电子发烧友论坛|
我是新手,所以请原谅我的无知。我有Vee Pro 7.01并继承了一个相当复杂的程序,涉及通过Measurement Computing制作的两个I / O板的模拟和数字输入和输出数据。
单板上只有两个模拟输入,因为我有三个模拟需求,我有两块板连接在一起,并使用连接板的多线连接器同步。 当没有这些I / O板的驱动程序时,是否可以在Vee Pro中生成一个程序来指示这些板获取数据并在没有制造商的特殊驱动程序的情况下获取数据? 是否有任何人可以帮助这项努力,以前经历过这一点。 提前感谢你。 此外,我住在西海岸大约一半的西雅图,所以如果响应者在该地区生活,我们可以通过电话进行沟通,这可能会有所帮助。请将您的回复转发给DavidG@AeraEnergy.org ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。取消订阅发送 发送电子邮件至“leave-vrf@it.lists.it.agilent.com”。要发送邮件至此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 I am new to this so please excuse my ignorance. I have Vee Pro 7.01 and have inherited a fairly complex program involving input and output data both analog and digital through two I/O Boards made by Measurement Computing. There are only two analog inputs on a single board and since I have three analog needs I have two boards that are connected together and synchronized together using a multiwired connector that connects the boards. When there are no drivers for these I/O boards is it possible to generate a program in Vee Pro to instruct these boards to go to get data and to retrieve it without having a special driver from the manufacture? Is there anyone out there that could aid in this effort, having gone through this previously. Thanking you in advance. Also, I'm living on the West coast about an hour and one half from Seattle, so it might be helpful if the responders were living in the area as we could possibly communicate via phone as well. Please forward your response to DavidG@AeraEnergy.org --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
>当没有这些驱动程序时> I / O板是否可以在Vee Pro中生成>一个程序来指示>这些板可以获取数据并在没有来自制造商的特殊>驱动程序的情况下检索它?
它的工作原理如下:你从MC获得了VEE的通用库并使用它。 还有其他几种选择,但它们非常激烈。至少,你需要有关电路板如何工作的详细信息。但是很奇怪没有驱动程序。 它可能是cheaperto购买新硬件而不是跳过你需要的所有软件箍。通常有三层:Windows驱动程序,通常(在auld lang syne中)表示为C dll的库,可选 一些更高级的levellibrary,如ActiveX或.NET。 驱动程序和主库必须取得任何成功(VEE或其他).- SHAWN ----您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至:“vrf-request @ lists.it.agilent.com“在邮件正文中带有订阅单词。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件到此邮件列表,请发送电子邮件 “vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 > When there are no drivers for these > I/O boards is it possible to generate > a program in Vee Pro to instruct > these boards to go to get data and to > retrieve it without having a special > driver from the manufacture? Generally it works like this: You get the Universal Library from MC for VEE and use that. There are a couple other options, but they're pretty intense. At least, you need details of how the boards work. It's curious that there are no drivers though. It would probably be cheaper to buy new hardware than jump through all the software hoops you'd need to without them. There are usually three layers: a Windows driver, a library that usually (in the auld lang syne) manifests as a C dll, an optionally some higher level library like ActiveX or .NET. The driver and primary library are pretty much a must for any success (VEE or otherwise). -SHAWN- --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
我是新手,所以请原谅我的无知。我有Vee Pro 7.01并继承了一个相当复杂的程序,涉及通过Measurement Computing制造的两个I / O板的模拟和数字输入和输出数据。
单个板上只有两个模拟输入,由于我有三个模拟需求,我有两块板连接在一起并使用连接板的多线连接器同步在一起。 当没有这些I / O板的驱动程序时,可以在Vee Pro中生成一个程序来指示这些板获取数据并在没有制造商的特殊驱动程序的情况下检索它们吗? 是否有任何人可以帮助这项努力,之前已经完成了这项工作。 提前感谢你。 此外,我住在西海岸约一个半小时从西雅图出发,所以如果应急人员住在该地区,我们可以通过电话进行沟通,这可能会有所帮助。请将您的回复转发给DavidG @ AeraEnergy .org ---要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists .it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 I am new to this so please excuse my ignorance. I have Vee Pro 7.01 and have inherited a fairly complex program involving input and output data both analog and digital through two I/O Boards made by Measurement Computing. There are only two analog inputs on a single board and since I have three analog needs I have two boards that are connected together and synchronized together using a multiwired connector that connects the boards. When there are no drivers for these I/O boards is it possible to generate a program in Vee Pro to instruct these boards to go to get data and to retrieve it without having a special driver from the manufacture? Is there anyone out there that could aid in this effort, having gone through this previously. Thanking you in advance. Also, I'm living on the West coast about an hour and one half from Seattle, so it might be helpful if the responders were living in the area as we could possibly communicate via phone as well. Please forward your response to DavidG@AeraEnergy.org --- To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
