电子发烧友论坛|
有没有办法在Spartan 6上对电池供电的AES密钥进行编程?
我想在将密钥提交到eFuse寄存器之前测试和验证操作(和可重新编程)。 我没有看到使用iMpact工具将密钥输入电池备份RAM的方法。 我唯一的选择是“program eFuse”并指向.nky文件,文档建议直接进入eFuse寄存器。 在相关的说明中,一旦密钥在eFuse中,并且config选项设置为始终使用eFuse密钥进行比特流解密,如何配置iMpact以重新编程我们的配置FLASH(BPI x8模式)? 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Is there a way to program the battery-backed AES key on the Spartan 6? I want to test and verify operations (and reprogramability) before I commit a key into the eFuse register. I do not see a way to get a key into battery-backed RAM using the iMpact tool. The only option I have is "program eFuse" and point to the .nky file and the documentation suggests this goes directly into the eFuse register. On a related note, once a key is in the eFuse, and the config option is set to always use the eFuse key for bitstream decryption, how can iMpact be configured to reprogram our configuration FLASH (BPI x8 mode)? Thanks for any assistance. |
6个回答
M.M,
密钥的JTAG编程指定它是电池支持的RAM还是熔丝密钥寄存器。 您可以选择要编程的编程。 选择BBRAM是一个很好的选择,可以解决问题,确保关键匹配,一切正常(在你真正去除之前)。 无论在efuse或BBRAM中使用密钥,您都可以通过JTAG始终使用非加密的比特流(请参阅配置用户指南,第83页,第5段。 奥斯汀 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 m.m, The JTAG programming of the key specifies if it is the battery backed RAM, or the fuse key register. You choose which one you want to program. Choosing the BBRAM is a good choice to trouble-shoot hte process, and ensure the key matches, and everything works (before you actually go and blow efuses). Reagrdless of having a key in efuse or BBRAM, you may always use a non-encrypted bitstream through JTAG (see the configuration users guide, pp 83, paragraph 5. Austin Austin Lesea Principal Engineer Xilinx San Jose |
M.M
但是,如果你编写那个神奇的位,cfg_aes_only,那么efuse将是从那时开始配置athat部分的唯一方法。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 m.m But, if you program that magic bit, cfg_aes_only, then the efuse will be the ONLY way to configure athat part from then on. Austin Lesea Principal Engineer Xilinx San Jose |
那么,我在哪里设置BRAM与eFuse编程选项?
在iMpact下,我只能看到在“Program eFuse”菜单选项下编写密钥的能力。 我是否使用iMpact以外的其他东西? 如果我需要使用iMpact,你能指出我可以选择的选项吗? 感谢你的协助。 以上来自于谷歌翻译 以下为原文 So, where do I set the option to program BRAM vs. eFuse? Under iMpact, I only see the ability to program a key under the "Program eFuse" menu option. Do I use something other than iMpact? If I need to use iMpact, can you point me to where the option is selectable? Thanks for your assistance. |
M.M
您的JTAG链中有多个设备吗? ISE 13中的错误会阻止对efuse密钥进行编程。 见AR42682。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 m.m Do you have more than one device in your JTAG chain? A bug in ISE 13 prevents programming the efuse key. See AR42682. Austin Lesea Principal Engineer Xilinx San Jose |
m.m或许其他人更熟悉编程密钥可以回复吗?谢谢,
Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 m.m Perhaps someone else more familiar with programming the key can respond? Thanks, Austin Lesea Principal Engineer Xilinx San Jose |
你好,
我只是试了一下,我认为这是将Key编入BBRAM的严格方法: 在IMPACT中: - 初始化JTAG链 - 在FPGA上单击鼠标右键 - “分配新配置文件” - 选择你的nky-File(右键) - 编程你的FPGA,例如 “程序”来自左侧的“可用操作” 现在您可以分配您的位文件并对其进行编程.... 适合我 以上来自于谷歌翻译 以下为原文 Hi there, I just tried it and I think this is the rigth way to program the Key into BBRAM: In IMPACT: - initialize the JTAG chain - click with right mouse button on your FPGA - "assign new configuration file" - choose your nky-File (with the right key in it) - program your FPGA e.g. "program" from "available operations" on the left now you can assign your bit-file and program it.... works for me |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 06:47 , Processed in 0.766378 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4080
