电子发烧友论坛|
本章介绍STM32F1的SPI功能,利用STM32F1自带的SPI来实现对外部FLASH(W25Q128)的读写,并将结果显示在TFTLCD模块上。
main函数 #include "led.h" #include "delay.h" #include "key.h" #include "sys.h" #include "lcd.h" #include "usart.h" #include "w25qxx.h" //要写入到W25Q64的字符串数组 const u8 TEXT_Buffer[]={"WarShipSTM32 SPI TEST"}; #define SIZE sizeof(TEXT_Buffer) int main(void) { u8 key; u16 i=0; u8 datatemp[SIZE]; u32 FLASH_SIZE; delay_init(); //延时函数初始化 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级 uart_init(115200); //串口初始化为115200 LED_Init(); //初始化与LED连接的硬件接口 LCD_Init(); //初始化LCD KEY_Init(); //按键初始化 W25QXX_Init(); //W25QXX初始化 POINT_COLOR=RED;//设置字体为红色 LCD_ShowString(30,50,200,16,16,"WarShip STM32"); LCD_ShowString(30,70,200,16,16,"SPI TEST"); LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK"); LCD_ShowString(30,110,200,16,16,"2015/1/15"); LCD_ShowString(30,130,200,16,16,"KEY1:Write KEY0:Read"); //显示提示信息 while(W25QXX_ReadID()!=W25Q128) //检测不到W25Q128 { LCD_ShowString(30,150,200,16,16,"W25Q128 Check Failed!"); delay_ms(500); LCD_ShowString(30,150,200,16,16,"Please Check! "); delay_ms(500); LED0=!LED0;//DS0闪烁 } LCD_ShowString(30,150,200,16,16,"W25Q128 Ready!"); FLASH_SIZE=128*1024*1024; //FLASH 大小为16M字节 POINT_COLOR=BLUE;//设置字体为蓝色 while(1) { key=KEY_Scan(0); if(key==KEY1_PRES) //KEY1按下,写入W25QXX { LCD_Fill(0,170,239,319,WHITE);//清除半屏 LCD_ShowString(30,170,200,16,16,"Start Write W25Q128...."); W25QXX_Write((u8*)TEXT_Buffer,FLASH_SIZE-100,SIZE); //从倒数第100个地址处开始,写入SIZE长度的数据 LCD_ShowString(30,170,200,16,16,"W25Q128 Write Finished!"); //提示传送完成 } if(key==KEY0_PRES) //KEY0按下,读取字符串并显示 { LCD_ShowString(30,170,200,16,16,"Start Read W25Q128.... "); W25QXX_Read(datatemp,FLASH_SIZE-100,SIZE); //从倒数第100个地址处开始,读出SIZE个字节 LCD_ShowString(30,170,200,16,16,"The Data Readed Is: "); //提示传送完成 LCD_ShowString(30,190,200,16,16,datatemp);//显示读到的字符串 } i++; delay_ms(10); if(i==20) { LED0=!LED0;//提示系统正在运行 i=0; } } } spi.c函数 #include "spi.h" //以下是SPI模块的初始化代码,配置成主机模式,访问SD Card/W25Q64/NRF24L01 //SPI口初始化 //这里针是对SPI2的初始化 void SPI2_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE );//PORTB时钟使能 RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE );//SPI2时钟使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //PB13/14/15复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB GPIO_SetBits(GPIOB,GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15); //PB13/14/15上拉 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平 SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为256 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI2, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI2, ENABLE); //使能SPI2外设 SPI2_ReadWriteByte(0xff);//启动传输 } //SPI 速度设置函数 //SpeedSet: //SPI_BaudRatePrescaler_2 2分频 //SPI_BaudRatePrescaler_8 8分频 //SPI_BaudRatePrescaler_16 