电子发烧友论坛|
使用N5244A和固件A.09.85.06,是否可以在SMC测量通道中显示电源I / O(引脚7,A | 1)的电压?
我已经能够在标准测量通道中执行此操作,但无法在SMC通道中找到接收器测量选择。 我正在测试一个带有输出检测器的转换器,并希望在AM / AM AM / PM测量期间显示它的性能。 在此先感谢您的帮助/建议! 以上来自于谷歌翻译 以下为原文 Using N5244A with firmware A.09.85.06, Is it possible to display the Voltage at the Power I/O (Pin 7, A|1) in SMC measurement channel? I have been able to do this in standard measurement channel but cannot find receiver measurement selection in SMC channel. I am testing a converter that has an output detector and want to display it's performance during AM/AM AM/PM measurement. Thanks in advance for help/suggestions! |
10个回答
您当然可以在SMC频道中测量AI1(模拟输入1):http://dl.dropbox.com/u/87949221/SMCMeas.jpg!
以上来自于谷歌翻译 以下为原文 you can certainly measure AI1 (Analog Input 1) in the SMC channel: !https://dl.dropbox.com/u/87949221/SMCMeas.jpg! |
Topcbpcba 发表于 2019-6-25 13:32 感谢您的回复,我发现了它。 问题是当我将它添加到我想要使用它的.CSA时,PNAX崩溃了。 我将提交CSA和崩溃文件...... 以上来自于谷歌翻译 以下为原文 Thanks for the response, I found it. Problem is PNAX is crashing when I add this to the .CSA where I want to use it. I will submit CSA and crash files... |
你可能会回到9.80分支再看看。 我们明天将对此进行跟进,看看我们是否可以复制它。 如果你发送了CSA,那就好了。 顺便说一下,这是专门为一个客户添加的,用于测试毫米波无线链路上的探测器输出电压,因此可能没有进行过广泛的测试。 我要求我们还将您的用例添加到回归测试中。 以上来自于谷歌翻译 以下为原文 you might roll back to 9.80 branch and look again. We'll follow up on this tomorrow to see if we can replicated it. Be good if you do send a CSA. BTW, this was added specifically for one customer to test their detector output voltage on a mm-wave wireless link, so it may not have had extensive testing. I'll request that we also add your use case to the regression test. |
您好Dr.博士,感谢您对此的回应/关注!
我已经提交了CSA和崩溃文件,并且Ballo先生昨晚能够重现他的设置。 我能用9.80分支打开9.85.06创建的.CSA吗? 今天下午我会试着在机器上抽出一些时间。 再次感谢您的支持! 以上来自于谷歌翻译 以下为原文 Hello Dr., Thanks for your response/attention to this! I have submitted CSA and crash files and Mr. Ballo was able to reproduce on his setup last night. Will I be able to open .CSA, created in 9.85.06, with 9.80 branch? I will try to get some time on the machine this afternoon. Thanks again for your support! |
linlin10 发表于 2019-6-25 14:14 很不幸的是,不行。 我将与Dave(Ballo)核对,看看他是否会在较旧的转速上设置测量值。 如果是这样,也许他可以向您发送旧版本的已保存文件。 我希望我们能够迅速处理这个问题。 以上来自于谷歌翻译 以下为原文 unfortunately, no. I will check with Dave (Ballo) and see if he will setup the measuement on an older rev. If so, maybe he can send you a saved file for the older rev. I expect we will attend to this issue quickly. |
今天早上我在PNAX上得到了一些时间,我找到了一个解决方法......我复制了通道并禁用了相位测量。 禁用相位时,激活模拟输入走线不会导致PNAX崩溃。 如果我重新启用阶段,PNAX将崩溃。 星期五快乐 :) 以上来自于谷歌翻译 以下为原文 I got some time on the PNAX this morning and I have found a workaround... I have copied the channel and disabled phase measurement. When phase is disabled, activating Analog input trace does not cause PNAX to crash. If I re-enable phase the PNAX will crash. Happy Friday :) |
感谢您提供更多信息。
我已经复制了这个问题,并且我已经实现了修复。 你想要修复测试版吗? 如果是这样,我可以向您发送详细信息的PM(将在下周初提供)。 否则,该修复程序将在下一个公开发布中提供 - 暂定于4月初发布。 您的解决方法(不使用“阶段”属性)也可以使用。 以上来自于谷歌翻译 以下为原文 Thank you for the additional information. I have reproduced the issue, and I have implemented a fix. Would you like a beta with the fix? If so, I can send you a PM with the details (it will be available early next week). Otherwise, the fix will be available in the next public release - tentatively scheduled for early April. Your work-around (not using the "phase" attribute) will also work. |
谢谢,是的,我会通过修复获得测试版。
以上来自于谷歌翻译 以下为原文 Thank you, yes, I would to get the beta with fix. |
该缺陷在测试版Z.09.81.52或更高版本中得到修复,可在此处找到(例如PNA_Z09.81.54.exe)。
此修复程序还将在客户版本A.09.85.08中进行,该版本将于2013年4月初发布。 以上来自于谷歌翻译 以下为原文 This defect was fixed in beta release Z.09.81.52 or higher, which can be found here (e.g. PNA_Z09.81.54.exe). The fix will also be in customer version A.09.85.08 which will be released in early April, 2013. |
tan8561 发表于 2019-6-25 15:10 谢谢你,先生! 以上来自于谷歌翻译 以下为原文 Thank You Sir! |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 20:23 , Processed in 0.870305 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5205
