嗨,
我是FPGA编程的小伙子所以请忍受我看似愚蠢的查询。 我需要存储大约1MB长的位序列。 它是一个恒定的比特流,在编程电路板时我会知道。 我需要能够从此流中一次读出一位。 我相信我需要将这个位序列放在板上的闪存中,因为即使没有给电路板供电,我也需要它。 有任何线索如何做? 有人能指点我一个关于如何将这些数据放在闪存上的教程以及如何将其读出来处理它的其他模块吗? 提前致谢。 Gururaj 以上来自于谷歌翻译 以下为原文 Hi, I am a noob at FPGA programming so please bear with my seemingly stupid queries. I need to store a sequence of bits around 1MB long. It is a constant bitstream and will be known to me at the time of programming the board. I need to be able to read out one bit at a time from this stream. I believe I need to put this sequence of bits in the flash memory on the board since I need it to be persistent even when power is not given to the board. Any clue how that is to be done? Can someone point me to a tutorial on how to put this data on the flash and how to read it out to some other module that processes it? Thanks in advance. Gururaj |
4个回答
G,
这取决于电路板,闪光灯以及配置(连接)的方式。 你在和哪个董事会合作? 一旦我们知道了,那么我会查看该板的文档,特别是“基础系统构建器”示例设计。 然后我会尝试一个接近你想做的BSB设计示例,在你能够在工具中复制它之后,我会考虑为它添加另一个接口(读取和写入flash)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 g, It depends on the board, the flash, and how it is configured (connected). What board are you working with? Once we know that, then I would look at the documentation for that board, and specifically the "base-system builder" example designs. Then I would run through an example BSB design that is close to what you want to do, and after you are able to replicate it in the tools, I would look at adding another interface to it (to read and write the flash). Austin Lesea Principal Engineer Xilinx San Jose |
我正在使用Spartan 3E入门套件板。
我用USB线编程。 根据此处列出的规格(http://www.xilinx.com/products/boards-and-kits/HW-SPAR3E-SK-US-G.htm),它说Xilinx器件:Spartan-3E FPGA(XC3S500E-4FG320C) )CoolRunner™-II CPLD(XC2C64A-5VQ44C)平台闪存(XCF04S-VO20C)时钟:50 MHz晶振时钟振荡器内存:128 Mbit并行Flash16 Mbit SPI Flash64 MByte DDR SDRAM XCF04S-VO20C有4Mb闪存,还有另外两个条目 说128 Mbit并行Flash16 Mbit SPI Flash。 我用哪一个呢? 以上来自于谷歌翻译 以下为原文 I am using the Spartan 3E starter kit board. I program it with a USB cord. From the specifications listed here (http://www.xilinx.com/products/boards-and-kits/HW-SPAR3E-SK-US-G.htm) , it says Xilinx Devices: Spartan-3E FPGA (XC3S500E-4FG320C) CoolRunner™-II CPLD (XC2C64A-5VQ44C) Platform Flash (XCF04S-VO20C) Clocks: 50 MHz crystal clock oscillator Memory: 128 Mbit Parallel Flash 16 Mbit SPI Flash 64 MByte DDR SDRAM The XCF04S-VO20C has 4Mb flash memory while there are two other entries saying 128 Mbit Parallel Flash 16 Mbit SPI Flash. Which one do I use for this? |
G,
SPI闪存可能是一个更容易使用这个板的接口。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 g, The SPI flash might be a much easier interface to usemon this board. Austin Lesea Principal Engineer Xilinx San Jose |
嗨奥斯汀,谢谢你的帮助。
我想我将能够弄清楚如何使用基本系统构建器向导在Flash中存储一个bitream。 如果我理解正确,我基本上是使用这个基本系统构建器向导在FPGA上构建自己的微控制器。 现在我想调制这个我编写了另一个verilog模块的比特流。 我可以用这个基于fpga的微控制器以某种方式连接那个verilog模块吗? 我该怎么用? 我能阅读的一些术语可以帮助我实现这一目标会有所帮助。 谢谢 Gururaj 以上来自于谷歌翻译 以下为原文 Hi Austin, Thanks for all your help. I guess I will be able to figure out how to store a bitsream in the flash by using base system builder wizard. If I have understood right, I am basically building my own microcontroller on the FPGA with this base system builder wizard. Now I want to modulate this bitstream for which I have written another verilog module. Can I interface that verilog module somehow with this microcontroller built on the fpga? What do I use for that? A few terms that I could read about that would be help me achieve this would be helpful. Thanks Gururaj |
只有小组成员才能发言,加入小组>>
2182 浏览 7 评论
2618 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2213 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
453浏览 1评论
1541浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2187浏览 0评论
516浏览 0评论
1660浏览 0评论
GMT+8, 2024-5-16 08:30 , Processed in 1.272526 second(s), Total 85, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