Measurement Computing应该通过他们的通用驱动程序提供驱动程序..而且有一个便宜的附件(约50美元),这使得与VEE的集成非常简单。
Kathy WrightDavid Goodson | DavidG@aeraenergy.org>写道:我是新手,所以请原谅我的无知。我有Vee Pro 7.01并继承了一个相当复杂的程序,涉及通过两个I / O板制作的模拟和数字输入和输出数据 测量计算。 单板上只有两个模拟输入,因为我有三个模拟需求,我有两块板连接在一起,并使用连接板的多线连接器同步。 当没有这些I / O板的驱动程序时,是否可以在Vee Pro中生成一个程序来指示这些板获取数据并在没有制造商的特殊驱动程序的情况下获取数据? 是否有任何人可以帮助这项努力,以前经历过这一点。 提前感谢你。 此外,我住在西海岸大约一半的西雅图,所以如果响应者在该地区生活,我们可以通过电话进行沟通,这可能会有所帮助。请将您的回复转发给DavidG@AeraEnergy.org ---您目前订阅了vrf:kathy_wright_ca@yahoo.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,并在邮件正文中添加“subscribe”字样。要取消订阅,请发送空白 发送电子邮件至“leave-vrf@it.lists.it.agilent.com”。要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”.--- 您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。要取消订阅,请发送空白电子邮件 到“leave-vrf@it.lists.it.agilent.com”。要发送邮件到这个邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Measurement Computing should supply drivers through their Universal Driver .. and there is an inexpensive add-on (about $50) that makes integration with VEE pretty simple. Kathy WrightDavid Goodson [email=%7CDavidG@aeraenergy.org]|DavidG@aeraenergy.org[/email]> wrote: I am new to this so please excuse my ignorance.I have Vee Pro 7.01 and have inherited a fairly complex program involvinginput and output data both analog and digital through two I/O Boards madeby Measurement Computing. There are only two analog inputs on a singleboard and since I have three analog needs I have two boards that areconnected together and synchronized together using a multiwired connectorthat connects the boards. When there are no drivers for these I/O boards is it possible to generatea program in Vee Pro to instruct these boards to go to get data and toretrieve it without having a special driver from the manufacture? Is thereanyone out there that could aid in this effort, having gone through thispreviously. Thanking you in advance. Also, I'm living on the West coast about an hourand one half from Seattle, so it might be helpful if the responders wereliving in the area as we could possibly communicate via phone as well.Please forward your response to DavidG@AeraEnergy.org---You are currently subscribed to vrf as: kathy_wright_ca@yahoo.comTo subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".---You are currently subscribed to vrf as: [email=r***@soco.agilent.comTo]r***@soco.agilent.comTo[/email] subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
Measurement Computing应该通过他们的通用驱动程序提供驱动程序..并且有一个便宜的附件(大约50美元),这使得与VEE的集成非常简单。凯西WrightDavid Goodson写道:我是新手,所以请原谅我的无知。我有Vee
Pro 7.01并继承了一个相当复杂的程序,涉及通过Measurement Computing制作的两个I / O板进行模拟和数字输入和输出数据。 单板上只有两个模拟输入,因为我有三个模拟需求,我有两块板连接在一起,并使用连接板的多线连接器同步。 当没有这些I / O板的驱动程序时,是否可以在Vee Pro中生成一个程序来指示这些板获取数据并在没有制造商的特殊驱动程序的情况下获取数据? 是否有任何人可以帮助这项努力,以前经历过这一点。 提前感谢你。 此外,我住在西海岸大约一半的西雅图,所以如果响应者在该地区生活,我们可以通过电话进行沟通,这可能会有所帮助。请将您的回复转发给DavidG@AeraEnergy.org ---您目前订阅了vrf:kathy_wright_ca@yahoo.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,并在邮件正文中添加“subscribe”字样。要取消订阅,请发送空白 发送电子邮件至“leave-vrf@it.lists.it.agilent.com”。要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”.--- 要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“www.oswegosw.com/vrf_archive/”上搜索“unofficial vrf archive”。 以上来自于谷歌翻译 以下为原文 Measurement Computing should supply drivers through their Universal Driver .. and there is an inexpensive add-on (about $50) that makes integration with VEE pretty simple. Â Kathy Wright David Goodson wrote: I am new to this so please excuse my ignorance. I have Vee Pro 7.01 and have inherited a fairly complex program involving input and output data both analog and digital through two I/O Boards made by Measurement Computing. There are only two analog inputs on a single board and since I have three analog needs I have two boards that are connected together and synchronized together using a multiwired connector that connects the boards. When there are no drivers for these I/O boards is it possible to generate a program in Vee Pro to instruct these boards to go to get data and to retrieve it without having a special driver from the manufacture? Is there anyone out there that could aid in this effort, having gone through this previously. Thanking you in advance. Also, I'm living on the West coast about an hour and one half from Seattle, so it might be helpful if the responders were living in the area as we could possibly communicate via phone as well. Please forward your response to DavidG@AeraEnergy.org --- You are currently subscribed to vrf as: kathy_wright_ca@yahoo.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:01 , Processed in 0.828200 second(s), Total 81, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1336
