电子发烧友论坛|
10#您好,我安装并选择了5.2.10版的CGT,编译后出现如下错误,按理说controlSUITE里的工程文件是没错的吧!
"../SolarHv_DCAC-F28035_RAM.cmd", line 51: error: BEGIN memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 51: error: BEGIN memory range overlaps existing memory range BEGIN "../SolarHv_DCAC-F28035_RAM.cmd", line 53: error: RAMM0 memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 53: error: RAMM0 memory range overlaps existing memory range RAMM0 "../SolarHv_DCAC-F28035_RAM.cmd", line 55: error: progRAM memory range overlaps existing memory range RAML0L1 "../SolarHv_DCAC-F28035_RAM.cmd", line 57: error: IQTABLES memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 57: error: IQTABLES memory range overlaps existing memory range IQTABLES "../SolarHv_DCAC-F28035_RAM.cmd", line 58: error: IQTABLES2 memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 58: error: IQTABLES2 memory range overlaps existing memory range IQTABLES2 "../SolarHv_DCAC-F28035_RAM.cmd", line 59: error: IQTABLES3 memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 59: error: IQTABLES3 memory range overlaps existing memory range IQTABLES3 "../SolarHv_DCAC-F28035_RAM.cmd", line 61: error: RESET memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 61: error: RESET memory range overlaps existing memory range RESET "../SolarHv_DCAC-F28035_RAM.cmd", line 62: error: BOOTROM memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 62: error: BOOTROM memory range overlaps existing memory range BOOTROM "../SolarHv_DCAC-F28035_RAM.cmd", line 67: error: RAMM1 memory range has already been specified "../SolarHv_DCAC-F28035_RAM.cmd", line 67: error: RAMM1 memory range overlaps existing memory range RAMM1 "../SolarHv_DCAC-F28035_RAM.cmd", line 69: error: ADCDRVRAM memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 70: error: PFCICMDRAM memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 71: error: GENSINCOS memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 72: error: PWMDRVRAM memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 73: error: CNTL2P2ZRAM memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 74: error: dataRAM1 memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 75: error: CNTL2P2ZBUFF memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 76: error: DLOG memory range overlaps existing memory range RAML3 "../SolarHv_DCAC-F28035_RAM.cmd", line 78: error: dataRAM memory range overlaps existing memory range RAML3 "../28035_RAM_lnk.cmd", line 112: error: placement fails for object ".text", size 0x15de (page 0). Available ranges: RAML0L1 size: 0xc00 unused: 0xbbe max hole: 0xbbe warning: entry-point symbol "_c_int00" undefined undefined first referenced symbol in file --------- ---------------- L$$DIV ./SolarHv_DCAC-main.obj error: unresolved symbols remain error: errors encountered during linking; "SolarHV_DCAC.out" not built |
szbliy 发表于 2020-5-7 10:58 是最新版本,我把controlSUIT装在D盘了,不会是这个原因吧,我的C盘空间快满了,ccs4也是装在D盘,我用别的电脑试试看吧 |
szbliy 发表于 2020-5-7 11:16 就是因为我把controlSUIT和ccs4装在了D盘导致编译不正确,哎,这个问题我搞了一周!!! 另外,还有一个问题,TMDSHV1PHINVKIT 我只接了电阻负载(500R),off-grid下,为什么输出波形是方波而不是正弦波。注:我拿到demo板没刷程序,里面应该有程序的,control-card上的LED2闪烁正常。我用GUI软件选择120VAC和220VAC输出都是方波,用万用表测量是361V。求专家解释 |
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 17:47 , Processed in 1.078088 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1517
