电子发烧友论坛|
我的产品要用到PWM,我编写以下程序:
void PWM_Init() [ SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); /* 使能PWM输出所在GPIO */ SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM); /* 使能PWM模块 */ SysCtlPWMClockSet(SYSCTL_PWMDIV_1); /* PWM时钟配置:不分频 */ GPIOPinConfigure(GPIO_PF0_PWM); GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_0); /* PF0配置为PWM功能 D7 */ GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_1); /* PF1配置为PWM功能 D6 */ GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_2); /* PF2配置为PWM功能 D5 */ GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_3); /* PF3配置为PWM功能 D4 */ PWMGenConfigure(PWM_BASE, PWM_GEN_3, /* 配置PWM发生器1:加减计数 */ PWM_GEN_MODE_DOWN ); PWMGenPeriodSet(PWM_BASE, PWM_GEN_3, 6000); /* 设置PWM发生器1的周期 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_4, 4200); /* 设置PWM4输出的脉冲宽度 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_5, 1800); /* 设置PWM5输出的脉冲宽度 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_6, 1000); /* 设置PWM6输出的脉冲宽度 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_7, 500); /* 设置PWM7输出的脉冲宽度 */ PWMOutputState(PWM_BASE, (PWM_OUT_4_BIT | PWM_OUT_5_BIT | PWM_OUT_6_BIT | PWM_OUT_7_BIT), true); /* 使能PWM输出 */ PWMGenEnable(PWM_BASE, PWM_GEN_3); /* 使能PWM发生器1, */ /* 开始产生PWM方波 */ // while(1); ] 在编译的时候这句编译不过. GPIOPinConfigure(GPIO_PF0_PWM);提示没有定义.请问GPIO_PF0_PWM是在哪个文件定义的呢?我加的头文件有: #include "inc/hw_ints.h" #include "inc/hw_memmap.h" #include "inc/hw_pwm.h" #include "inc/hw_sysctl.h" #include "inc/hw_types.h" #include "driverlib/debug.h" #include "driverlib/interrupt.h" #include "driverlib/pwm.h" #include "led-test.h" #include "driverlib/gpio.h" 要怎么解决?谢谢!!! |
6 个讨论
void PWM_Init() [ SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); /* 使能PWM输出所在GPIO */ SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM); /* 使能PWM模块 */ SysCtlPWMClockSet(SYSCTL_PWMDIV_1); /* PWM时钟配置:不分频 */ GPIOPinConfigure(GPIO_PF3_M1PWM7); GPIOPinConfigure(GPIO_PF2_M1PWM6); GPIOPinConfigure(GPIO_PF1_M1PWM5); GPIOPinConfigure(GPIO_PF0_M1PWM4); GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_0); /* PF0配置为PWM功能 D7 */ GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_1); /* PF1配置为PWM功能 D6 */ GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_2); /* PF2配置为PWM功能 D5 */ GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_3); /* PF3配置为PWM功能 D4 */ PWMGenConfigure(PWM_BASE, PWM_GEN_3, /* 配置PWM发生器1:加减计数 */ PWM_GEN_MODE_DOWN ); PWMGenPeriodSet(PWM_BASE, PWM_GEN_3, 6000); /* 设置PWM发生器1的周期 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_4, 4200); /* 设置PWM4输出的脉冲宽度 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_5, 1800); /* 设置PWM5输出的脉冲宽度 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_6, 1000); /* 设置PWM6输出的脉冲宽度 */ PWMPulseWidthSet(PWM_BASE, PWM_OUT_7, 500); /* 设置PWM7输出的脉冲宽度 */ PWMOutputState(PWM_BASE, (PWM_OUT_4_BIT | PWM_OUT_5_BIT | PWM_OUT_6_BIT | PWM_OUT_7_BIT), true); /* 使能PWM输出 */ PWMGenEnable(PWM_BASE, PWM_GEN_3); /* 使能PWM发生器1, */ /* 开始产生PWM方波 */ while(1); ] 奇怪,为什么PWM没有输出呢?能帮我看看配置有没有问题吗? |
Jazzye 发表于 2020-4-10 09:37 你可以将下面的代码加上试下,PF0默认情况下是不能作为常规外设功能使用,需要将其解锁并设置为相关外设使用。 //配置PF0为GPIO功能,PF0默认为NMI功能; HWREG(GPIO_PORTF_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY_DD; HWREG(GPIO_PORTF_BASE + GPIO_O_CR) = 0x01; HWREG(GPIO_PORTF_BASE + GPIO_O_AFSEL) &= 0xfe; HWREG(GPIO_PORTF_BASE + GPIO_O_LOCK) = 0; |
kangt 发表于 2020-4-10 10:01 问题解决! 把SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM); 改为SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM1); 后面所有PWM_BASE 改为PWM1_BASE. 还是要谢谢技术工程师的帮助. |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 01:18 , Processed in 0.739378 second(s), Total 71, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3044
