扫一扫,分享给好友
我从“AN664 77 PSOC35热敏电阻测温”中导入PSoC Creator CyComponentLibary.cyprj的“热敏电阻Calc”。
然后我创建了我的项目并添加了热敏电阻CALC组件。但是,当我构建我的项目时,总是有错误。请看下面的截图。令人惊讶的是,没有任何错误通知,而我建立了原产地AN664 77项目。并且配置窗口在它们之间是不同的。 此外,组件目录中没有组件预览。似乎没有成功的进口。但我不知道为什么。有人能帮忙吗? SNAP3.JPG 169.6 K 以上来自于百度翻译 以下为原文 I have imported "Thermistor_Calc" to PSoC Creator CyComponentLibary.cyprj from "AN66477-PSoC35 Temperature Measurement with Thermistor" . Then I created my project and add the Thermistor_Calc component. But there always has error while I built my project. See below screenshots. And it is surprising that no any error notice while I built the origin AN66477 project. And the config window is differenct between them. Also, there is no Component Preview in Component Catalog. Seems it has not been imported successful. But I do not know why. Anyone can help?
5个回答
这里是一个完整的屏幕截图与错误描述。
SNAP4.JPG 192.1 K 以上来自于百度翻译 以下为原文 Here is a complete screenshots with error description.
嗨,WeiBiao,
我认为你导入热敏电阻CALC组件的方式存在问题。 与AN相关联的项目有一个名为TyListB文件夹的热敏电阻CalcIV1V0.0.CYLIB。这个CYLB应该被用来增加对需要这个组件的项目的依赖性。 因此,在您想要使用热敏电阻CLAC组件Goto Project和Gt依赖项的项目中 “依赖项”对话框打开。在用户依赖项中,单击新条目。 现在选择热敏电阻CalcV1V0在热敏电阻CalcV1V0.0.CYLB文件夹下。 单击确定。 现在,组件将出现在您的组件目录中,在热敏电阻器文件夹下的一个名为CyReF的新选项卡中。下面的快照显示依赖关系对话框。 以上来自于百度翻译 以下为原文 Hi WeiBiao, I think there is an issue with the way in which you are importing the Thermistor_Calc component. The project associated along with the AN has a cylib folder named Thermistor_Calc_v1_0.cylib. This cylib should be used to add dependency to the project which requires this component. Hence, in the project where you want to use the Thermistor_Clac Component go to Project > Dependencies The Dependencies dialog box opens. In the User Dependencies, click on New Entry. Now select Thermistor_Calc_v1_0 under Thermistor_Calc_v1_0.cylib folder. Click OK. Now the Component will appear in your component catalog in a new tab called CYRef under Thermistor folder. The snap shot below shows the Dependencies dialog box. |
亲爱的DASQ:
太棒了!误差得到了解决。谢谢! 但我不知道为什么其他组件可以很容易地导入?不需要设置依赖项吗?像SGPIO还是FanController? 以上来自于百度翻译 以下为原文 Dear dasq: It is great ! The error has been solved. Thanks! But I do not know why other component can be import easily? No need to set the Dependencies? Like SGPIO or FanController? |
嗨,WeiBiao,
我不知道为什么在您的情况下直接导入自定义组件会导致错误。 在PSoC Creator中,组件的导入创建项目中组件的本地副本。可以修改此组件。 当依赖项添加到组件时,自定义组件可以在项目中使用,但CANOPT将被修改。 以上来自于百度翻译 以下为原文 Hi WeiBiao, I am not sure why in your case direct importing of the custom component resulted in an error. In PSoC Creator, importing of component creates a local copy of the component in the project. This component can be modified. When dependency is added to a component, the custom component can be used in the project, but cannopt be modified. |
WeiBiao
我认为您的问题的答案是,当导入其他组件时,可能不存在底层相关的库,但我不熟悉SGPIO或FAND控制器。 如果对这些项目有潜在的依赖性,那么您可能已经在设计中拥有这些DENDECDES了。 以上来自于百度翻译 以下为原文 WeiBiao, I think the answer to your question is when importing other components there is probably not an underlying dependent library, but I am not familiar with the SGPIO or FanController to be sure. If there is an underlying dependency for those projects, it might be that you already have those dependecies in your design? |
只有小组成员才能发言,加入小组>>
740个成员聚集在这个小组
加入小组1980 浏览 1 评论
1739 浏览 1 评论
3514 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1670 浏览 6 评论
1449 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
227浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
130浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
325浏览 2评论
274浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
456浏览 2评论
GMT+8, 2024-8-23 09:19 , Processed in 0.905104 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
