是否可以在两个GTP上对齐tx串行差分信号。
Spartan 6直流开关特性规格表示最大偏斜 启用低延迟时为400ps 但我想知道是否可以实际对齐我的Eband I和Q通道的tx边缘 它们以1.25Gbps的速度运行。 400ps是我的线路费率的一半! 我需要他们对齐。 我查看了通道绑定,但这只是通过使用对齐字符来补偿偏斜。 我需要在低延迟模式下运行,没有偏差! 那里的任何人都知道如何边缘对齐GTP发射器的输出? 谢谢 以上来自于谷歌翻译 以下为原文 Is it possible to align the tx serial differential signals on two GTPs. The Spartan 6 DC switching characteristics spec says the maximum skew is 400ps when low latency in enabled. But I would like to know if its possible to actually align the tx edges for my Eband I and Q channels which are running at 1.25Gbps. 400ps is half the period of my line rate! I need them to be aligned. I looked into channel bonding, but that just compensates for the skew by using alignment characters. I need to run in low latency mode with no skew! Anyone out there know how to edge align the output of the GTP transmitters? Thanks |
1个回答
嗨,可以通过绕过缓冲器并使用相位对齐来减少TX通道到通道的偏斜。
不可能使偏斜为零。但如果偏斜小于400 ps,则确保无误操作。您是否看到任何问题?问候,Krishna -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Hi, The TX lane-to-lane skew can be reduced by bypassing the buffer and using the phase alignment. It is not possible to make the skew zero. But if the skew is less than 400 ps then the error free operation is ensured. Are you seeing any issues? Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
656浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
463浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
226浏览 1评论
669浏览 0评论
1864浏览 0评论
GMT+8, 2024-10-1 19:19 , Processed in 1.156527 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
