电子发烧友论坛扫一扫,分享给好友
NRF24L01.c #include "24l01.h" #include "delay.h" #include "spi.h" #include "usart.h" #include "stm32f10x_spi.h" #include "FreeRTOS.h" #include "task.h" #include "24l01.h" #include "semphr.h" #include "queue.h" const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x33,0x41,0x72,0x12,0x43}; //发送地址 const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x33,0x41,0x72,0x12,0x43}; //初始化24L01的IO口 void nrf24l01_init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //使能复用功能时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能PB,G端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11|GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化指定IO GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //PB10 输入 GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_ResetBits(GPIOB,GPIO_Pin_11|GPIO_Pin_12);//PB11 12下拉 //nRF24L01 NVIC配置 NVIC_InitStructure.NVIC_IRQChannel=EXTI15_10_IRQn; NVIC_InitStructure.NVIC_IRQChannelSubPriority=5; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0; NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE; NVIC_Init(&NVIC_InitStructure); //将GPIO管脚与外部中断线连接 GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource10); //nRF24L01 EXIT配置 EXTI_InitStructure.EXTI_Line=EXTI_Line10; EXTI_InitStructure.EXTI_Mode=EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger=EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd=ENABLE; EXTI_Init(&EXTI_InitStructure); EXTI_ClearITPendingBit(EXTI_Line10); SPI2_Init(); //初始化SPI SPI_Cmd(SPI2, DISABLE); // SPI外设不使能 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //SPI主机 SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //时钟悬空低 SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //数据捕获于第1个时钟沿 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由软件控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16; //定义波特率预分频的值:波特率预分频值为16 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI2, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI2, ENABLE); //使能SPI外设 NRF24L01_CE=0; //使能24L01 NRF24L01_CSN=1; //SPI片选取消 } //检测24L01是否存在 //返回值:0,成功;1,失败 u8 NRF24L01_Check(void) { u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5}; u8 i; SPI2_SetSpeed(SPI_BaudRatePrescaler_4); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址. NRF24L01_Read_Buf(TX_ADDR,buf,5); //读出写入的地址 for(i=0;i<5;i++)if(buf!=0XA5)break; if(i!=5)return 1;//检测24L01错误 return 0; //检测到24L01 } //SPI写寄存器 //reg:指定寄存器地址 //value:写入的值 u8 NRF24L01_Write_Reg(u8 reg,u8 value) { u8 status; NRF24L01_CSN=0; //使能SPI传输 status =SPI2_ReadWriteByte(reg);//发送寄存器号 SPI2_ReadWriteByte(value); //写入寄存器的值 NRF24L01_CSN=1; //禁止SPI传输 return(status); //返回状态值 } //读取SPI寄存器值 //reg:要读的寄存器 u8 NRF24L01_Read_Reg(u8 reg) { u8 reg_val; NRF24L01_CSN = 0; //使能SPI传输 SPI2_ReadWriteByte(reg); //发送寄存器号 reg_val=SPI2_ReadWriteByte(0XFF);//读取寄存器内容 NRF24L01_CSN = 1; //禁止SPI传输 return(reg_val); //返回状态值 } //在指定位置读出指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status=SPI2_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0;u8_ctr return status; //返回读到的状态值 } //在指定位置写指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status = SPI2_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0; u8_ctr return status; //返回读到的状态值 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:发送完成状况 u8 NRF24L01_TxPacket(u8 *txbuf) { SPI2_SetSpeed(SPI_BaudRatePrescaler_8);//spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_CE=0; NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节 NRF24L01_CE=1;//启动发送 return 0xff;//其他原因发送失败 } //该函数初始化NRF24L01到RX模式 //设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR //当CE变高后,即进入RX模式,并可以接收数据了 void NRF24L01_RX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通信频率 NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x27);//设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f);//配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式 SPI2_SetSpeed(SPI_BaudRatePrescaler_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,0xff); //***一定要清空状态寄存器,否则会出错。