电子发烧友论坛|
你好
我正在玩ST25DV_Discovery_ANT_C6和ST25R3911B-DISCO开发板来测试能量收集功能。我的测试的一个结果是,输出电压V_EH被限制为大约。 3.4V尽管我在任何应用笔记或数据表中都找不到任何表述。 R = 10kOhm 在写入ST25DVxxx的数据表中,电压V_EH未被调节。如果这是真的,我无法理解我的测量结果。 你对这种行为有任何言论吗? 谢谢和最好的问候 马尔科 #energy-harvesting#st25dv64k#st25r3911b-disco 以上来自于谷歌翻译 以下为原文 Hi I'm playing around with an ST25DV_Discovery_ANT_C6 and an ST25R3911B-DISCO development board to test the energy harvesting features. One result of my tests yields, that the output voltage V_EH is limitted to approx. 3.4V eventhough I can't find any explenation therefore in any application note or datasheet. R = 10kOhm In the datasheet of the ST25DVxxx is written, that the voltage V_EH is NOT regulated. If that's true, I'm not able to understand my measurements. Do you have any explenation for this behavior? Thanks and best regards Marco #energy-harvesting #st25dv64k #st25r3911b-disco |
1个回答
亲爱的马可,
首先,感谢您考虑使用ST25DVxxx。 您的测量实际上是正确的。 V_EH输出确实不受管制,但内部受限。 V_EH输出直接取决于AC0 / AC1天线线圈上施加的电压。 如果RF场功率很强,天线线圈上的电压可以上升到高值(远大于10V)。 为了保护标签免受AC0 / AC1上的那些高电压的影响,有一个内部钳位机制将该电压限制为标签可以支持的值。由于V_EH输出电压直接取决于AC0 / AC1电压,因此也受此钳位值的限制。 这就是为什么你看到3.4V左右的限制(钳位实际上并不完美,RF场功率值非常高,V_EH电压可能升至4V以上)的原因。 您可以在图3和图4的应用笔记AN4913中看到,V_EH电压限制在3V和4V之间。这是由于钳位。当RF场功率高于6A / m时,钳位使电压稍微上升,V_EH> 4V。 希望这能回答你的问题。 最好的祝福。 以上来自于谷歌翻译 以下为原文 Dear Marco, First, thank you for considering the ST25DVxxx. Your measurement is actually correct. The V_EH output is indeed not regulated, but is internally limited. The V_EH output directly depends on the the voltage applied on the AC0/AC1 antenna coils. Voltage on the antenna coil can rise up to high values (much more than 10V) if RF field power is strong. In order to protect the tag from those high voltage on AC0/AC1, there is a internal clamp mechanism which limits this voltage to values that the tag can support. As V_EH output voltage directly depends on AC0/AC1 voltage, it is also limited by this clamping value. This is the reason why you see a limitation around 3.4V (the clamp is actually not perfect and with very high RF filed power values, it is possible for the V_EH voltage to rise above 4V). You can see in the application note AN4913 in figures 3 and 4 that the V_EH voltage is limited to values between 3V and 4V. This is due to the clamp. When the RF field power is above 6A/m, the clamp let the voltage rise a little bit and you can have V_EH>4V. Hope this answers your question. Best regards. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 22:44 , Processed in 0.851537 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2555
