近日考虑DIY1台STM32版的T12焊台,MCU选来选去选中了STM32F070F6P6(CM0内核,TSSOP20封装,48Mhz,32kFlash,6kRam,内置8Mhz晶振和RTC晶振,网上均价5元左右,性价比很高)。因此本文是基于STM32F070F6P6示范,其它stm32的相应设置基本大同小异。
EC11的电气特性 由上图,我们可以看到出 A相上升沿时,B相高电平为顺时针转动,B相低电平则为逆时针转动不采用Encoder模式的常规方法就是利用上述特点来编程。 EC11部分电路原理图 EC11_A→PA6 EC11_B→PA7 STM32CubeMX的设置 这里,Encoder的channel2我配置的Falling edge(原先设置的Rising edge)。实际这里channel2设置Rising edge/Falling edge都可以,只影响顺/逆时针转动EC11时输出结果+/-的问题。 解码EC11 本例中,我采用中断法解码EC11,CubeMX中还需在NVIC勾选TIM3的全局中断; 配置完成TIM3的初始化代码如下所示: /** * @brief TIM3 Initialization Function * @param None * @retval None */ static void MX_TIM3_Init(void) { /* USER CODE BEGIN TIM3_Init 0 */ /* USER CODE END TIM3_Init 0 */ TIM_Encoder_InitTypeDef sConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; /* USER CODE BEGIN TIM3_Init 1 */ /* USER CODE END TIM3_Init 1 */ htim3.Instance = TIM3; htim3.Init.Prescaler = 3; htim3.Init.CounterMode = TIM_COUNTERMODE_UP; htim3.Init.Period = 20; htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; sConfig.EncoderMode = TIM_ENCODERMODE_TI12; sConfig.IC1Polarity = TIM_ICPOLARITY_RISING; sConfig.IC1Selection = TIM_ICSELECTION_DIRECTTI; sConfig.IC1Prescaler = TIM_ICPSC_DIV1; sConfig.IC1Filter = 1; sConfig.IC2Polarity = TIM_ICPOLARITY_FALLING; //TIM_ICPOLARITY_RISING sConfig.IC2Selection = TIM_ICSELECTION_DIRECTTI; sConfig.IC2Prescaler = TIM_ICPSC_DIV1; sConfig.IC2Filter = 1; if (HAL_TIM_Encoder_Init(&htim3, &sConfig) != HAL_OK) { Error_Handler(); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN TIM3_Init 2 */ /* USER CODE END TIM3_Init 2 */ } EC11A、B相连接的引脚配置在stm32f0xx_hal_msp.c文件中,TIM3的NVIC代码也在相同代码片段,具体代码如下 /** * @brief TIM_Encoder MSP Initialization * This function configures the hardware resources used in this example * @param htim_encoder: TIM_Encoder handle pointer * @retval None */ void HAL_TIM_Encoder_MspInit(TIM_HandleTypeDef* htim_encoder) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(htim_encoder->Instance==TIM3) { /* USER CODE BEGIN TIM3_MspInit 0 */ /* USER CODE END TIM3_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_TIM3_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); /**TIM3 GPIO Configuration PA6 ------> TIM3_CH1 PA7 ------> TIM3_CH2 */ GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF1_TIM3; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* USER CODE BEGIN TIM3_MspInit 1 */ HAL_NVIC_SetPriority(TIM3_IRQn,0,0); HAL_NVIC_EnableIRQ(TIM3_IRQn); /* USER CODE END TIM3_MspInit 1 */ } } 最后还需开启Encoder,代码为: HAL_TIM_Encoder_Start(&htim3,TIM_CHANNEL_ALL); 1 欲使用Encoder中断,还需开启相应中断: > HAL_TIM_Encoder_Start_IT(&htim3,TIM_CHANNEL_1);//这里TIM_CHANNEL_1/TIM_CHANNEL_ALL均可 1 回调函数 Encoder中断产生的是Capture compare event ,因此我们在TIM3的初始化代码附近补充callback代码: void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim) { if(htim->Instance->CR1==0x01)//顺时针 Rotary=1; if(htim->Instance->CR1==0x11)//逆时针 Rotary=0; } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4138 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2752 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14980 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3086浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1896浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2066浏览 3评论
1979浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2168浏览 3评论
/9
GMT+8, 2025-12-2 07:27 , Processed in 0.794132 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2387
