我们正在尝试使用Motor Profiler实用程序设置一个小型BLDC电机。
-X-细胞核 - IHM07M1 -FOC SDK 4.3 - 自定义电机:2极对BLDC 18VDC,2W @空载,4000 rpm 通过此设置,Motor Profiler无法成功完成分析序列。 在仿形循环期间,在确定电气模型期间,电动机每次仿形尝试都变慢。序列因消息而停止:分析序列需要很长时间。 为什么Motor Profiler实用程序无法使用上述BLDC电机完成Profiler序列?运行“低功率”BLDC电机是否需要进行特殊修改? 以上来自于谷歌翻译 以下为原文 We are trying to setup a small BLDC motor with the Motor Profiler utility. -X-NUCLEO-IHM07M1 -FOC SDK 4.3 -Custom motor: 2 pole pair BLDC 18VDC, 2W @ no load, 4000 rpm With this setup the Motor Profiler is not able to successfully finish the profiling sequence. During the profiling cycle the motor is turning slower each profiling attempt during the determination of the electrical model. The sequence stops with the message: profiling sequence takes to long. Why is the Motor Profiler utility not able to finish the profiler sequence using the BLDC motor mentioned above? Are there special modifications necessary running ‘low’ power BLDC motors? |
5个回答
我也遇到了这个问题。我设置了较低的最大值。速度和最大当前,Motor Profiler能够成功创建电机配置文件。
以上来自于谷歌翻译 以下为原文 I have also got this problem. After I have set lower max. speed and max. current, the Motor Profiler is able to successfully create a motor profile. |
嗨,
我们已经将电机调到0.28 Apk。 Profiler实用程序至少给出此值: 你使用了最大电流吗? 0.28 Apk?你的电机规格是多少? 以上来自于谷歌翻译 以下为原文 Hi, we already tuned the motor at 0.28 Apk. This value is given as a minimum by the Profiler utility: Did you use a max current < 0.28 Apk? What are your motor specs? |
我使用的是48V 15A 10极电机。我的设置是Max Speed 500 RPM和Max Current 12 Apk。
以上来自于谷歌翻译 以下为原文 I used a 48V 15A 10-Pole motor. My setting is Max Speed 500 RPM and Max Current 12 Apk. |
好的,你没有达到最低Apk。与我的应用程序相比有哪些不同。
以上来自于谷歌翻译 以下为原文 OK, you are not hitting the minimum Apk. Which is different compared to my application. |
选择BLDC电机,其运行速度为0.33 Apk,高于最低0.28 Apk。在10秒内成功分析。问题解决了。
以上来自于谷歌翻译 以下为原文 Selected a BLDC motor which is running at 0.33 Apk which is higher then the minimum of 0.28 Apk. Profiling successfully within 10 seconds. Problem solved. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 01:26 , Processed in 0.694814 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
553
