电子发烧友论坛|
大家好,
我正在考虑为PLC实现Copress中继器算法(AN62497)。我的疑问是,如果我们有15个奴隶,而中继站不只是它旁边的1个节点,而是2个或更多的节点,如果我们没有100%个到达能力节点到节点(更少的说它可以在一个节点正确读取一个消息之前接受1-3个消息)。 根据对第2-3页中的AN62488文档的解释,如果中继消息在其前面达到2个节点,则2节点将停止重复消息,因为两个节点都接收到来自彼此的确认,并且加上这2个节点前面的节点尚未接收到消息。事实上我们没有达到100%的能力。在这里,我试图通过一个方案来解释场景:A -B-C--D -E-F-G-H-I--L A想与L A通信,向L发送了直接消息,不能看到A,发送广播消息。B和C从A接收广播消息,在直接消息到L之后,都发送广播消息。两者都收到对方的确认,所以他们停止重复消息。现在,如果没有其他节点(D,E,…)接收到来自B和C的广播消息(坏运气),则消息丢失并且永远达不到L。我的问题是:如果另一个节点没有以100%确定的消息接收到消息,该算法是否有效。谢谢你的支持。-J 以上来自于百度翻译 以下为原文 Hi everyone, I am considering implementing Cypress repeater Algorithm for PLC (AN62487). My doubt is if we have 15 slaves and the repeater reaches not just 1 node next to it but 2 or more nodes and if we don't have 100% reach ability node-to-node (less say it could take 1-3 messages before one node reads correctly a message). According to the explanation of AN62487 document on page 2-3 it seems that if a repeater message reaches 2 nodes ahead of it, the 2 node will stop repeating the message because both receive a confirmation from each other and plus the nodes ahead of these 2 have not received the message yet due to the fact we don't have 100% reach ability. Here I try to explain the scenario trough a scheme: A--B--C--D--E--F--G--H--I--L A wants to communicate with L. A has sent direct message to L, which can't see A, A sends broadcast message. B and C receive the broadcasted message from A. After direct message to L, both send broadcast message. Both receive a confirmation from each other so they stop repeating the message. Now, if none of the further nodes ( D,E, ...) has received the broadcasted message from B and C (bad luck), the message is lost and never reach L. My question is: Does the algorithm works if a node next to another does't received with 100% certainty a message. Thank you in advance for the support. - J |
3个回答
在我看来,AlgTrthHIM每个节点都作为一个中继器工作。
需要知道,并且每个节点重复它的邻居直到它 实现认知。因此,数据包传播到每个最近的位置。 邻居直到完成。 HTTP://www. CyPress?COM/?DOCID=44756 问候,Dana。 以上来自于百度翻译 以下为原文 Seems to me the algortithim has each node operating as a repeater requiring acknowlegement, and each node repeats to its neighbor until it achieves acknowlegement. So the packet propagates to each nearest neighbor until complete. http://www.cypress.com/?docID=44756 Regards, Dana. |
我认为在分组跳数消除了我对消息达到1以上的邻居节点的疑问。
现在我关注的案例2个节点同时寄一包。包会碰撞并被破坏吗? 再次感谢您的帮助!! -J 以上来自于百度翻译 以下为原文 I think that with the number of hops value in the packet eliminates my doubt about the message reaching more than 1 neighbour node. Now I am concern about the case 2 nodes send at the same time a packet. Will the packets collide and be destroyed? Thank you again, your help is appreciated !! - J |
该协议使用CSMA,就像以太网,以避免碰撞。
HTTP://www. CyPress?COM/?DOCID=46702 问候,Dana。 以上来自于百度翻译 以下为原文 Use CSMA in the protocol, much like Ethernet, to avoid collisions. http://www.cypress.com/?docID=46702 Regards, Dana. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 02:06 , Processed in 0.804390 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3851
