电子发烧友论坛|
STM32F103+NRF24L01通道配置之多发一收
1、NRF24L01模块 * 3 2、STM32F103C8T6单片机的最小系统模块 * 3 3、正点原子的例程:《实验33 无线通信实验》 让我们开始吧!!! (下面只提供部分代码) 下面是发送端0号设备的24l01.c文件内容 #include "24l01.h" #include "lcd.h" #include "delay.h" #include "spi.h" #include "usart.h" // //本程序只供学习使用,未经作者许可,不得用于其它任何用途 //ALIENTEK战舰STM32开发板 //NRF24L01驱动代码 //正点原子@ALIENTEK //技术论坛:www.openedv.com //修改日期:2012/9/13 //版本:V1.0 //版权所有,盗版必究。 //Copyright(C) 广州市星翼电子科技有限公司 2009-2019 //All rights reserved // const u8 TX_ADDRESS[TX_ADR_WIDTH] = {0xA5,0xA5,0xA5,0xA5,0xA5}; //发送地址 const u8 RX_ADDRESS[RX_ADR_WIDTH] = {0xA5,0xA5,0xA5,0xA5,0xA5}; //初始化24L01的IO口 void NRF24L01_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOA, ENABLE); //使能PB,G端口时钟 // // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //PB12上拉 防止W25X的干扰 // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化指定IO // GPIO_SetBits(GPIOB,GPIO_Pin_12);//上拉 // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化指定IO GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化指定IO GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; GPIO_Init(GPIOA, &GPIO_InitStructure); //GPIO_ResetBits(GPIOG,GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8);//PG6,7,8上拉 GPIO_ResetBits(GPIOB,GPIO_Pin_0); GPIO_ResetBits(GPIOA,GPIO_Pin_3); GPIO_ResetBits(GPIOA,GPIO_Pin_4); SPI1_Init(); //初始化SPI SPI_Cmd(SPI1, DISABLE); // SPI外设不使能 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //SPI主机 SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //时钟悬空低 SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //数据捕获于第1个时钟沿 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由软件控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16; //定义波特率预分频的值:波特率预分频值为16 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式 SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI1, ENABLE); //使能SPI外设 NRF24L01_CE=0; //使能24L01 NRF24L01_CSN=1; //SPI片选取消 } //检测24L01是否存在 //返回值:0,成功;1,失败 u8 NRF24L01_Check(void) { u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5}; u8 i; SPI1_SetSpeed(SPI_BaudRatePrescaler_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址. NRF24L01_Read_Buf(TX_ADDR,buf,5); //读出写入的地址 for(i=0;i<5;i++)if(buf!=0XA5)break; if(i!=5)return 1;//检测24L01错误 return 0; //检测到24L01 } //SPI写寄存器 //reg:指定寄存器地址 //value:写入的值 u8 NRF24L01_Write_Reg(u8 reg,u8 value) { u8 status; NRF24L01_CSN=0; //使能SPI传输 status =SPI1_ReadWriteByte(reg);//发送寄存器号 SPI1_ReadWriteByte(value); //写入寄存器的值 NRF24L01_CSN=1; //禁止SPI传输 return(status); //返回状态值 } //读取SPI寄存器值 //reg:要读的寄存器 u8 NRF24L01_Read_Reg(u8 reg) { u8 reg_val; NRF24L01_CSN = 0; //使能SPI传输 SPI1_ReadWriteByte(reg); //发送寄存器号 reg_val=SPI1_ReadWriteByte(0XFF);//读取寄存器内容 NRF24L01_CSN = 1; //禁止SPI传输 return(reg_val); //返回状态值 } //在指定位置读出指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status=SPI1_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0;u8_ctr return status; //返回读到的状态值 } //在指定位置写指定长度的数据 //reg:寄存器(位置) //*pBuf:数据指针 //len:数据长度 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len) { u8 status,u8_ctr; NRF24L01_CSN = 0; //使能SPI传输 status = SPI1_ReadWriteByte(reg);//发送寄存器值(位置),并读取状态值 for(u8_ctr=0; u8_ctr return status; //返回读到的状态值 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:发送完成状况 u8 NRF24L01_TxPacket(u8 *txbuf) { u8 sta; SPI1_SetSpeed(SPI_BaudRatePrescaler_8);//spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) NRF24L01_CE=0; NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节 NRF24L01_CE=1;//启动发送 while(NRF24L01_IRQ!=0);//等待发送完成 sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 if(sta&MAX_TX)//达到最大重发次数 { NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器 return MAX_TX; } if(sta&TX_OK)//发送完成 { return TX_OK; } return 0xff;//其他原因发送失败 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:0,接收完成;其他,错误代码 u8 NRF24L01_RxPacket(u8 *rxbuf) { u8 sta; SPI1_SetSpeed(SPI_BaudRatePrescaler_8); //spi速度为9Mhz(24L01的最大SPI时钟为10Mhz) sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志 if(sta&RX_OK)//接收到数据 { NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据 NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器 return 0; } return 1;//没收到任何数据 } //该函数初始化NRF24L01到RX模式 //设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR //当CE变高后,即进入RX模式,并可以接收数据了 void NRF24L01_RX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址 RX_ADDR_P0 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通信频率 NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度 RX_PW_P0 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x27);//设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f);//配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式 NRF24L01_CE = 1; //CE为高,进入接收模式 } //该函数初始化NRF24L01到TX模式 //设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR //PWR_UP,CRC使能 //当CE变高后,即进入RX模式,并可以接收数据了 //CE为高大于10us,则启动发送. void NRF24L01_TX_Mode(void) { NRF24L01_CE=0; NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//写TX节点地址 NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK RX_ADDR_P0 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x03); //使能通道0的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x03); //使能通道0的接收地址 NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通道为40 NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x27); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断 NRF24L01_CE=1;//CE为高,10us后启动发送 } |
下面是发送端1号设备的24l01.c文件内容
在发送端0号和发送端1号的文件中主要修改的是 // 除了发送地址和接收地址有修改的地方,其他的并没有什么修改 // 修改的发送地址和接收地址,还有就是无论是使用几台设备,就必须要把多个通道全部开启 // 下面的是将通道1和通道0进行了开启的配置 // 如果想要开启三个通道,那就先设置好多个通道的发送地址和接收地址,再将通道0、通道1和通道2的自动应答和接收地址进行使能操作 const u8 TX_ADDRESS[TX_ADR_WIDTH] = {0xA5,0xA5,0xA5,0xA5,0xA5}; //发送地址0号 const u8 RX_ADDRESS[RX_ADR_WIDTH] = {0xA5,0xA5,0xA5,0xA5,0xA5}; //接收地址0号 const u8 TX_ADDRESS1[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x10}; //发送地址1号 const u8 RX_ADDRESS1[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x10}; //接收地址1号 NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//写TX节点地址 NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x03); //使能通道0和通道1的自动应答 NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x03); //使能通道0和通道1的接收地址 下面是发送端1号设备的main.c文件内容 #include "led.h" #include "delay.h" #include "key.h" #include "sys.h" #include "lcd.h" #include "usart.h" #include "24l01.h" #include int main(void) { u8 key = 0; u8 tmp_buf[4] = {0}; delay_init(); //延时函数初始化 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级 NRF24L01_Init(); //初始化NRF24L01 KEY_Init(); LED_Init(); while(NRF24L01_Check()) { printf("NRF24L01_Check Error!!!rn"); delay_ms(500); } NRF24L01_TX_Mode(); while(1) { if(elevator_24Vlock_pin == 1) { key = 1; GPIO_ResetBits(GPIOC,GPIO_Pin_13); } else { key = 0; GPIO_SetBits(GPIOC,GPIO_Pin_13); } tmp_buf[0] = 'S'; tmp_buf[1] = '1'; tmp_buf[2] = key; tmp_buf[3] = 'E'; if(NRF24L01_TxPacket(tmp_buf) == TX_OK) GPIO_ResetBits(GPIOC,GPIO_Pin_13); else GPIO_SetBits(GPIOC,GPIO_Pin_13); delay_ms(30); } } 下面是发送端0号设备的main.c文件内容 #include "led.h" #include "delay.h" #include "key.h" #include "sys.h" #include "lcd.h" #include "usart.h" #include "24l01.h" #include int main(void) { u8 key = 0; u8 tmp_buf[4] = {0}; delay_init(); //延时函数初始化 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级 NRF24L01_Init(); //初始化NRF24L01 KEY_Init(); LED_Init(); while(NRF24L01_Check()) { printf("NRF24L01_Check Error!!!rn"); delay_ms(500); } NRF24L01_TX_Mode(); while(1) { if(elevator_24Vlock_pin == 1) { key = 1; GPIO_ResetBits(GPIOC,GPIO_Pin_13); } else { key = 0; GPIO_SetBits(GPIOC,GPIO_Pin_13); } tmp_buf[0] = 'S'; tmp_buf[1] = '0'; tmp_buf[2] = key; tmp_buf[3] = 'E'; if(NRF24L01_TxPacket(tmp_buf) == TX_OK) GPIO_ResetBits(GPIOC,GPIO_Pin_13); else GPIO_SetBits(GPIOC,GPIO_Pin_13); delay_ms(30); } } 下面是接收端的main.c文件. // An highlighted block #include "led.h" #include "delay.h" #include "key.h" #include "sys.h" #include "usart.h" #include "24l01.h" #include "stdio.h" int main(void) { u8 rc = 0; u8 tmp_buf[4] = {0}; delay_init(); //延时函数初始化 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级 NRF24L01_Init(); //初始化NRF24L01 LED_Init(); while(NRF24L01_Check()) { printf("NRF24L01_Check Error!!!rn"); delay_ms(500); } NRF24L01_RX_Mode(); while(1) { rc = NRF24L01_RxPacket(tmp_buf); if(rc == 0) { if((tmp_buf[0] == 'S' && tmp_buf[1] == '0' && tmp_buf[3] == 'E') || (tmp_buf[0] == 'S' && tmp_buf[1] == '1' && tmp_buf[3] == 'E')) { if(tmp_buf[2]) { GPIO_SetBits(GPIOB, GPIO_Pin_10 | GPIO_Pin_11); GPIO_SetBits(GPIOC, GPIO_Pin_13); } else { GPIO_ResetBits(GPIOB, GPIO_Pin_10 | GPIO_Pin_11); GPIO_ResetBits(GPIOC, GPIO_Pin_13); } } } delay_ms(30); } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 21:34 , Processed in 0.627498 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
497
