电子发烧友论坛|
在启动时,我会遇到以下崩溃:
---- [窗口标题] GPIF第二设计器 GPIF.II设计器遇到用户定义的断点。 [问题]导致程序停止正常工作的问题。请关闭这个程序。 [关闭程序] [调试程序] ----- 我在戴尔M400上运行Windows 7企业64位。它是一个集成了HD4000图形的四方I7。如果Iclick调试并使用VS2010,我可以看到下面的堆栈跟踪: KernelBase.dll!Debug清除()+0x2字节D3D9DLL!ReffiNeDeD()+0x1C字节D3D9DLL!CSWAPCART::GETBACKBUFER()+0x1E9字节WPFGFXV0300!CD3DSWAPLoC::In()+0x9f字节WPFGFXV0300!CD3DSWAPLCON::CREATE()+0x113字节WPFGFXV0300!CD3DVIECIELVEL1::CurdieAddioSavaChanIn()+0xD9字节WPFGFXV030.DLL!CD3DVIECIELVEL1::TestRunDealTrimeFalm()+0x17d字节WPFGFXV030.DLL!CD3DVIECIELVEL1::CaltReRealTebug格式()+0x76字节WPFGFXV0300!CD3DVEICEMANGER::CeaTeNeDeVice()+0x3FA字节WPFGFXV0300,DLL!CD3DVEICEMANGER::GETD3DDEVICE和PrimePARAMS()+0x251字节WPFGFXV030.DLL!CWSDPrReNelDave::CREATE()+0x8A字节WPFGFXV0300,DLL!CdTopTurnRealTest::In()+0x244字节WPFGFXV0300!DLL!CdTabPurnRealTest::CREATE()+0x12d字节WPFGFXV0300!CMILFactory::CeaDeaToPutrNeRealTrand()+0x116字节WPFGFXV0300!CsLaveWnDrEngRealTest::EnSerurEngRealtimeInalAuthor(+0x108字节)WPFGFXV0300!RelDead()+0x24字节WPFGFXV0300,DLL!ReNordTalkMeals::RelDead()+0x4e字节WPFGFXV0300!CyPosi::RelDead()+0x28字节WPFGFXV0300!CyPosi::PrimeDe合体()+0x10b字节WPFGFXV0300、DLL!CyPosi::Co()+0x52字节WPFGFXV030.DLL!CPartitionThread::ReReDealStudio()+0x28字节WPFGFXV0300!CPartitionThread::运行()+0x60字节WPFGFXV0300!CPartitionThread::THEAD主()+0x1C字节KELNEL32.DLL!BaseRealInthununk()+0xD字节NTDLL.DLL!RtUsSerthRead Stand()+0x21字节 以上来自于百度翻译 以下为原文 Immediately at startup, I get the following crash: ---- [Window Title] GPIF™II Designer [Main Instruction] GPIF™II Designer has encountered a user-defined breakpoint. [Content] A problem caused the program to stop working correctly. Please close the program. [Close the program] [Debug the program] ----- I am running Windows 7 Enterprise 64 bit on a Dell Precision M4700. It is a quad i7 with integrated HD4000 graphics. If I click debug and use VS2010, I can see the following stack trace: > KernelBase.dll!DebugBreak() + 0x2 bytes d3d9d.dll!BreakIfNeeded() + 0x1c bytes d3d9d.dll!CSwapChain::GetBackBuffer() + 0x1e9 bytes wpfgfx_v0300.dll!CD3DSwapChain::Init() + 0x9f bytes wpfgfx_v0300.dll!CD3DSwapChain::Create() + 0x113 bytes wpfgfx_v0300.dll!CD3DDeviceLevel1::CreateAdditionalSwapChain() + 0xd9 bytes wpfgfx_v0300.dll!CD3DDeviceLevel1::TestRenderTargetFormat() + 0x17d bytes wpfgfx_v0300.dll!CD3DDeviceLevel1::CheckRenderTargetFormat() + 0x76 bytes wpfgfx_v0300.dll!CD3DDeviceManager::CreateNewDevice() + 0x3fa bytes wpfgfx_v0300.dll!CD3DDeviceManager::GetD3DDeviceAndPresentParams() + 0x251 bytes wpfgfx_v0300.dll!CHwDisplayRenderTarget::Create() + 0x8a bytes wpfgfx_v0300.dll!CDesktopRenderTarget::Init() + 0x244 bytes wpfgfx_v0300.dll!CDesktopRenderTarget::Create() + 0x12d bytes wpfgfx_v0300.dll!CMILFactory::CreateDesktopRenderTarget() + 0x116 bytes wpfgfx_v0300.dll!CSlaveHWndRenderTarget::EnsureRenderTargetInternal() + 0x108 bytes wpfgfx_v0300.dll!CSlaveHWndRenderTarget::Render() + 0x24 bytes wpfgfx_v0300.dll!CRenderTargetManager::Render() + 0x4e bytes wpfgfx_v0300.dll!CComposition::Render() + 0x28 bytes wpfgfx_v0300.dll!CComposition::ProcessComposition() + 0x10b bytes wpfgfx_v0300.dll!CComposition::Compose() + 0x52 bytes wpfgfx_v0300.dll!CPartitionThread::RenderPartition() + 0x28 bytes wpfgfx_v0300.dll!CPartitionThread::Run() + 0x60 bytes wpfgfx_v0300.dll!CPartitionThread::ThreadMain() + 0x1c bytes kernel32.dll!BaseThreadInitThunk() + 0xd bytes ntdll.dll!RtlUserThreadStart() + 0x21 bytes |
1个回答
嗨,亚历克斯,
这可能是安装的问题。 请重新安装一遍好吗? 谢谢, 西克里希纳。 以上来自于百度翻译 以下为原文 Hi Alex, It might be the problem with installation. Can you please try re-installing it again. Thanks, sai krishna. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 02:27 , Processed in 0.635139 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1891
