在那里我正在学习vee pro 8.5软件。我希望通过在vee pro i / o中通过u***连接dso来连续监视波形。
但是我的软件没有通过仪器i / o找到dso。请帮助我.DSO已经被计算机用它的驱动程序检测到它可以远程控制。 以上来自于谷歌翻译 以下为原文 hi there i am learning the vee pro 8.5 software.i want to continuously monitor the waveform by connecting dso through u*** in vee pro direct i/o. but my software does not find dso through instrument i/o.please help me in this.DSO is already detected by computer with it's driver and it can be controlled remotely. |
4个回答
那么,Agilent Connection Expert能否检测到dso?
以上来自于谷歌翻译 以下为原文 So, did Agilent Connection Expert able to detect the dso ? |
哪个驱动程序?我使用3000系列dso.problem是我无法在连接专家和vee pro中使用它但是同样的dso通过其相关软件在远程模式下工作
以上来自于谷歌翻译 以下为原文 which driver?I m using 3000series dso.problem is i m not able to use it in connection expert and vee pro but same dso is working in remote mode through its pertcular software |
如果Agilent Connection Expert无法检测到dso,VEE肯定找不到它。
以上来自于谷歌翻译 以下为原文 if Agilent Connection Expert unable to detect the dso, VEE definitely cannot find it. |
如果你的问题仍然存在,那么我希望我能在这里提供帮助。
我不确定您使用的是哪种界面。 根据我的经验,某些仪器的接口很少,例如 LAN,USB和GPIB。 如果Agilent IO Lib无法检测到它,我通常会检查仪器配置系统以验证正在使用的活动接口。 如果它在LAN中,我们将不得不通过转到I / O配置|在Connection Expert中添加该接口 添加仪器/添加接口。 以上来自于谷歌翻译 以下为原文 If you problem still exist, then I hope I can help here. I am not sure what kind of interface you are using. From my experience, some instrument has few interface available e.g. LAN, USB and GPIB. If Agilent IO Lib cannot detect it, I will usually check the instrument configuration system to verify the active interface in use. If it is in LAN, we will have to add that interface in Connection Expert by going to I/O Configuration | Add Instrument/Add Interface. |
只有小组成员才能发言,加入小组>>
1061 浏览 0 评论
2299 浏览 1 评论
2087 浏览 1 评论
1959 浏览 5 评论
2832 浏览 3 评论
831浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
612浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
708浏览 0评论
1390浏览 0评论
1063浏览 0评论
GMT+8, 2024-9-27 19:29 , Processed in 1.162658 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