16分频 //SPI_BaudRatePrescaler_256 256分频 void SPI2_SetSpeed(u8 SPI_BaudRatePrescaler) { assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler)); SPI2->CR1&=0XFFC7; SPI2->CR1|=SPI_BaudRatePrescaler; //设置SPI2速度 SPI_Cmd(SPI2,ENABLE); } //SPIx 读写一个字节 //TxData:要写入的字节 //返回值:读取到的字节 u8 SPI2_ReadWriteByte(u8 TxData) { u8 retry=0; while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位 { retry++; if(retry>200)return 0; } SPI_I2S_SendData(SPI2, TxData); //通过外设SPIx发送一个数据 retry=0; while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位 { retry++; if(retry>200)return 0; } return SPI_I2S_ReceiveData(SPI2); //返回通过SPIx最近接收的数据 } |
w25q128.c函数
#include "w25qxx.h" #include "spi.h" #include "delay.h" #include "usart.h" u16 W25QXX_TYPE=W25Q128; //默认是W25Q128 //4Kbytes为一个Sector扇区 //16个扇区为1个Block块 //W25Q128 容量为16M字节,共有128个Block,4096个Sector //初始化SPI FLASH的IO口 void W25QXX_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//PORTB时钟使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; // PB12 推挽 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_SetBits(GPIOB,GPIO_Pin_12); W25QXX_CS=1; //SPI FLASH不选中 SPI2_Init(); //初始化SPI SPI2_SetSpeed(SPI_BaudRatePrescaler_2);//设置为18M时钟,高速模式 W25QXX_TYPE=W25QXX_ReadID();//读取FLASH ID. } //读取W25QXX的状态寄存器 //BIT7 6 5 4 3 2 1 0 //SPR RV TB BP2 BP1 BP0 WEL BUSY //SPR:默认0,状态寄存器保护位,配合WP使用 //TB,BP2,BP1,BP0:FLASH区域写保护设置 //WEL:写使能锁定 //BUSY:忙标记位(1,忙;0,空闲) //默认:0x00 u8 W25QXX_ReadSR(void) { u8 byte=0; W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_ReadStatusReg); //发送读取状态寄存器命令 byte=SPI2_ReadWriteByte(0Xff); //读取一个字节 W25QXX_CS=1; //取消片选 return byte; } //写W25QXX状态寄存器 //只有SPR,TB,BP2,BP1,BP0(bit 7,5,4,3,2)可以写!!! void W25QXX_Write_SR(u8 sr) { W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_WriteStatusReg);//发送写取状态寄存器命令 SPI2_ReadWriteByte(sr); //写入一个字节 W25QXX_CS=1; //取消片选 } //W25QXX写使能 //将WEL置位 void W25QXX_Write_Enable(void) { W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_WriteEnable); //发送写使能 W25QXX_CS=1; //取消片选 } //W25QXX写禁止 //将WEL清零 void W25QXX_Write_Disable(void) { W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_WriteDisable); //发送写禁止指令 W25QXX_CS=1; //取消片选 } //读取芯片ID //返回值如下: //0XEF13,表示芯片型号为W25Q80 //0XEF14,表示芯片型号为W25Q16 //0XEF15,表示芯片型号为W25Q32 //0XEF16,表示芯片型号为W25Q64 //0XEF17,表示芯片型号为W25Q128 u16 W25QXX_ReadID(void) { u16 Temp = 0; W25QXX_CS=0; SPI2_ReadWriteByte(0x90);//发送读取ID命令 SPI2_ReadWriteByte(0x00); SPI2_ReadWriteByte(0x00); SPI2_ReadWriteByte(0x00); Temp|=SPI2_ReadWriteByte(0xFF)<<8; Temp|=SPI2_ReadWriteByte(0xFF); W25QXX_CS=1; return Temp; } //读取SPI FLASH //在指定地址开始读取指定长度的数据 //pBuffer:数据存储区 //ReadAddr:开始读取的地址(24bit) //NumByteToRead:要读取的字节数(最大65535) void W25QXX_Read(u8* pBuffer,u32 ReadAddr,u16 NumByteToRead) { u16 