电子发烧友论坛|
STM32F103移值RT-Thread Nano添加与FinSH标准库程序一些资源
RT-Thread官方提供的是HAL库的源码,和标准库函数还是有区别的,这里我了标准库下的移值,供有需要的人参考。 #include "sys.h" #include "usart.h" #include "rtthread.h" #define rt_ringbuffer_space_len(rb) ((rb)->buffer_size - rt_ringbuffer_data_len(rb)) struct rt_ringbuffer { rt_uint8_t *buffer_ptr; rt_uint16_t read_mirror : 1; rt_uint16_t read_index : 15; rt_uint16_t write_mirror : 1; rt_uint16_t write_index : 15; rt_int16_t buffer_size; }; enum rt_ringbuffer_state { RT_RINGBUFFER_EMPTY, RT_RINGBUFFER_FULL, /* half full is neither full nor empty */ RT_RINGBUFFER_HALFFULL, }; rt_inline enum rt_ringbuffer_state rt_ringbuffer_status(struct rt_ringbuffer *rb) { if (rb->read_index == rb->write_index) { if (rb->read_mirror == rb->write_mirror) return RT_RINGBUFFER_EMPTY; else return RT_RINGBUFFER_FULL; } return RT_RINGBUFFER_HALFFULL; } /** * get the size of data in rb */ rt_size_t rt_ringbuffer_data_len(struct rt_ringbuffer *rb) { switch (rt_ringbuffer_status(rb)) { case RT_RINGBUFFER_EMPTY: return 0; case RT_RINGBUFFER_FULL: return rb->buffer_size; case RT_RINGBUFFER_HALFFULL: default: if (rb->write_index > rb->read_index) return rb->write_index - rb->read_index; else return rb->buffer_size - (rb->read_index - rb->write_index); }; } void rt_ringbuffer_init(struct rt_ringbuffer *rb, rt_uint8_t *pool, rt_int16_t size) { RT_ASSERT(rb != RT_NULL); RT_ASSERT(size > 0); /* initialize read and write index */ rb->read_mirror = rb->read_index = 0; rb->write_mirror = rb->write_index = 0; /* set buffer pool and size */ rb->buffer_ptr = pool; rb->buffer_size = RT_ALIGN_DOWN(size, RT_ALIGN_SIZE); } /** * put a character into ring buffer */ rt_size_t rt_ringbuffer_putchar(struct rt_ringbuffer *rb, const rt_uint8_t ch) { RT_ASSERT(rb != RT_NULL); /* whether has enough space */ if (!rt_ringbuffer_space_len(rb)) return 0; rb->buffer_ptr[rb->write_index] = ch; /* flip mirror */ if (rb->write_index == rb->buffer_size-1) { rb->write_mirror = ~rb->write_mirror; rb->write_index = 0; } else { rb->write_index++; } return 1; } /** * get a character from a ringbuffer */ rt_size_t rt_ringbuffer_getchar(struct rt_ringbuffer *rb, rt_uint8_t *ch) { RT_ASSERT(rb != RT_NULL); /* ringbuffer is empty */ if (!rt_ringbuffer_data_len(rb)) return 0; /* put character */ *ch = rb->buffer_ptr[rb->read_index]; if (rb->read_index == rb->buffer_size-1) { rb->read_mirror = ~rb->read_mirror; rb->read_index = 0; } else { rb->read_index++; } return 1; } /******************************************************************************* * Function Name : uart_init * Description : * Input : None * Output : None * Return : None *******************************************************************************/ /* 第二部分:finsh 移植对接部分 */ #define UART_RX_BUF_LEN 16 rt_uint8_t uart_rx_buf[UART_RX_BUF_LEN] = {0}; struct rt_ringbuffer uart_rxcb; /* 定义一个 ringbuffer cb */ //static UART_HandleTypeDef UartHandle; static struct rt_semaphore shell_rx_sem; /* 定义一个静态信号量 */ void USART1_Init(u32 bound) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* 初始化串口接收 ringbuffer */ rt_ringbuffer_init(&uart_rxcb, uart_rx_buf, UART_RX_BUF_LEN); /* 初始化串口接收数据的信号量 */ rt_sem_init(&(shell_rx_sem), "shell_rx", 0, 0); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟 //USART1_TX GPIOA.9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9 //USART1_RX GPIOA.10初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10 //Usart1 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 USART_InitStructure.USART_BaudRate = bound;//串口波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口1 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断 USART_Cmd(USART1, ENABLE); //使能串口1 } /******************************************************************************* * Function Name : uart_send_byte * Description : * Input : None * Output : None * Return : None *******************************************************************************/ void uart_send_byte(u8 data) { while((USART1->SR & 0X40) == 0); USART1->DR = data; } /* 移植控制台,实现控制台输出, 对接 rt_hw_console_output */ void rt_hw_console_output(const char *str) { rt_size_t i = 0, size = 0; char a = 'r'; size = rt_strlen(str); for (i = 0; i < size; i++) { if (*(str + i) == 'n') { uart_send_byte(a); } uart_send_byte(str); } } /* 移植 FinSH,实现命令行交互, 需要添加 FinSH 源码,然后再对接 rt_hw_console_getchar */ /* 中断方式 */ char rt_hw_console_getchar(void) { char ch = 0; /* 从 ringbuffer 中拿出数据 */ while (rt_ringbuffer_getchar(&uart_rxcb, (rt_uint8_t *)&ch) != 1) { rt_sem_take(&shell_rx_sem, RT_WAITING_FOREVER); } return ch; } /******************************************************************************* * Function Name : USART1_IRQHandler * Description : * Input : None * Output : None * Return : None *******************************************************************************/ void USART1_IRQHandler(void) { int ch = -1; /* enter interrupt */ rt_interrupt_enter(); //在中断中一定要调用这对函数,进入中断 if ((USART_GetFlagStatus(USART1, USART_FLAG_RXNE) != RESET) && (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)) { while (1) { ch = -1; if (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) != RESET) { ch = USART1->DR & 0xff; } if (ch == -1) { break; } /* 读取到数据,将数据存入 ringbuffer */ rt_ringbuffer_putchar(&uart_rxcb, ch); } rt_sem_release(&shell_rx_sem); } /* leave interrupt */ rt_interrupt_leave(); //在中断中一定要调用这对函数,离开中断 } 然后在board.c文件中的void rt_hw_board_init()函数里调用串口初始化函数 。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1977浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2166浏览 3评论
/9
GMT+8, 2025-12-2 06:39 , Processed in 0.523073 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2384
