电子发烧友论坛|
嗨,
刚刚开始在新的地方工作,我们正在使用STC58NE84xx。对我来说这是一个新的部分,我从来没有像这样复杂地使用微控制器。很简单:我正在尝试验证系统时钟频率。我认为它可以配置的最大值是180 MHz。我一直在阅读有关PLL等的许多文档,但是如你所知......它非常复杂。我想我想把时钟连接到外部引脚,以便我可以在示波器上查看它。似乎这可能是可能的。或者,是否有一个HAL功能只能找出所有配置寄存器的状态并返回系统时钟频率?任何帮助,将不胜感激。提前致谢。 #system-clock #oscillator#spc58 以上来自于谷歌翻译 以下为原文 Hi, Just started working at a new place and we are using a STC58NE84xx. It's a new part for me, I've never used a micro-controller as complex as this. Very simple: I'm trying to verify the system clock frequency. I think the maximum that it can configured for is 180 MHz. I've been reading many of the documents regarding the PLLs, etc but as you know ... it's pretty complicated. I'm thinking I'd like to get the clock to an external pin so that I can look at it on the scope. It seems like that may be possible. Or, is there a HAL function that will just figure out the state of all the configuration registers and return the system clock frequency? Any help would be appreciated. Thanks in advance. #system-clock #oscillator #spc58 |
2个回答
谢谢Erwan,
我真的不知道GitHub,所以我不得不花一些时间在那里闲逛。我是否必须注册一个帐户才能获得该代码?好吧,我会搞清楚的。我做了一些测试,试图间接地计算出时钟速度,我执行了一堆NOP并切换了GPIO并且(在减去开销之后)认为每个NOP需要大约18ns。我看看NOP(实际上是一个OR 0,0,0)应该花多少个时钟周期,但我还是找不到。我找到了大量的汇编指令清单,但没有提到每条指令需要多长时间。 我会继续研究这个。 麦克风 以上来自于谷歌翻译 以下为原文 Thanks Erwan, I don't really know about GitHub so I'll have to spend some time poking around in there. Do I have to sign up for an account to get that code out? Well, I'll figure it out. I did some testing to try to figure out the clock speed indirectly I executed a bunch of NOPs and toggled a GPIO and (after I subtracted the overhead) figured that each NOP takes about 18ns. I looked to see how many clock cycles a NOP (which is really an OR 0,0,0) should take but I have not been able to find that. I found a huge listing of assembly instructions but no mention of how long each instruction takes. I'll keep researching this. Mike |
二万
咦?这看起来像某种类型的操作系统调用。这对我有什么帮助? 如果我希望PLL0为400 MHz且PLL1为180 MHz且输入时钟为20 MHz,那么PLLDIG寄存器的设置应该是什么? 麦克风 以上来自于谷歌翻译 以下为原文 Erwan Huh? That looks like some type of operating system call. How will that help me? If I want PLL0 to be 400 MHz and PLL1 to be 180 MHz and my input clock is 20 MHz what should the settings be for the PLLDIG registers? Mike |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 12:17 , Processed in 0.719218 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4126
