电子发烧友论坛|
嗨,只是想知道是否有可能将GTP输出映射到没有为GTP提供的正常引脚?
例如,如何在spartan6(xc6lx45T-3fgg484)中将GTPA1_DUAL_X0Y0的MGTTXP1_101pin映射到E16,而不是作为专用引脚的B8。 我知道我不能直接映射它们但有没有办法通过一些缓冲区将内部信号传送到其他引脚? 问候 以上来自于谷歌翻译 以下为原文 Hi, Just wondering is it possible to map the GTP outputs to normal pins that are not deticated for the GTPs ? For example how can I map GTPA1_DUAL_X0Y0's MGTTXP1_101pin to E16 in spartan6 (xc6lx45T-3fgg484) instead of B8 which is the dedicated pin. I know I can't directly map them but is there a way to bring the internal signals via some buffers to other pins ? Regards |
4个回答
有专门的路由。
因此,您无法将GT的输入/输出驱动到非专用引脚。 这是一个设备限制。注意,克里希纳 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 There is a dedicated routing. Hence, you can't drive the inputs/outputs of GT to non-dedicated pins. This is a device limitation. Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful.View solution in original post |
有专门的路由。
因此,您无法将GT的输入/输出驱动到非专用引脚。 这是一个设备限制。注意,克里希纳 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 There is a dedicated routing. Hence, you can't drive the inputs/outputs of GT to non-dedicated pins. This is a device limitation. Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
你有什么特别的理由要这么做吗?
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Is there any specific reason why you want to do this?----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
在我目前的测试板中,这些引脚是浮动/ NC。
以上来自于谷歌翻译 以下为原文 In my current test board these pins are floating/NC. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 17:52 , Processed in 0.948750 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
639
