扫一扫,分享给好友
我有一个问题,出口PSoC创建者4.0项目到Eclipse霓虹灯。
软件版本 Eclipse:4.6 PSoC Creator:4.0.0.432 我安装了PSoCoCurtoEclipse IppIngV2.3.1.Zip,然后导出了PSOC创建者项目。 然后,用PSoC Creator Project目录在Eclipse中创建新的C项目,如PSoC Creator帮助中所示。 在设置交叉GCC命令的步骤中,我设置PSoC Creator ARM工具作为PSoC Creator帮助说明,但是按钮“Next”和“FEAR”被禁用(灰色OUTED)。 当我在Eclipse MARS2中尝试相同的序列时,它是成功的。 Eclipse霓虹灯不支持了吗? 问题解决方案 254.3 K 以上来自于百度翻译 以下为原文 I have a problem with exporting PSoC Creator4.0 project to Eclipse Neon. Version of software is Eclipse:4.6.2 PSoC Creator:4.0.0.432 I installed PSoCCreatorEclipse_Import_v2.3.1.zip, then exported PSoC Creator Project for eclipse. Then, created new C project in eclipse with PSoC Creator Project directory, as shown in PSoC Creator Help. At the step of set Cross GCC Command, I set PSoC Creator arm tools as PSoC Creator Help say, but button "Next" and "Finish" are disabled(gray outed). When I tried same sequence in eclipse Mars2, It was successful. Is Eclipse Neon out of support yet?
8个回答
确保Eclipse LUNA或稍后和Java 7或更高版本安装在系统中。
你可以看看这个TSG的“出口到第三方工具”一节。 HTTP://www. CyPress .COM/知识基础文章/故障排除PSOC创建者问题-KBA217566 以上来自于百度翻译 以下为原文 Make sure Eclipse Luna or later and Java 7 or later are installed in the system. You can look into this TSG for section "Exporting to Third-Party Tools"- http://www.cypress.com/knowledge-base-article/troubleshooting-psoc-creator-issues-kba217546 |
muuwfwr 发表于 2019-7-1 14:53 谢谢你的回答 Eclipse是“新生儿2”,比露娜晚得多。 Java版本为8,比7版本晚。 链接页面对我没有帮助。 还有什么要检查的吗? 以上来自于百度翻译 以下为原文 Thank you for answer, ANKS Eclipse is "NEON2", much later than Luna. Java version is 8, later than 7. Linked page didn't help me. Anything to check additionally? |
你好,米卡米三,
你能告诉我为什么这个符号在那里,就像在文件路径中附加的图像所示。 未注册的 20.4 K 以上来自于百度翻译 以下为原文 Hello Mikami-San, Can you tell me why this symbol is there as shown in image attached in the path of file.
因为我使用日文版本的Windows,符号“Yang-Mark”用来指示目录。 斜线和后斜线也可以使用。但情况并没有改变,尽管使用斜线代替日元标记。 使用SLAH.PNG 69.6 K 以上来自于百度翻译 以下为原文 Because I use Japanese version of Windows, the symbol "Yen-mark" is used to indicate directory. Slash and Back Slash also can be used. But situation doesn't change although Slash is used instead of Yen-mark.
你好,
请尝试提供有关系统的详细信息,如OS、RAM、.NET版本。 以上来自于百度翻译 以下为原文 Hello, Can you please try to provide details about your system like OS,RAM,.NET version |
嗨,安克斯 我的系统配置文件如下… PC-MK32 MEZDG(NEC) 操作系统:Windows 7专业32位 内存:4GB .NET版本:.NETFramework 4.4.1 以上来自于百度翻译 以下为原文 Hi ANKS My system profile is following... PC : PC-MK32MEZDG(NEC) OS : Windows 7 Professional 32bit RAM : 4GB .NET version : .NET Framework 4.6.1 |
当您选择从PSoC Creator导出的选项时,在最后一个选项中,“复制项目路径到剪贴板”。单击该选项。
然后在下一步(在导入Eclipse IDE时)取消选中“使用默认位置”复选框,并从剪贴板粘贴项目路径到项目“位置”选项。 我试图在Eclipse(下面详细说明)中这样做 C/C++开发人员的Eclipse IDE 版本:Neon发布(4.06)构建ID:20160613-1800 我发现“完成”不是禁用的(不是灰色的)。 以上来自于百度翻译 以下为原文 When you choose the option to Export from PSoC Creator,in the last you get the option "Copy Project Path to clipboard".Click that option. Then in next step (while importing to Eclipse IDE)uncheck the Use Default Location check box and paste from clipboard the project path into Project "Location" option. I tried to do so in Eclipse(Detail below)- Eclipse IDE for C/C++ Developers Version: Neon Release (4.6.0) Build id: 20160613-1800 I found that "Finish" is not disabled(not gray outed). |
muuwfwr 发表于 2019-7-1 15:51 嗨,ANKS 感谢您在相同的环境下进行测试。 最后,我找到了造成这种麻烦的原因。 在我的环境中,Eclipse的默认工作区设置为“c:/WorkStudio”。 在Eclipse工作区下,我的项目目录是“C/:WorkStudio/WorkStudio”项目名称“/”。 我尝试将默认工作区更改为不同的目录,然后成功了。 以上来自于百度翻译 以下为原文 Hi, ANKS Thank you for your testing in same environment. Finally, I found the cause of this trouble. In my environment, the default workspace of Eclipse is set to "C:/workspace". My project directory is "C:/workspace/'project name'/", under the Eclipse workspace. I tried changing default workspace to different directory, then It was successful. |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2102 浏览 1 评论
1848 浏览 1 评论
3666 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1783 浏览 6 评论
1533 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
564浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
418浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
434浏览 2评论
380浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
911浏览 2评论
GMT+8, 2024-12-22 10:39 , Processed in 0.989472 second(s), Total 90, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
