电子发烧友论坛扫一扫,分享给好友
1个回答
如题,我的设置是:外部中断为下降沿模式,GPIO的输入为上拉模式的输入,中断响应为输出端反转状态———小灯亮灭。当按下按键后,理应产生一个下降沿,按一下灭灯,再按一下亮灯。
但是现象是:有时候可以亮,但有时候按下去小灯状态不变。这个是什么原因,是否要进行去抖? (初学者,用的野火的程序) //中断初始化设置 static void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; /* Configure one bit for preemption priority -优先级设置为第一级*/ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); /***********注各个端口的引脚5 中断向量一样************************/ /* 配置P[A|B|C|D|E]5为中断源 */ NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } //中断函数设置 void EXTI_PE5_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; /* config the extiline(PE5) clock and AFIO clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,ENABLE); /* config the NVIC(PE5) */ NVIC_Configuration(); /* EXTI line gpio config(PE5) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; // 上拉输入 GPIO_Init(GPIOE, &GPIO_InitStructure); /* EXTI line(PE5) mode config */ GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource5); EXTI_InitStructure.EXTI_Line = EXTI_Line5; //外部中断线的组合,应该是引脚号 EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //一般就用这种中断模式 EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //下降沿中断 EXTI_InitStructure.EXTI_LineCmd = ENABLE; //中断使能 EXTI_Init(&EXTI_InitStructure); } //中断函数设置 void EXTI_PE5_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; /* config the extiline(PE5) clock and AFIO clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,ENABLE); /* config the NVIC(PE5) */ NVIC_Configuration(); /* EXTI line gpio config(PE5) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; // 上拉输入 GPIO_Init(GPIOE, &GPIO_InitStructure); /* EXTI line(PE5) mode config */ GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource5); EXTI_InitStructure.EXTI_Line = EXTI_Line5; //外部中断线的组合,应该是引脚号 EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //一般就用这种中断模式 EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //下降沿中断 EXTI_InitStructure.EXTI_LineCmd = ENABLE; //中断使能 EXTI_Init(&EXTI_InitStructure); } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 22:08 , Processed in 0.615307 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2688
