扫一扫,分享给好友
我一直在使用CY8CKIT-0505LP做得很好,今天早上,我突然发现:“这个设备被认可了,但PSoC Creator现在不支持使用它。”这个设备被列为“CORTEX-M3”,旁边是一个感叹号。尝试连接和断开USB…重新启动PC…同样的信息。怎么了?有什么想法吗?谢谢。。。
以上来自于百度翻译 以下为原文 I have been working just fine with the CY8CKIT-050 5LP and this morning, all of a sudden, I get: "This device was recognized but PSoC Creator does not support using it at this time" The device is listed as "Cortex-M3" wtih an exclamation mark next to it. Tried connecting and disconnecting USB... Rebooting the PC.... Same message. What's wrong? Any ideas? Thanks... |
8个回答
而“信息”框放置在“CordX-M3”目标的顶部时说“这个设备已经被另一个客户使用”…然而,当重新启动PC并启动PSoC creator时,这种情况就发生了。
以上来自于百度翻译 以下为原文 And the "info" box when placed on top of the "Cortex-M3" target says "this device is already in used by another client"... and yet, this happens when rebooting the PC and starting PSoC creator. |
这是非常奇怪的消息,即使我正在使用PSoC5 JSE的ES芯片,我也从来没有看到过。
以上来自于百度翻译 以下为原文 Very strange message it is, I never saw that even if I'm using the ES chip of PSoC5 jsut now. |
我对这个PSoC的开发是新的,只是试图今晚开始。我得到了同样的信息。有没有解决这个问题的办法?谢谢!
以上来自于百度翻译 以下为原文 I am new to this PSOC development and just trying to get started tonight. I am getting this same message. Was there ever any resolution to this problem? Thanks! |
该消息意味着另一个应用程序已经打开调试接口。它经常发生在设备被调试/程序模式,没有正确复位(因为应用程序崩溃或被杀死或某物)只是重置板并重新启动PSoC程序员/创建者。
以上来自于百度翻译 以下为原文 The message means that another application has opened the debug interface. It often happens when the device has been put into debug/program mode and wasn't properly reset (because the application crashed or was killed or something) just reset the board and restart PSOC Programmer / Creator. |
我在我的两个程序员中得到了同样的错误。
这可能是什么原因呢? 以上来自于百度翻译 以下为原文 I am getting the same error infact I am getting this in two of my programmers. What can be the possible causes for it? |
CY8C3666 AXI-206设备也不包含在设备选择列表和创建者中,给出相同的错误。
以上来自于百度翻译 以下为原文 CY8C3866AXI-206 device also not included in the device selection list and creator giving same error. |
我使用的是创建者4 SP1,CY8C3666 AXI-206在支持的设备列表中。你需要更新吗?
鲍勃 以上来自于百度翻译 以下为原文 I am using Creator 4.0 SP1 and the CY8C3866AXI-206 is in the supported device list. Can it be you need an update? Bob |
只有小组成员才能发言,加入小组>>
747个成员聚集在这个小组
加入小组2040 浏览 1 评论
1791 浏览 1 评论
3598 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1721 浏览 6 评论
1485 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
444浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
311浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
386浏览 2评论
330浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
543浏览 2评论
GMT+8, 2024-10-20 22:14 , Processed in 1.294038 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
