电子发烧友论坛|
我们正在寻找井下高温的斯巴达替换零件。
我们错过了Spartan FPGA的终生购买。 看来Spartan 3A / 3E可能是一个长期的解决方案,如果它在可预见的未来不会被淘汰。 以上来自于谷歌翻译 以下为原文 We are looking for replacement part for the Spartan in hi temp downhole. We have missed the lifetime buy on the Spartan FPGA. It appears that Spartan 3A/3E could be a long term solution if it will not be obsoleted in the forseeable future. |
2个回答
男,
我会联系您当地的经销商,并要求他们联系Xilinx销售和营销部门,并回复您的建议。 据我所知,Spartan 3A / 3E是最新的(最后的)90nm产品,因此仍然可以广泛使用。 至于它们什么时候停产,这取决于Xilinx客户设计出来的速度,使用更新的产品,或者90年代流程本身在联华电子公司过时的时间。 Spartan2为250nm,据联合电子公司宣布为过程,而斯巴达2E为180nm。 Spartan是旧的4KXL部件,我相信它是350nm,现在已经太老了。 如果有的话,我会推荐Spartan 6(45nm三星工艺),因为它应该具有很长的使用寿命(体积比以前的任何系列都要大)。 Austin Lesea主要工程师Xilinx San Jose 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 m, I would contact your local distributor, and request that they contact Xilinx sales and marketing, an get back to you on a recommendation. As far as I know Spartan 3A/3E are the latest (last) 90nm products, and as such, are still widely available. As to when they will be discontinued, that depends on how quickly Xilinx customers design them out, and use newer products, or how soon the 90nm process itself is made obsolete at UMC. The Spartan2 was 250nm, which was declared obsolete as a process by UMC, as wasSpartan 2E, which is 180nm. Spartan was the old 4KXL part, which was 350nm, I believe, which is far too old now. If anything, I would recommend Spartan 6 (45nm Samsung process), as it should have a very long life (volumes are substantially larger than any previous family). Austin Lesea Principal Engineer Xilinx San JoseView solution in original post |
男,
我会联系您当地的经销商,并要求他们联系Xilinx销售和营销部门,并回复您的建议。 据我所知,Spartan 3A / 3E是最新的(最后的)90nm产品,因此仍然可以广泛使用。 至于它们什么时候停产,这取决于Xilinx客户设计出来的速度,使用更新的产品,或者90年代流程本身在联华电子公司过时的时间。 Spartan2为250nm,据联合电子公司宣布为过程,而斯巴达2E为180nm。 Spartan是旧的4KXL部件,我相信它是350nm,现在已经太老了。 如果有的话,我会推荐Spartan 6(45nm三星工艺),因为它应该具有很长的使用寿命(体积比以前的任何系列都要大)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 m, I would contact your local distributor, and request that they contact Xilinx sales and marketing, an get back to you on a recommendation. As far as I know Spartan 3A/3E are the latest (last) 90nm products, and as such, are still widely available. As to when they will be discontinued, that depends on how quickly Xilinx customers design them out, and use newer products, or how soon the 90nm process itself is made obsolete at UMC. The Spartan2 was 250nm, which was declared obsolete as a process by UMC, as wasSpartan 2E, which is 180nm. Spartan was the old 4KXL part, which was 350nm, I believe, which is far too old now. If anything, I would recommend Spartan 6 (45nm Samsung process), as it should have a very long life (volumes are substantially larger than any previous family). Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 16:23 , Processed in 0.721053 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2023
