Module.h @@ -11,11 +11,11 @@ using namespace android; #define CAMERA_DEFAULT_PREVIEW_FPS_MIN 8000 //8 fps #define CAMERA_DEFAULT_PREVIEW_FPS_MAX 15000 #endif -#define CAMERAS_SUPPORT_MAX 2 +#define CAMERAS_SUPPORT_MAX 10 #if defined(TARGET_RK3399) - #define CAMERAS_SUPPORTED_SIMUL_MAX 2 + #define CAMERAS_SUPPORTED_SIMUL_MAX 10 #else - #define CAMERAS_SUPPORTED_SIMUL_MAX 1 + #define CAMERAS_SUPPORTED_SIMUL_MAX 10 #endif #define CAMERA_DEVICE_NAME "/dev/video" #define CAMERA_MODULE_NAME "RK29_ICS_CameraHal_Module" |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 18:54 , Processed in 0.540335 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3208
