电子发烧友论坛|
您好,我正在使用A.09.42.12固件。
我有一个包含多个IM Spectrum转换器通道的状态文件。 但是,我遇到了一些奇怪的行为。在附加的状态文件中,通道13应该输出-20dBm的功率; 相反,它输出到PNA-X的最大功率水平! 奇怪的是,输出相同频率并使用相同校准文件的通道49输出正确的-20dBm功率电平。 我检查了两个频道的设置,它们看起来几乎相同。 有人可以调查一下,看看它是一些设置问题还是固件中的错误? (注意:我有其他渠道以相同的奇怪方式行事,但我不得不删除它们以削减状态文件的大小以包括作为附件)谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello, I'm using A.09.42.12 firmware. I have a state file with multiple IM Spectrum Converters channels. However, I came across some strange behavior In the attached state file, channel 13 should be outputting power at -20dBm; instead it is outputting to the maximum power level of the PNA-X! The strange part is that channel 49, which is outputting the same frequency and using the same calibration file is outputting the correct power level of -20dBm. I checked the settings for both channels and they look to be virtually the same. Can someone look into this to see if it is some setting issue or a bug in the firmware? (Note: I have other channels behaving in the same odd way, but I had to delete them to pare down the size of the state file to include as an attachement) Thanks, rok 附件
4个回答
我看不到家里的电量,但在我看到的状态下,delta频率设置为0 Hz。
这是有意的吗? 如果是这样,形式不好; 因为音调可以添加或取消并给出结果。 如果需要单音响应,请将PNA port1src2设置为关闭。 以上来自于谷歌翻译 以下为原文 I can't see the power at home, but in the state that I see, the delta frequency is set to 0 Hz. Is that intended? IF so, bad form; as the tones can add or cancel and give weired results. If you want a single-tone response, set the PNA port1src2 to off. |
嗨,我将delta F设置为0,因为我想输出该频率,而不是偏离它。
然后我通过'Power'和'Power and Attenuators'对话框将'PNA port1src2'更改为off'。 但奇怪的是,每当我通过'Stimulus' - 'Freq' - 'IMX Spectrum Setup'进行任何更改时,固件会自动再次打开源2! 另外,无法通过激励“IMX Spectrum Setup”对话框关闭源2; 只能通过'Power and Attenuators'对话框。 我确实尝试过关闭和修改源2的实验,但在任何一种情况下它仍然给了我错误的RF功率。 (达到端口允许的最大值)。 我使用安捷伦频谱分析仪测量PNA-X射频端口1的输出功率。 所以我不确定为什么2个不同的imdx通道在相同的状态文件中并且使用相同的校准文件的行为如此不同,当它们都被配置为输出-20dBm时。 韩国 以上来自于谷歌翻译 以下为原文 Hi, I set the delta F to 0 because I want to output that frequency, rather than some offset from it. I then change the 'PNA port1src2 to off' via the 'Power' and 'Power and Attenuators' dialog box. But a strange thing is that whenever I make any change via 'Stimulus'-'Freq'-'IMX Spectrum Setup', the firmware automatically turns source 2 on again! Plus there is no way to turn off source 2 through the stimulus 'IMX Spectrum Setup' dialog box; only through the 'Power and Attenuators' dialog box. I did try the experiment with modifying source 2 off and on, but it still gave me the wrong RF power in either case. (up to the max allowed on the port). I used an Agilent spectrum analyzer to measure the output power coming off the RF Port 1 of the PNA-X. So I'm not sure why 2 different imdx channels in the same state file and using the same calibration file is behaving so differently, when they both are configured to output -20dBm. rok |
蓝色冰汐 发表于 2019-5-31 16:03 我要做的是解决第二个来源的问题:在“电源和衰减器”菜单中,您可以选择路径配置并切换旁路开关。 因此,即使第二个源被打开,它也不会被耦合。 以上来自于谷歌翻译 以下为原文 What I do to get around issues with the second source turning back on: IN "power and attenuators" menu, you can select path configuration and toggle the bypass switch. So, even if the second source gets turned on it will not be coupled. |
您好再次问:以下是我的实验中的更多结果:我已升级到最新的A.09.42.18固件,但我仍然遇到同样的问题。
在回顾我用来创建状态文件的步骤时,我想我发现了问题。 如果我在现有的IM Spectrum转换器通道上使用以下例程,其deltaF = 0MHz且第二个源关闭:SENSE:MIX:LO:POW SENSE:MIX:APPL它将改变LO功率,但它也会改变deltaF 该通道从0到10MHz,当它不应该并且也打开第二个源。 我相信这会导致渠道权力以某种方式被破坏。 因此,即使列出的所述RF功率与之前相同(即-20dBm),在内部,它也会以某种方式重置为最大输出功率(即,间歇行为)。 至少这是我的理论。 我使用Agilent IO控制交互窗口验证了上述行为。 安捷伦固件人员可以验证这一点吗? 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello again, Here are some more findings from my experimentation: I've upgraded to the latest A.09.42.18 firmware, but I still get the same problem. In retracing the steps I used to create the state file, I think I found the problem. If I use the following routine on an existing IM Spectrum Converters channel whose deltaF=0MHz and the second source is turned off: SENSE:MIX:LO:POW SENSE:MIX:APPL It will change the LO power, but it also changes the deltaF of that channel from 0 to 10MHz, when it shouldn't and also turns on the second source. I believe that it leads to the channel powers being corrupted somehow. So even though the stated RF power listed is the same as before (i.e. -20dBm), internally, it gets reset to max output power somehow for some of the channels (i.e. intermittent behavior). At least that is my theory. I verified the above behavior using the Agilent IO control interactive window. Can the agilent firmware folks verify this? Thanks, rok |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 06:01 , Processed in 0.599449 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2158