i; W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_ReadData); //发送读取命令 SPI2_ReadWriteByte((u8)((ReadAddr)>>16)); //发送24bit地址 SPI2_ReadWriteByte((u8)((ReadAddr)>>8)); SPI2_ReadWriteByte((u8)ReadAddr); for(i=0;i pBuffer=SPI2_ReadWriteByte(0XFF); //循环读数 } W25QXX_CS=1; } //SPI在一页(0~65535)内写入少于256个字节的数据 //在指定地址开始写入最大256字节的数据 //pBuffer:数据存储区 //WriteAddr:开始写入的地址(24bit) //NumByteToWrite:要写入的字节数(最大256),该数不应该超过该页的剩余字节数!!! void W25QXX_Write_Page(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite) { u16 i; W25QXX_Write_Enable(); //SET WEL W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_PageProgram); //发送写页命令 SPI2_ReadWriteByte((u8)((WriteAddr)>>16)); //发送24bit地址 SPI2_ReadWriteByte((u8)((WriteAddr)>>8)); SPI2_ReadWriteByte((u8)WriteAddr); for(i=0;i W25QXX_CS=1; //取消片选 W25QXX_Wait_Busy(); //等待写入结束 } //无检验写SPI FLASH //必须确保所写的地址范围内的数据全部为0XFF,否则在非0XFF处写入的数据将失败! //具有自动换页功能 //在指定地址开始写入指定长度的数据,但是要确保地址不越界! //pBuffer:数据存储区 //WriteAddr:开始写入的地址(24bit) //NumByteToWrite:要写入的字节数(最大65535) //CHECK OK void W25QXX_Write_NoCheck(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite) { u16 pageremain; pageremain=256-WriteAddr%256; //单页剩余的字节数 if(NumByteToWrite<=pageremain)pageremain=NumByteToWrite;//不大于256个字节 while(1) { W25QXX_Write_Page(pBuffer,WriteAddr,pageremain); if(NumByteToWrite==pageremain)break;//写入结束了 else //NumByteToWrite>pageremain { pBuffer+=pageremain; WriteAddr+=pageremain; NumByteToWrite-=pageremain; //减去已经写入了的字节数 if(NumByteToWrite>256)pageremain=256; //一次可以写入256个字节 else pageremain=NumByteToWrite; //不够256个字节了 } }; } //写SPI FLASH //在指定地址开始写入指定长度的数据 //该函数带擦除操作! //pBuffer:数据存储区 //WriteAddr:开始写入的地址(24bit) //NumByteToWrite:要写入的字节数(最大65535) u8 W25QXX_BUFFER[4096]; void W25QXX_Write(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite) { u32 secpos; u16 secoff; u16 secremain; u16 i; u8 * W25QXX_BUF; W25QXX_BUF=W25QXX_BUFFER; secpos=WriteAddr/4096;//扇区地址 secoff=WriteAddr%4096;//在扇区内的偏移 secremain=4096-secoff;//扇区剩余空间大小 //printf("ad:%X,nb:%Xrn",WriteAddr,NumByteToWrite);//测试用 if(NumByteToWrite<=secremain)secremain=NumByteToWrite;//不大于4096个字节 while(1) { W25QXX_Read(W25QXX_BUF,secpos*4096,4096);//读出整个扇区的内容 for(i=0;i if(W25QXX_BUF[secoff+i]!=0XFF)break;//需要擦除 } if(i W25QXX_Erase_Sector(secpos); //擦除这个扇区 for(i=0;i W25QXX_BUF[i+secoff]=pBuffer; } W25QXX_Write_NoCheck(W25QXX_BUF,secpos*4096,4096);//写入整个扇区 }else W25QXX_Write_NoCheck(pBuffer,WriteAddr,secremain);//写已经擦除了的,直接写入扇区剩余区间. if(NumByteToWrite==secremain)break;//写入结束了 else//写入未结束 { secpos++;//扇区地址增1 secoff=0;//偏移位置为0 pBuffer+=secremain; //指针偏移 WriteAddr+=secremain; //写地址偏移 NumByteToWrite-=secremain; //字节数递减 if(NumByteToWrite>4096)secremain=4096;//下一个扇区还是写不完 else secremain=NumByteToWrite; //下一个扇区可以写完了 } }; } //擦除整个芯片 //等待时间超长... void