电子发烧友论坛扫一扫,分享给好友
我有2个板,我与Psoc Creator 2:板A:CY8CITK-01与CY8C55家庭板B:CY8CITK-01与CY8C58LP家庭在A上,我可以闪光程序没有问题。但是在B上,我不能闪动程序,我得到错误:dg.M039:运行端口获取出错。可能没有附加设备,或者设备可能在另一个应用程序中使用。有什么问题吗?
MixPrim32.PNG 23.7 K 以上来自于百度翻译 以下为原文 I have 2 Boards and I work with Psoc Creator 2.0: Board A: CY8CKIT-001 with CY8C55 Family Board B: CY8CKIT-001 with CY8C58LP Family on Board A, I can flash the programm without problems. But on Board B, I can't flash the Programm, I get the error: dbg.M0039: There was an error running port acquire. There may be no devices attached, or a device may be in use by another application. what can be the problem?
7个回答
你是否考虑更新创建者为2.2?我不知道是否2已经“知道”PSoC5 LP。鲍勃
以上来自于百度翻译 以下为原文 Did you take account of to update Creator to 2.2? I do not know whether 2.0 already "knows" the PSoC5 LP. Bob |
根据发布公告,我发现创建者2.1是第一个支持PSoC5LP的。所以你应该升级到最新版本。(不管怎样推荐它)
以上来自于百度翻译 以下为原文 According to the release announcements I found Creator 2.1 is the first one to support PSoC5LP. So you should upgrade to the latest version. (which is recommended anyway) |
我有一个由三个电路板组成的系统:CY8CKIT-1001与CY8C55系列,我使用C造作2,但一个BOD是缺陷,我想用CY8C58LP家族来改变它。当我在C造作2.1中打开我的项目时,我得到了这个错误:SDB.M059:组件中的错误:Mistar可以。在PSoC 5设备上不支持CAN(Mistar CAN)组件。因为这个原因,我正在与创建者2一起工作。我怎样才能解决这个问题?
当做 以上来自于百度翻译 以下为原文 I have a system consisting of three Boards: CY8CKIT-001 with CY8C55 Family and I use Creator 2.0, but one Bord is defect and I want to change it with CY8C58LP Family. when I open my project in Creator 2.1, I get this error: sdb.M0059:Error in component: Master_CAN. The CAN (Master_CAN) component is not supported on the PSoC 5 device. for this reason, I'm working with Creator 2.0. how can I solve this problem? Regards |
也许,对这种情况最有经验的是柏树本身。提交一个技术案例(支持和社区&技术支持-gt;创建一个MyCase]。虽然有时可能需要一些时间,但你会得到帮助。鲍勃
以上来自于百度翻译 以下为原文 Probably, the most experienced with such a situation is Cypress itself. File a thechnical case (Support&Community->Technical Support -> Create a MyCase). Although sometimes it may take some time you will be helped. Bob |
在PSoC5上不支持CAN组件,因为它存在一些问题。它是在创建者的早期版本中,在问题被发现之前被移除的。这些问题用PSoC5LP进行了修正。因此,建议移至PSoC5LP。但为此,你需要升级到创建者2.1至少8,2.2SP1会更好。
以上来自于百度翻译 以下为原文 The CAN component is not supported on PSoC5 because there were some problems with it. It was in earlier versions of Creator, before the problems got detected, but got removed in later ones. These problems got corrected with PSoC5LP. So it is advisable to move to PSoC5LP anyways. But for that you need to upgrade to Creator 2.1 8at least, 2.2SP1 would be better). |
在执行过程中出现以下误差。请给出解决问题的步骤。
dg.M90039:运行端口获取出错。可能没有附加设备,或者设备可能在另一个应用程序中使用。 以上来自于百度翻译 以下为原文 the following error is occured during the implementation. kindly give the steps to resolve the problem. dbg.M0039: There was an error running port acquire. There may be no devices attached, or a device may be in use by another application. |
劫持一根2岁的线不是一个好主意。尽管如此,欢迎来到论坛!
可能没有附加设备,或者设备可能在另一个应用程序中使用。检查两者,重置您的PC。 给我们更多的信息: 你用哪种牌子的?工具箱?哪一个????PSoC给出了什么错误?你使用的实际创建者版本是什么?你能把你的整个项目发布出来,这样我们就可以看看你的所有设置了吗?要做到这一点,使用C造饰者和GT;文件-GT;创建工作区束(最小)并附加结果文件。 鲍勃 以上来自于百度翻译 以下为原文 Not a good idea to hijack a 2 year old thread. Nonetheless: Welcome in the forum! There may be no devices attached, or a device may be in use by another application. Check for both, reset your PC. Give us some more information:
Creator->File->Create Workspace Bundle (minimal) and attach the resulting file. Bob |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 09:38 , Processed in 1.001790 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1255
