电子发烧友论坛扫一扫,分享给好友
在我看来,当我增加驱动强度时,例如:
更改以下约束: NET“net_name”drive = 2; 至 NET“net_name”drive = 16; 信号的上升时间会减少。 我通过DSO(数字式振荡器)检查它,有趣的是,当我使用探头时,结果与我的假设一致。 但是当我通过SMA连接器使用通信线路时,上升时间几乎没有变化 愿任何人解释一下吗? 提前致谢 以上来自于谷歌翻译 以下为原文 In my view, when I increase the drive strength ,for example: change the following constraint: NET "net_name" drive = 2; to NET "net_name" drive = 16; the signal 's rise time will decrease. I check it by the DSO(digital storate osciloscope ),Intrestly,when I use the probe, the result agree with my suppose. But when I use the communication line through the SMA connector , the rise time is nearly unchanged May anyone give an explanation ? Thanks in advance |
3个回答
G,
您应该使用IBIS模型和信号完整性模拟器。 阻抗匹配,pcb传输线的质量,终端的电容和电感将极大地影响信号的形状。 测量装置也会影响您在示波器上看到的信号 - 通常测量基本上是不可能的(您可以看到探头的效果及其接线,由信号激发)。 没有这么简单的结论是有效的(即使是远程的)。 信号完整性是一个独立的领域,全职工程师获得了不错的薪水。 http://www.google.com/url?sa=t&rct=j&q=xilinx%20signal%20integrity&source=web&cd=1&cad=rja&ved=0CCoQFjAA&url=http%3A% 2F%2Fwww.xilinx.com%2Fproducts%2Ftechnology%2Fsignal完整性%2F&安培; EI = Wh35UYCiEKrqiwLYkYH4Bg&安培; USG = AFQjCNEfN-wKIbjvliK2htYGNX25NbzlyQ&安培; BV ... Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 g, You should really use the IBIS models, and a signal integrity simulator. The impedance match, the quality of the pcb transmission line, the termination's capacitance, and inductance, will greatly affect the shape of the signal. The measurement means will also affect the signal you see on the scope -- often measuring is just basically impossible (you see the effects of the probe, and its wiring, as excited by the signal). No such simple conclusion is valid (even remotely so). Signal integrity is a field all its own, with full time engineers earning a good salary. http://www.google.com/url?sa=t&rct=j&q=xilinx%20signal%20integrity&source=web&cd=1&cad=rja&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.xilinx.com%2Fproducts%2Ftechnology%2Fsignal-integrity%2F&ei=Wh35UYCiEKrqiwLYkYH4Bg&usg=AFQjCNEfN-wKIbjvliK2htYGNX25NbzlyQ&bv... Austin Lesea Principal Engineer Xilinx San Jose |
谢谢奥斯汀的快速回复。
对我的知识感到羞愧。 我同意,你列出的所有因素都会影响信号。 测量装置也会影响您在示波器上看到的信号 - 通常测量基本上是不可能的(您可以看到探头的效果及其接线,由信号激发)。 当我们陷入困境时,我们会对信号产生影响。这一点也得到了我的支持。但是如果我们想知道生成的信号是否符合我们的要求,我们该怎么做? 谢谢 以上来自于谷歌翻译 以下为原文 Thank you austin for your quick reply . Shamed on my knowledge. All the factors you listed affect the signal ,I agree. The measurement means will also affect the signal you see on the scope -- often measuring is just basically impossible (you see the effects of the probe, and its wiring, as excited by the signal). When we mesure ,we have impact on the singal .This point is also supported by me.But if we want to figure out if the generated singal meets our request ,what we supposed to do? Thanks |
模拟它。
并阅读有关如何最好的衡量。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Simulate it. And read about how to best measure. Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
3119 浏览 7 评论
3408 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2875 浏览 9 评论
3967 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3058 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1332浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1171浏览 1评论
/9
GMT+8, 2025-12-3 17:27 , Processed in 0.685388 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3260