W25QXX_Erase_Chip(void) { W25QXX_Write_Enable(); //SET WEL W25QXX_Wait_Busy(); W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_ChipErase); //发送片擦除命令 W25QXX_CS=1; //取消片选 W25QXX_Wait_Busy(); //等待芯片擦除结束 } //擦除一个扇区 //Dst_Addr:扇区地址 根据实际容量设置 //擦除一个山区的最少时间:150ms void W25QXX_Erase_Sector(u32 Dst_Addr) { //监视falsh擦除情况,测试用 printf("fe:%xrn",Dst_Addr); Dst_Addr*=4096; W25QXX_Write_Enable(); //SET WEL W25QXX_Wait_Busy(); W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_SectorErase); //发送扇区擦除指令 SPI2_ReadWriteByte((u8)((Dst_Addr)>>16)); //发送24bit地址 SPI2_ReadWriteByte((u8)((Dst_Addr)>>8)); SPI2_ReadWriteByte((u8)Dst_Addr); W25QXX_CS=1; //取消片选 W25QXX_Wait_Busy(); //等待擦除完成 } //等待空闲 void W25QXX_Wait_Busy(void) { while((W25QXX_ReadSR()&0x01)==0x01); // 等待BUSY位清空 } //进入掉电模式 void W25QXX_PowerDown(void) { W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_PowerDown); //发送掉电命令 W25QXX_CS=1; //取消片选 delay_us(3); //等待TPD } //唤醒 void W25QXX_WAKEUP(void) { W25QXX_CS=0; //使能器件 SPI2_ReadWriteByte(W25X_ReleasePowerDown); //send W25X_PowerDown command 0xAB W25QXX_CS=1; //取消片选 delay_us(3); //等待TRES1 } w25q128.h #ifndef __FLASH_H #define __FLASH_H #include "sys.h" //W25X系列/Q系列芯片列表 //W25Q80 ID 0XEF13 //W25Q16 ID 0XEF14 //W25Q32 ID 0XEF15 //W25Q64 ID 0XEF16 //W25Q128 ID 0XEF17 #define W25Q80 0XEF13 #define W25Q16 0XEF14 #define W25Q32 0XEF15 #define W25Q64 0XEF16 #define W25Q128 0XEF17 extern u16 W25QXX_TYPE; //定义W25QXX芯片型号 #define W25QXX_CS PBout(12) //W25QXX的片选信号 //指令表 #define W25X_WriteEnable 0x06 #define W25X_WriteDisable 0x04 #define W25X_ReadStatusReg 0x05 #define W25X_WriteStatusReg 0x01 #define W25X_ReadData 0x03 #define W25X_FastReadData 0x0B #define W25X_FastReadDual 0x3B #define W25X_PageProgram 0x02 #define W25X_BlockErase 0xD8 #define W25X_SectorErase 0x20 #define W25X_ChipErase 0xC7 #define W25X_PowerDown 0xB9 #define W25X_ReleasePowerDown 0xAB #define W25X_DeviceID 0xAB #define W25X_ManufactDeviceID 0x90 #define W25X_JedecDeviceID 0x9F void W25QXX_Init(void); u16 W25QXX_ReadID(void); //读取FLASH ID u8 W25QXX_ReadSR(void); //读取状态寄存器 void W25QXX_Write_SR(u8 sr); //写状态寄存器 void W25QXX_Write_Enable(void); //写使能 void W25QXX_Write_Disable(void); //写保护 void W25QXX_Write_NoCheck(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite); void W25QXX_Read(u8* pBuffer,u32 ReadAddr,u16 NumByteToRead); //读取flash void W25QXX_Write(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite);//写入flash void W25QXX_Erase_Chip(void); //整片擦除 void W25QXX_Erase_Sector(u32 Dst_Addr); //扇区擦除 void W25QXX_Wait_Busy(void); //等待空闲 void W25QXX_PowerDown(void); //进入掉电模式 void W25QXX_WAKEUP(void); //唤醒 #endif ; |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 17:54 , Processed in 0.827220 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1969
