1、下载opencv源码 我下载的是4.5.0版本的,开发板直接git的话,下载很慢。我选择用电脑下好再传给开发板, 2、安装所需的库,python版本是3.6 sudo apt-get install build-essential cmake git libgtk2.0-dev pkg-config libavcodec-dev libavformat-dev libswscale-dev python3.6-dev python3.6-numpy libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libjasper-dev libdc1394-22-dev sudo apt install gstreamer1.0* sudo apt install ubuntu-restricted-extras sudo apt install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev 3、解压编译 cd opencv-4.5.0 mkdir build cd build # python版本改成对应的,找到python和numpy的路径,和opencv关联起来 export PY_NAME=$(python3.6 -c 'from sys import version_info as v; print("python%d.%d" % v[:2])') export PY_NUMPY_DIR=$(python3.6 -c 'import os.path, numpy.core; print(os.path.dirname(numpy.core.__file__))') cmake -DCMAKE_BUILD_TYPE=RELEASE -DCMAKE_INSTALL_PREFIX=/usr/local -DPYTHON_DEFAULT_EXECUTABLE=$(which python3.6) -DPYTHON3_EXECUTABLE=$(which python3.6) -D WITH_GSTREAMER = ON #这个一定要打开 -DPYTHON3_INCLUDE_DIR=/usr/include/$PY_NAME -DPYTHON3_INCLUDE_DIR2=/usr/include/aarch64-linux-gnu/$PY_NAME -DPYTHON3_LIBRARY=/usr/lib/aarch64-linux-gnu/lib$PY_NAME.so -DPYTHON3_NUMPY_INCLUDE_DIRS=/usr/lib/$PY_NAME/dist-packages/numpy/core/include/ -DBUILD_DOCS=OFF -DBUILD_EXAMPLES=OFF -DBUILD_TESTS=OFF -DBUILD_PERF_TESTS=OFF .. build完成后 make -j6 #根据芯片的核数 sudo make install 然后就是等待编译结束,大概一个小时左右,编译期间可能会报内存不足,先是报下面这个错误,然后往上翻 使用swap创建临时分区 #count的大小就是增加的swap空间的大小,64M是块大小,所以空间大小是bs*count=1536MB sudo dd if=/dev/zero of=/swapfile bs=64M count=24 #把刚才空间格式化成swap格式 sudo mkswap /swapfile #该目录权限,不改的话,在下一步启动时会报“swapon: /swapfile: insecure permissions 0644, 0600 suggested.”错误 chmod 0600 /swapfile #使用刚才创建的swap空间 sudo swapon /swapfile #编译完成把临时空间关闭 swapoff -a #详细的用法可以:swapoff --help #查看当前内存使用情况:free -m 4、Python 通过Gstreamer调用摄像头 官方给的文档是通过shell脚本来访问的 $ gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw, format=NV12, width=640, height=480, framerate=30/1 ! waylandsink 在opencv中构建gstreamer的pipeline需要调整为: 'v4l2src device=/dev/video1 ! video/x-raw, format=NV12, width=640, height=480, framerate=30/1 ! videoconvert ! appsink' 测试代码 import numpy as np import cv2 as cv import os import time cap = cv.VideoCapture('v4l2src device=/dev/video1 ! video/x-raw, format=NV12, width=640, height=480, framerate=30/1 ! videoconvert ! appsink', cv.CAP_GSTREAMER) if not cap.isOpened(): print("Cannot capture from camera. Exiting.") os._exit() last_time = time.time() while(True): ret, frame = cap.read() this_time = time.time() print (str((this_time-last_time)*1000)+'ms') last_time = this_time; cv.imshow('frame', frame) if cv.waitKey(1) & 0xFF == ord('q'): break cap.release() cv.destroyAllWindows() 最终效果图 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 01:57 , Processed in 2.897006 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2633
