电子发烧友论坛|
平台:KEIL5+stm32f103
功能:用TIMER3在通道1上输出一个频率为36KHz,占空比自动变化的PWM波形。为了效果更明显,我把其他通道都打开了。 代码如下:这个代码是在官方例程的基础上加了一些修改: 1.增加设置PWM的频率和占空比的函数,方便调用; 2.增加了关闭通道的功能(在该例程中没有使用); #define DUTY_CYCLCE_BUF_LEN 6//6种占空比 //DMA自动读取buf里面的内容到CCR1 uint16_t DutyCyclebuf[DUTY_CYCLCE_BUF_LEN] = {500,333,249,166,83,41}; /** * disable CHX output * */ void DisableChxOutput(uint8_t CHX) { switch(CHX) { case 1: { /* Disable the Channel 1: Reset the CC1E Bit */ TIM3->CCER &= (uint16_t)(~(uint16_t)TIM_CCER_CC1E); TIM_ITConfig(TIM3, TIM_IT_CC1 , DISABLE); } break; case 2: { /* Disable the Channel 2: Reset the CC2E Bit */ TIM3->CCER &= (uint16_t)(~(uint16_t)TIM_CCER_CC2E); TIM_ITConfig(TIM3, TIM_IT_CC2 , DISABLE); } break; case 3: { TIM3->CCER &= (uint16_t)(~(uint16_t)TIM_CCER_CC3E); TIM_ITConfig(TIM3, TIM_IT_CC3 , DISABLE); } break; case 4: { TIM3->CCER &= (uint16_t)(~(uint16_t)TIM_CCER_CC4E); TIM_ITConfig(TIM3, TIM_IT_CC4 , DISABLE); } break; default: break; } } void TIMER3_PWM_GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* GPIOA clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB| RCC_APB2Periph_AFIO, ENABLE); /* GPIOA Configuration:TIM3 Channel1, 2, 3 and 4 as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1; GPIO_Init(GPIOB, &GPIO_InitStructure); } uint16_t SetPWMFreq(uint16_t TargetFreaq_KHz) { uint16_t TIM_Period = 0; TIM_Period = 24000/TargetFreaq_KHz; return TIM_Period; } //DutyCycle:0~100 //TIM_Period:计数周期 uint16_t SetPWMDutyCycle(uint16_t TIM_Period,uint8_t DutyCycle) { uint32_t TIM_Pulse = 0; uint32_t Period = TIM_Period; TIM_Pulse = (DutyCycle*Period)/100; return (uint16_t)TIM_Pulse; } void DMA_Configuration(void) { DMA_InitTypeDef D; DMA_DeInit(DMA1_Channel3); //DMA1_3通道初始化 D.DMA_PeripheralBaseAddr =(u32)&TIM3->CCR1; //DMA外设基址 TIM3_CCR1_Address D.DMA_MemoryBaseAddr = (u32)DutyCyclebuf; //DMA内存基址 D.DMA_DIR = DMA_DIR_PeripheralDST; //DST外设作为数据传送目的地址,SRC则作为源地址 D.DMA_BufferSize = DUTY_CYCLCE_BUF_LEN; //DMA缓存大小 D.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不增加 D.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器不增加 D.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //外存字宽16bit D.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //内存字宽16bit //D.DMA_Mode = DMA_Mode_Normal; //工作在循环模式 D.DMA_Mode =DMA_Mode_Circular; D.DMA_Priority = DMA_Priority_High; //DMA置为高优先级 D.DMA_M2M = DMA_M2M_Disable; //不置为内存到内存传输 DMA_Init(DMA1_Channel3, &D); //初始化DMA1 DMA_Cmd(DMA1_Channel3, ENABLE); //DMA1_3使能 } void TIMER3_PWMMode_Config(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; //uint16_t Timer3_PWM_CCR1_Val = 333; uint16_t Timer3_PWM_CCR2_Val = 249; uint16_t Timer3_PWM_CCR3_Val = 166; uint16_t Timer3_PWM_CCR4_Val = 83; uint16_t Timer3_PWM__PrescalerValue = 0; uint16_t Set_Period = 665; /* TIM3 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); TIMER3_PWM_GPIO_Configuration(); /* ----------------------------------------------------------------------- TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles: The TIM3CLK frequency is set to SystemCoreClock (Hz), to get TIM3 counter clock at 24 MHz the Prescaler is computed as following: - Prescaler = (TIM3CLK / TIM3 counter clock) - 1 SystemCoreClock is set to 72 MHz for Low-density, Medium-density, High-density The TIM3 is running at 36 KHz: TIM3 Frequency = TIM3 counter clock/(ARR + 1) = 24 MHz / 666 = 36 KHz TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50% TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5% TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25% TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5% ----------------------------------------------------------------------- */ /* Compute the prescaler value */ Timer3_PWM__PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1; Set_Period = SetPWMFreq(36);//配置输出频率为36kHz //Timer3_PWM_CCR1_Val = SetPWMDutyCycle(Set_Period,20); Timer3_PWM_CCR2_Val = SetPWMDutyCycle(Set_Period,50); Timer3_PWM_CCR3_Val = SetPWMDutyCycle(Set_Period,70); Timer3_PWM_CCR4_Val = SetPWMDutyCycle(Set_Period,90); /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = Set_Period; TIM_TimeBaseStructure.TIM_Prescaler = Timer3_PWM__PrescalerValue; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); /* PWM1 Mode configuration: Channel1 */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = DutyCyclebuf[0];//Timer3_PWM_CCR1_Val; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM3, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);//下次更新事件时,更新寄存器的值 /* PWM1 Mode configuration: Channel2 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = Timer3_PWM_CCR2_Val; TIM_OC2Init(TIM3, &TIM_OCInitStructure); TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable); /* PWM1 Mode configuration: Channel3 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = Timer3_PWM_CCR3_Val; TIM_OC3Init(TIM3, &TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable); /* PWM1 Mode configuration: Channel4 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = Timer3_PWM_CCR4_Val; TIM_OC4Init(TIM3, &TIM_OCInitStructure); TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_ARRPreloadConfig(TIM3, ENABLE); /* TIM3 enable counter */ TIM_Cmd(TIM3, ENABLE); TIM_DMACmd(TIM3, TIM_DMA_Update, ENABLE); //TIM3 DMA请求使能 DMA_Configuration(); } 输出波形如下:绿色的是PA6,即通道1,是我们想要的效果。红色的PA7为通道2. |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 19:08 , Processed in 0.601559 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1851
