电子发烧友论坛|
uart2axi_master_intf程序源码:
/*************************************************** * Module Name : uart2axi_master_intf * Engineer : Huangruigui * Target Device : * Tool versions : * Create Date : * Revision : v1.0 * Description : **************************************************/ module uart2axi_master_intf #( parameter M_AXI_ADDR_WIDTH = 8'd32, parameter M_AXI_DATA_WIDTH = 8'd32, parameter RX_TOTAL_BYTE = 8'd9, // 串口接收到9byte数据开始工作 parameter TX_TOTAL_BYTE = 8'd4 // 串口发送4byte数据给上位机 )( // Global Clock Signal input wire m_axi_aclk, // 模块基准时钟,100MHz input wire m_axi_aresetn, // 模块复位信号,低电平有效 // Master Write Addr Interface output reg m_axi_awvalid, input wire m_axi_awready, output wire [M_AXI_ADDR_WIDTH-1:0] m_axi_awaddr, // Master Write Date Interface output reg m_axi_wvalid, input wire m_axi_wready, output wire [M_AXI_DATA_WIDTH-1:0] m_axi_wdata, output wire [M_AXI_DATA_WIDTH/8-1:0] m_axi_wstrb, // Master Read Addr Interface output reg m_axi_arvalid, input wire m_axi_arready, output wire [M_AXI_ADDR_WIDTH-1:0] m_axi_araddr, // Master Read Date Interface output wire m_axi_rready, input wire m_axi_rvalid, input wire [M_AXI_DATA_WIDTH-1:0] m_axi_rdata, input wire [1:0] m_axi_rresp, // Master Response Interface output reg m_axi_bready, input wire m_axi_bvalid, input wire [1:0] m_axi_bresp, input wire uart_write, input wire [M_AXI_ADDR_WIDTH-1:0] uart_write_addr, input wire [M_AXI_DATA_WIDTH-1:0] uart_write_data, input wire uart_read, input wire [M_AXI_ADDR_WIDTH-1:0] uart_read_addr, output reg uart_tx_en, output reg [M_AXI_DATA_WIDTH-1:0] uart_tx_data ); //parameter define localparam OKAY = 2'b00, EXOKAY = 2'b01, SLVERR = 2'b10, DECERR = 2'b11; assign m_axi_wstrb = {(M_AXI_DATA_WIDTH/8){1'b1}}; assign m_axi_wdata = uart_write_data; assign m_axi_awaddr = uart_write_addr; assign m_axi_araddr = uart_read_addr; assign m_axi_rready = 1; always@(posedge m_axi_aclk or negedge m_axi_aresetn) begin if(!m_axi_aresetn) m_axi_bready <= 0; else if(m_axi_wvalid & m_axi_wready) m_axi_bready <= 1; else if(m_axi_bvalid & (m_axi_bresp == OKAY)) m_axi_bready <= 0; end always@(posedge m_axi_aclk or negedge m_axi_aresetn) begin if(!m_axi_aresetn) m_axi_awvalid <= 0; else if(uart_write) m_axi_awvalid <= 1; else if(m_axi_awready) m_axi_awvalid <= 0; end always@(posedge m_axi_aclk or negedge m_axi_aresetn) begin if(!m_axi_aresetn) m_axi_wvalid <= 0; else if(m_axi_awvalid & m_axi_awready) m_axi_wvalid <= 1; else if(m_axi_wready) m_axi_wvalid <= 0; end always@(posedge m_axi_aclk or negedge m_axi_aresetn) begin if(!m_axi_aresetn) m_axi_arvalid <= 0; else if(uart_read) m_axi_arvalid <= 1; else if(m_axi_arready) m_axi_arvalid <= 0; end always@(posedge m_axi_aclk or negedge m_axi_aresetn) begin if(!m_axi_aresetn) begin uart_tx_en <= 0; uart_tx_data <= 0; end else if(m_axi_rvalid & m_axi_rready) begin uart_tx_en <= 1; uart_tx_data <= m_axi_rdata; end else if(uart_write) begin uart_tx_en <= 1; uart_tx_data <= uart_write_data; // 将写数据发送回上位机作为响应 end else uart_tx_en <= 0; end endmodule //*****************文件结束************************** 整个模块测试文件 /*************************************************** * Module Name : uart2axi_master_tb * Engineer : Huangruigui * Target Device : * Tool versions : * Create Date : * Revision : v1.0 * Description : **************************************************/ `timescale 1ns/1ns module uart2axi_master_tb; // parameter define parameter M_AXI_ADDR_WIDTH = 8'd32; parameter M_AXI_DATA_WIDTH = 8'd32; parameter BAUD_SET = 16'd10416; // 波特率设置,默认9600 parameter RX_TOTAL_BYTE = 8'd9; // 串口接收到9byte数据开始工作 parameter TX_TOTAL_BYTE = 8'd4; // 串口发送4byte数据给上位机 parameter WRITE_BIT = 5'd1; // 设置最高位1为写操作 parameter READ_BIT = 5'd2; reg sys_clk; reg sys_rst_n; reg tx_en; reg [7:0] tx_data; wire tx_done ; wire uart_tx ; wire m_axi_awvalid; reg m_axi_awready; wire [M_AXI_ADDR_WIDTH-1:0] m_axi_awaddr; wire m_axi_wvalid; reg m_axi_wready; wire [M_AXI_DATA_WIDTH-1:0] m_axi_wdata; wire [M_AXI_DATA_WIDTH/8-1:0] m_axi_wstrb; wire m_axi_arvalid; reg m_axi_arready; wire [M_AXI_ADDR_WIDTH-1:0] m_axi_araddr; wire m_axi_rready; reg m_axi_rvalid; reg [M_AXI_DATA_WIDTH-1:0] m_axi_rdata; reg [1:0] m_axi_rresp; wire m_axi_bready; reg m_axi_bvalid; reg [1:0] m_axi_bresp; initial sys_clk = 1; always #5 sys_clk = ~sys_clk; initial begin sys_rst_n = 0; tx_en = 0; tx_data = 0; m_axi_awready = 1; m_axi_wready = 1; m_axi_arready = 1; m_axi_rresp = 2'b00; m_axi_rvalid = 0; m_axi_rdata = 0; m_axi_bvalid = 1; m_axi_bresp = 2'b00; #201; sys_rst_n = 1; #20; @(posedge sys_clk) #100; tx_data = 0; // 测试写操作 repeat(9) begin tx_en = 1; tx_data = tx_data + 1; #10; tx_en = 0; wait(tx_done); #100; end #100; if((m_axi_awaddr == 32'h02030405) & (m_axi_wdata == 32'h06070809)) $display("test success"); else $display("test fail"); #1000; tx_data = 1; // 测试读操作 repeat(9) begin tx_en = 1; tx_data = tx_data + 1; #10; tx_en = 0; wait(tx_done); #100; end if(m_axi_araddr == 32'h03040506) $display("test success"); else $display("test fail"); #100; m_axi_rvalid = 1; // 测试串口发送 m_axi_rdata = 32'h12345678; #10; m_axi_rvalid = 0; wait(uart2axi_master.uart2axi_master_logic.byte_matching.tx_conduct.uart_tx_done); #1000; $stop; end uart_tx_logic #( .BAUD_SET ( BAUD_SET ) )uart_tx_logic( .sys_clk ( sys_clk ), .sys_rst_n ( sys_rst_n ), .tx_en ( tx_en ), .tx_data ( tx_data ), .tx_done ( tx_done ), .uart_tx ( uart_tx ) ); uart2axi_master #( .M_AXI_ADDR_WIDTH ( M_AXI_ADDR_WIDTH), .M_AXI_DATA_WIDTH ( M_AXI_DATA_WIDTH), .RX_TOTAL_BYTE ( RX_TOTAL_BYTE ), .TX_TOTAL_BYTE ( TX_TOTAL_BYTE ) )uart2axi_master( .m_axi_aclk ( sys_clk ), .m_axi_aresetn ( sys_rst_n ), .m_axi_awvalid ( m_axi_awvalid ), .m_axi_awready ( m_axi_awready ), .m_axi_awaddr ( m_axi_awaddr ), .m_axi_wvalid ( m_axi_wvalid ), .m_axi_wready ( m_axi_wready ), .m_axi_wdata ( m_axi_wdata ), .m_axi_wstrb ( m_axi_wstrb ), .m_axi_arvalid ( m_axi_arvalid ), .m_axi_arready ( m_axi_arready ), .m_axi_araddr ( m_axi_araddr ), .m_axi_rready ( m_axi_rready ), .m_axi_rvalid ( m_axi_rvalid ), .m_axi_rdata ( m_axi_rdata ), .m_axi_rresp ( m_axi_rresp ), .m_axi_bready ( m_axi_bready ), .m_axi_bvalid ( m_axi_bvalid ), .m_axi_bresp ( m_axi_bresp ), .UART_RX ( uart_tx ), .UART_TX ( ) ); endmodule //*****************文件结束************************* |
只有小组成员才能发言,加入小组>>
1599 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4738 浏览 0 评论
4229 浏览 9 评论
3822 浏览 16 评论
4398 浏览 1 评论
4210浏览 3评论
2379浏览 0评论
3393浏览 0评论
1158浏览 0评论
2843浏览 0评论
/9
GMT+8, 2025-12-1 23:54 , Processed in 0.653587 second(s), Total 74, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
557
