电子发烧友论坛|
你好,
与ZEAN有限公司的ZA10S20(1280X720/30FPS/YUV422)接口FX3接口。 我有一个黑屏,所以我检查了AN7799中的故障排除列表。 用UART校验增帧计数器,可以。 我想检查下一个项目,如何检查每帧发送的数据总量? 多谢。 MayFLY。 以上来自于百度翻译 以下为原文 Hi, I modified AN75779_001-75779_0B source code to interface FX3 with ZA10S20(1280x720/30fps/YUV422) of Zeeann Co.,Ltd. I have a black screen, so I checked troubleshooting list in the AN75779. I have checked the increasing frame counter using UART, It is ok. I want to check next item, how to check the total amount of data being sent out per frame? Many thanks. MayFLY. |
2个回答
HiMayFLY
在UVC应用程序线程条目的TIF((HIFTF)和AMP;(PodCurt==CuSnCurt))中,可以打印生产者计数,以查看每个帧发送了多少缓冲区,并且在添加最后一个缓冲区的头的情况下,可以打印SuffEddiBuff.Currar来查找最后一个B中的字节数。UFFER。 但是,您确定没有任何提交缓冲区故障吗?? 破布 以上来自于百度翻译 以下为原文 Hi MayFLY, In the if ((hitFV) && (prodCount == consCount)) block of UVC app thread entry you can print the producer count to see how many buffers were sent per frame , and also where the header for the last buffer is added you can print the produced_buffer.count to find the number of bytes in the last buffer. But are you sure you dont get any commit buffer failures ?? Rags |
高破布,
谢谢你的回复。 我买了一个PCI到USB 3.0主机接口卡,因为我的桌面PC没有USB 3.0。 我修改了AN75 79 SouCE代码,然后构建DoFulm IMGTO目标板。 当运行虚拟DUB以检查图像时,帧速率为1500 fPS,输出大小为640x480。 此时,我可以通过UART看到缓冲区失败消息。 因此,我修改传感器的源代码来设置VGA/15FPS。 再试一次,在开始帧计数之前有一个或两个缓冲器失败消息。 并且帧计数值正在增加。 顺便说一下,我的董事会有个问题。几乎UART港口不是工作,有时是工作。 所以我刚发了一封邮件给Cuffer-CaleCyPress。 多谢。 李杰。 以上来自于百度翻译 以下为原文 Hi Rags, Thanks for your reply. I bought a PCI to USB3.0 host interface card, because my desktop PC does not have USB3.0. I modified AN75779 souce code and build then dowload img to target board. When I run virtualDub to check image, frame rate was 15.00fps and output size was 640x480. At this time, I can see the buffer failures message through UART. So, I modify source code for sensor to set VGA/15fps. And try again, there was one or two buffer failures message before starting frame counting and frame count value was increasing. By the way, my board has a problem. Almost UART port is not work, sometimes is work. so I just sent a email to customercare@cypress.com for asking after serive. Many thanks. BJ Lee. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 06:10 , Processed in 0.880574 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3748
