我的问题来自bank 1的差分时钟(PinIO_L40P_GCLK11_1 / IO_L40N_GCLK10_1)通过IODELAY和BUFIO路由到PLL。
问题:xilinx ISE不允许我将输出信号路由到bank 2(原理图中的变体B) - bank 0(原理图中的变体A)工作正常。 变体B将导致错误消息(见下文)。 额外的BUFG没有帮助(只有全局路由问题)。 错误:位置:1238 - 组件“XLXI_52 / PLL_ADV”没有可行的站点。 该组件有6个可能的位置:位置“PLL_ADV_X0Y0”由于以下条件而无法用于放置组件:错误:放置:1201 - PLL类型的组件不可放置,因为它具有放置在区域中的锁定负载: CLOCKREGION_X0Y0。 存在一个限制,即PLL的时钟负载必须位于PLL的水平相邻时钟区域。 建议将BUFG用于此时钟信号,以便将时钟负载放置在器件的任何位置。 如果时钟驱动器或时钟负载被锁定或区域分组,请确保它们被约束到水平相邻的时钟区域。由于跟随误差条件,位置“PLL_ADV_X0Y1”不能用于放置组件:错误:放置:1201 - PLL类型的组件不可放置,因为它具有放置在区域中的锁定负载:CLOCKREGION_X0Y0。 存在一个限制,即PLL的时钟负载必须位于PLL的水平相邻时钟区域。 建议将BUFG用于此时钟信号,以便将时钟负载放置在器件的任何位置。 如果时钟驱动器或时钟负载被锁定或区域分组,请确保它们被约束到水平相邻的时钟区域。第4.2节架构特定功能的初始放置(校验和:c263894c)实时:7秒完成Placer完成的总实时时间: 7秒Placer完成的总CPU时间:7秒ERROR:Pack:1654 - 时序驱动的放置阶段遇到错误。 感谢帮助 以上来自于谷歌翻译 以下为原文 My Problem A differential clock from bank 1 (PinIO_L40P_GCLK11_1/ IO_L40N_GCLK10_1) is routed via IODELAY and BUFIO to a PLL. Problem: xilinx ISE does not let me route the output signal to bank 2 (Variant B in the schematic) - bank 0 (Variant A in the schematic) works fine. Variant B will cause the error message (see below). Additional BUFG does not help (only a global routing problem). ERROR:Place:1238 - Component "XLXI_52/PLL_ADV" does not have a feasible site. There are 6 potential locations for the component: Location "PLL_ADV_X0Y0" cannot be used to place the component due to following error condition(s): ERROR:Place:1201 - Component because it has locked loads placed in regions: CLOCKREGION_X0Y0. There is a restriction that the clock loads of a PLL must be in a horizontally adjacent clock region to the PLL. It is recommended that a BUFG be used for this clock signal so that the clock loads can be placed anywhere on the device. If the clock driver or clock loads are locked or area grouped, please ensure that they are constrained to horizontally adjacent clock regions. Location "PLL_ADV_X0Y1" cannot be used to place the component due to following error condition(s): ERROR:Place:1201 - Component because it has locked loads placed in regions: CLOCKREGION_X0Y0. There is a restriction that the clock loads of a PLL must be in a horizontally adjacent clock region to the PLL. It is recommended that a BUFG be used for this clock signal so that the clock loads can be placed anywhere on the device. If the clock driver or clock loads are locked or area grouped, please ensure that they are constrained to horizontally adjacent clock regions. Phase 4.2 Initial Placement for Architecture Specific Features (Checksum:c263894c) REAL time: 7 secs Total REAL time to Placer completion: 7 secs Total CPU time to Placer completion: 7 secs ERROR:Pack:1654 - The timing-driven placement phase encountered an error. Thanks for help |
7个回答
什么FPGA?哪个版本的ISE?
------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 What FPGA? Which version of ISE? ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
Spartan6 XC6SLX16(CPG196)
Xilinx ISE设计套件13.2 以上来自于谷歌翻译 以下为原文 Spartan6 XC6SLX16 (CPG196) Xilinx ISE Design Suite 13.2 |
输出时钟的频率是多少?
如果它不是太高,你可以使用BUFG和 ODDR2驱动输出引脚。 您可能需要调整时钟阶段来处理 延迟的差异,但BUFG将允许您到达任何银行。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 What's the frequency of the output clock? If it's not too high, you could use a BUFG and ODDR2 to drive the output pin. You might need to adjust the clock phase to deal with the difference in delay, but the BUFG would allow you to reach any bank. -- Gabor -- Gabor |
对于BUFG来说,648 MHz太快了。
它们的运行速度最高可达400 MHz。 我认为648 MHz也在推动 通用LVDS I / O的限制。 你有可能使用2分频时钟吗? - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 648 MHz is too fast for a BUFG. They only run up to about 400 MHz. I think 648 MHz is also pushing the limits of the general purpose LVDS I/O. Any chance you can use a divide-by-2 clock? -- Gabor -- Gabor |
谢谢 - 我们已经针对逻辑块交换了BUFG。
路由工作令人惊讶.648MHz适用于I / O--我们有另一种设计基于时钟运行.-- Tony 以上来自于谷歌翻译 以下为原文 Thanks - We have exchanged BUFG against a logic block. Routing worked surprisingly. 648MHz works fine for the I/O - We have another design running based on the clock already. --Tony |
BUFPLL设计用于缓冲从PLL到IO的高频时钟。
- 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 BUFPLL is designed for buffering high-frequency clocks from PLL to IO. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
2337 浏览 7 评论
2756 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2229 浏览 9 评论
3306 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2383 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
692浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
489浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
270浏览 1评论
698浏览 0评论
1893浏览 0评论
GMT+8, 2024-10-18 18:57 , Processed in 1.258502 second(s), Total 59, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