** NRF24L01_CE = 1; //CE为高,进入接收模式 } //该函数初始化NRF24L01到TX模式 //设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR //PWR_UP,CRC使能 //当CE变高后,即进入RX模式,并可以接收数据了 //CE为高大于10us,则启动发送. void NRF24L01_TX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//写TX节点地址 NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通道为40 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x27); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断 NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器 NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,0xff); //清除状态寄存器 NRF24L01_CE=1;//CE为高,10us后启动发送 } //nRF24L01中断服务程序 void EXTI15_10_IRQHandler(void) { u8 istatus=0x00; BaseType_t xHigherPriorityTaskWoken; //判断是否是线路6引起的中断 if (EXTI_GetITStatus(EXTI_Line10)!=RESET) { if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_10)==0) { istatus=NRF24L01_Read_Reg(STATUS); // 读取状态寄存其来判断数据接收状况 if(istatus&0x40)//bit6:数据接收中断 { xSemaphoreGiveFromISR(nrfAcptBinSem,&xHigherPriorityTaskWoken); } else if((istatus&0x10)>0)达到最大发送次数中断 { NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器 } else if((istatus&0x20)>0)//TX发送完成中断 { NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器 } NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,istatus);//清除状态寄存器 } EXTI_ClearITPendingBit(EXTI_Line10); //清除标志 } } NRF24L01.h #ifndef __24L01_H #define __24L01_H #include "sys.h" #include "delay.h" #include "usart.h" #include "FreeRTOS.h" #include "task.h" #include "24l01.h" #include "semphr.h" #include "queue.h" // //NRF24L01寄存器操作命令 #define NRF_READ_REG 0x00 //读配置寄存器,低5位为寄存器地址 #define NRF_WRITE_REG 0x20 //写配置寄存器,低5位为寄存器地址 #define RD_RX_PLOAD 0x61 //读RX有效数据,1~32字节 #define WR_TX_PLOAD 0xA0 //写TX有效数据,1~32字节 #define FLUSH_TX 0xE1 //清除TX FIFO寄存器.发射模式下用 #define FLUSH_RX 0xE2 //清除RX FIFO寄存器.接收模式下用 #define REUSE_TX_PL 0xE3 //重新使用上一包数据,CE为高,数据包被不断发送. #define NOP 0xFF //空操作,可以用来读状态寄存器 //SPI(NRF24L01)寄存器地址 #define CONFIG 0x00 //配置寄存器地址;bit0:1接收模式,0发射模式;bit1:电选择;bit2:CRC模式;bit3:CRC使能; //bit4:中断MAX_RT(达到最大重发次数中断)使能;bit5:中断TX_DS使能;bit6:中断RX_DR使能 #define EN_AA 0x01 //使能自动应答功能 bit0~5,对应通道0~5 #define EN_RXADDR 0x02 //接收地址允许,bit0~5,对应通道0~5 #define SETUP_AW 0x03 //设置地址宽度(所有数据通道):bit1,0:00,3字节;01,4字节;02,5字节; #define SETUP_RETR 0x04 //建立自动重发;bit3:0,自动重发计数器;bit7:4,自动重发延时 250*x+86us #define RF_CH 0x05 //RF通道,bit6:0,工作通道频率; #define RF_SETUP 0x06 //RF寄存器;bit3:传输速率(0:1Mbps,1:2Mbps);bit2:1,发射功率;bit0:低噪声放大器增益 #define STATUS 0x07 //状态寄存器;bit0:TX FIFO满标志;bit3:1,接收数据通道号(最大:6);bit4,达到最多次重发 //bit5:数据发送完成中断;bit6:接收数据中断; #define MAX_TX 0x10 //达到最大发送次数中断 #define TX_OK 0x20 //TX发送完成中断 #define RX_OK 0x40 //接收到数据中断 #define OBSERVE_TX 0x08 //发送检测寄存器,bit7:4,数据包丢失计数器;bit3:0,重发计数器 #define CD 0x09 //载波检测寄存器,bit0,载波检测; #define RX_ADDR_P0 0x0A //数据通道0接收地址,最大长度5个字节,低字节在前 #define RX_ADDR_P1 0x0B //数据通道1接收地址,最大长度5个字节,低字节在前 #define RX_ADDR_P2 0x0C //数据通道2接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define RX_ADDR_P3 0x0D //数据通道3接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define RX_ADDR_P4 0x0E //数据通道4接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define RX_ADDR_P5 0x0F //数据通道5接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define TX_ADDR 0x10 //发送地址(低字节在前),ShockBurstTM模式下,RX_ADDR_P0与此地址相等 #define RX_PW_P0 0x11 //接收数据通道0有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P1 0x12 //接收数据通道1有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P2 0x13 //接收数据通道2有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P3 0x14 //接收数据通道3有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P4 0x15 //接收数据通道4有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P5 0x16 //接收数据通道5有效数据宽度(1~32字节),设置为0则非法 #define NRF_FIFO_STATUS 0x17 //FIFO状态寄存器;bit0,RX FIFO寄存器空标志;bit1,RX FIFO满标志;bit2,3,保留 //bit4,TX FIFO空标志;bit5,TX FIFO满标志;bit6,1,循环发送上一数据包.0,不循环; // //24L01操作线 #define NRF24L01_CE PBout(12) //24L01片选信号 #define NRF24L01_CSN PBout(11) //SPI片选信号 #define NRF24L01_IRQ PBin(10) //IRQ主机数据输入 //24L01发送接收数据宽度定义 #define TX_ADR_WIDTH 5 //5字节的地址宽度 #define RX_ADR_WIDTH 5 //5字节的地址宽度 #define TX_PLOAD_WIDTH 32 //32字节的用户数据宽度 #define RX_PLOAD_WIDTH 32 //32字节的用户数据宽度 extern SemaphoreHandle_t nrfAcptBinSem; //无线接收数据同步信号量 void nrf24l01_init(void); //初始化 void NRF24L01_RX_Mode(void); //配置为接收模式 void NRF24L01_TX_Mode(void); //配置为发送模式 u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 u8s);//写数据区 u8 NRF24L01_Read_Buf(u8 reg, u8 *pBuf, u8 u8s); //读数据区 u8 NRF24L01_Read_Reg(u8 reg); //读寄存器 u8 NRF24L01_Write_Reg(u8 reg, u8 value); //写寄存器 u8 NRF24L01_Check(void); //检查24L01是否存在 u8 NRF24L01_TxPacket(u8 *txbuf); //发送一个包的数据 #endif |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-2 01:18 , Processed in 0.671179 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2461
