电子发烧友论坛|
1个回答
这几天在学平衡小车之家的平衡车,才意识到上位机显示小车参数的方便性,且平衡小车之家的上位机代码易移植。
上位机通信协议 与上位机通信的数据帧长度固定为 4*N+1,帧数据字节之间传输延时不可超过 1ms,否则将认为当前帧结束。UI 刷新没有限制显示延时。 STM32上位机库文件 DataScope_DP.C #include “DataScope_DP.h” unsigned char DataScope_OutPut_Buffer[42] = {0}; //串口发送缓冲区 //函数说明:将单精度浮点数据转成4字节数据并存入指定地址 //附加说明:用户无需直接操作此函数 //target:目标单精度数据 //buf:待写入数组 //beg:指定从数组第几个元素开始写入 //函数无返回 void Float2Byte(float *target,unsigned char *buf,unsigned char beg) { unsigned char *point; point = (unsigned char*)target; //得到float的地址 buf[beg] = point[0]; buf[beg+1] = point[1]; buf[beg+2] = point[2]; buf[beg+3] = point[3]; } //函数说明:将待发送通道的单精度浮点数据写入发送缓冲区 //Data:通道数据 //Channel:选择通道(1-10) //函数无返回 void DataScope_Get_Channel_Data(float Data,unsigned char Channel) { if ( (Channel 》 10) || (Channel == 0) ) return; //通道个数大于10或等于0,直接跳出,不执行函数 else { switch (Channel) { case 1: Float2Byte(&Data,DataScope_OutPut_Buffer,1); break; case 2: Float2Byte(&Data,DataScope_OutPut_Buffer,5); break; case 3: Float2Byte(&Data,DataScope_OutPut_Buffer,9); break; case 4: Float2Byte(&Data,DataScope_OutPut_Buffer,13); break; case 5: Float2Byte(&Data,DataScope_OutPut_Buffer,17); break; case 6: Float2Byte(&Data,DataScope_OutPut_Buffer,21); break; case 7: Float2Byte(&Data,DataScope_OutPut_Buffer,25); break; case 8: Float2Byte(&Data,DataScope_OutPut_Buffer,29); break; case 9: Float2Byte(&Data,DataScope_OutPut_Buffer,33); break; case 10: Float2Byte(&Data,DataScope_OutPut_Buffer,37); break; } } } //函数说明:生成 DataScopeV1.0 能正确识别的帧格式 //Channel_Number,需要发送的通道个数 //返回发送缓冲区数据个数 //返回0表示帧格式生成失败 unsigned char DataScope_Data_Generate(unsigned char Channel_Number) { if ( (Channel_Number 》 10) || (Channel_Number == 0) ) { return 0; } //通道个数大于10或等于0,直接跳出,不执行函数 else { DataScope_OutPut_Buffer[0] = ‘$’; //帧头 switch(Channel_Number) { case 1: DataScope_OutPut_Buffer[5] = 5; return 6; case 2: DataScope_OutPut_Buffer[9] = 9; return 10; case 3: DataScope_OutPut_Buffer[13] = 13; return 14; case 4: DataScope_OutPut_Buffer[17] = 17; return 18; case 5: DataScope_OutPut_Buffer[21] = 21; return 22; case 6: DataScope_OutPut_Buffer[25] = 25; return 26; case 7: DataScope_OutPut_Buffer[29] = 29; return 30; case 8: DataScope_OutPut_Buffer[33] = 33; return 34; case 9: DataScope_OutPut_Buffer[37] = 37; return 38; case 10: DataScope_OutPut_Buffer[41] = 41; return 42; } } return 0; } DataScope_DP.H #ifndef __DATA_PRTOCOL_H #define __DATA_PRTOCOL_H extern unsigned char DataScope_OutPut_Buffer[42]; //待发送帧数据缓存区 void DataScope_Get_Channel_Data(float Data,unsigned char Channel); // 写通道数据至 待发送帧数据缓存区 unsigned char DataScope_Data_Generate(unsigned char Channel_Number); // 发送帧数据生成函数 #endif 主函数 #include “sys.h” #include “DataScope_DP.h” unsigned char i; //计数变量 unsigned char Send_Count; //串口需要发送的数据个数 static float a; int main(void) { Stm32_Clock_Init(9); //系统时钟设置 delay_init(72); //延时初始化 uart_init(72,128000); //初始化串口1 while(1) { a+=0.1; if(a》3.14) a=-3.14; DataScope_Get_Channel_Data(500*sin(a), 1 ); DataScope_Get_Channel_Data(500* tan(a), 2 ); DataScope_Get_Channel_Data( 500*cos(a), 3 ); DataScope_Get_Channel_Data( 100*a , 4 ); DataScope_Get_Channel_Data(0, 5 ); DataScope_Get_Channel_Data(0 , 6 ); DataScope_Get_Channel_Data(0, 7 ); DataScope_Get_Channel_Data( 0, 8 ); DataScope_Get_Channel_Data(0, 9 ); DataScope_Get_Channel_Data( 0 , 10); Send_Count = DataScope_Data_Generate(10); for( i = 0 ; i 《 Send_Count; i++) { while((USART1-》SR&0X40)==0); USART1-》DR = DataScope_OutPut_Buffer[i]; } delay_ms(50); //20HZ } } 串口发送数据缓冲区一共有了42个字节,只用到的只有41个(0~40)。每个channel占用4个,共10个channel,再加一个帧头$ (用来区分不同数据的标记)。 用到几个channel,Channel_Number就写几,比如用到2个channel,Channel_Number=2,这时候DataScope_Data_Generate(2)=9,DataScope_OutPut_Buffer[9]赋值为9,便于统计(4*N+1格式),但其实只发送DataScope_OutPut_Buffer[0~8]。 验证 channel 1 500sin(a) channel 2 500 tan(a) channel 3 500cos(a) channel 4 100a channel 5~8 0 看得出上位机波形基本一致。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4207 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3263 浏览 1 评论
2796 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2227 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15169 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3169浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1942浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2110浏览 3评论
2020浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2218浏览 3评论
/9
GMT+8, 2025-12-14 07:44 , Processed in 0.672112 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
11674
